Question about Kenmore 64682 / 64684 / 64689 1200 Watts Microwave Oven
Microwave not heat all electronics work
Microwave does not heat, new letter by the time "d". All of the electronics work, but it is not heating. Any thoughts? The manual was useless.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 158 Answers
SIR,
the fuse that controls the temperature of the microwave is open... it should be replace... use a tester to test it plss... also check other components for busted or open ones, then replace them.... the heating element should also be ceck for damage... tnx
Posted on Feb 04, 2009
I have a GE profile PEM31SM3SS that heats intermittently. This is the second time it has stopped heating but in the past has started to work again sometimes months later. Is there any fix I can do short of...
do this test and fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Nov 08, 2013 | GE Profile 1.1 Cu. Ft. Mid-Size Microwave...
Microwave won't heat food
9 out of 10 times if all else is working then it is the magnatron rod that does the heating chances are it will be more expensive than to purchase a new microwave.
Feb 14, 2013 | Microwave Ovens
Oven does not heat food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Jul 24, 2010 | Sharp R-1480 Microwave Oven
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave won't heat anything
Yeah, it's time to invest in a new oven. The magnetron tube in yours most likely just finally wore out. It's the source of the microwaves, and like any tube it gets weaker with age and finally just quits altogether. It would cost more for a new magnetron than it would for a new oven these days.
May 15, 2009 | GE Microwave Ovens
Microwave will not heat
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
 Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
Q - The fan in my microwave oven is not running will this hurt my microwave?
A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
Q - My microwave blows the fuse inside itself as soon as I push the start button.
A - Usually a shorted high voltage capacitor...see components section.
Mar 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Typically, no heating of food, indicates a bad Magnetron (tube) or associated components. Yes, it can be repaired. Magnetrons are not hard to replace and can be ordered online through MCM electronics. Please let me know if I can be of further assistance to you.
Good Luck,
- Jim
Feb 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore 64682 / 64684 / 64689 1200 Watts Microwave Oven Logo
97 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
