Question about Sanyo Televison & Video
Old 4 head VHS missing plug
I have a Sanyo VWM 638 mts VHS that works fine. While moving lost or misplaced the power plug. Is there anyway I can pay another one.
thanks,
Diva
Try CPC or Charles Hyde.
Posted on Jun 12, 2008
Need a owners manual for a Sanyo vcr vwm 800
Here is the manual for the next model up. It should be similar enough to fix your problem. I hope this helps. http://www.retrevo.com/support/Sanyo-VWM-900-VCRs-manual/id/311ag907/t/2/
Mar 15, 2011 | Sanyo VWM-800 VHS VCR
How can I hook up my sanyo VWM-800 to an old tv with out av plug ins thank you.
Well think about it it needs a signal in ,so the antenna is the signal in which is usually coax or older screw jacks
Feb 18, 2011 | Sanyo VWM-800 VHS VCR
Video heads of Sanyo VWM-800 4 head vcr need cleaning.
Take the top off and spray the main head with Servisol Video 40. (image below) Also the tracking and audio heads.
Wait for it to dry before putting a tape in. In the future use only this it is much better and cheaper than cleaning tapes.
Mar 10, 2010 | Sanyo VWM-800 VHS VCR
Hook up instructions
has this problem been solved yet? hookup is easy
Nov 08, 2008 | Sanyo VWM-800 VHS VCR
Sanyo VWM-406 recorder
lost manual need codes
Dec 15, 2007 | Sanyo VWM-800 VHS VCR
Will only display on ch 3
You will need to take the original remoter and go into the menu, find the channel set up and reprogram the VCR for the channels, as when you lost power the channels also went out because of the memory chips need the power to hold the data.
Apr 29, 2007 | Sanyo VWM-950 VHS VCR
Can't get picture to display on ch 4
there is a switch at the back that you can to channel 4 or 3 good luck
Apr 17, 2007 | Sanyo VWM-950 VHS VCR
Tape will not load
A schematic would definitely be a plus here, as you could then check the logic levels from the sensor(s), as the "light path" is interupted. If voltage levels changed properly, and no tape load was initiated, then this would indicate a problem elsewhere. You may want to also check for the presence of power supply voltages. If the voltage supply for the loading motor (often the capstan motor) is missing then there would be no load initiate. It sounds like you have some knowledge of how these things work- a good thing. As you are probably aware, todays electronic equipment (VCRs included) is substandard, disposable, not worth investing much if any repair. Find an old Panasonic manufactured unit, and such will often outlive several of these "lighter than air" cheap rascals.
Feb 26, 2007 | Sanyo VWM-950 VHS VCR
Televison & Video Logo
52 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
