Question about Coleman Mach 15 Air Conditioner
COLEMAN TSR MACH 3 COMPRESSOR
I believe I'm having the same problem. I just bought a used travel trailer equipped with the Coleman TSR Mach 3. We started using the a/c this past Saturday morning and was working fine until about 2:00 pm when the sun was directly over the camper. Then the compressor kept shutting off and when it tried to kick back on it just couldn't. So we turned it off and when the sunset and everything cooled off we started it back up and it ran all night long because we stayed in it just to make sure. We left it running all day Sunday until 2:00 pm came again and the compressor shut off again. Again when it cooled it ran fine. Now two days later it will run for about an hour and it will cut off and when it tries to come back it just cant't make it. Nothing is tripping inside the camper or the house, water is also dripping from atop the camper so I don't guess it is freezing up. Could this be something major? Please help I hate to buy a new one
  • Wayne 14 Jun 12, 2008
    The air conditioner runs but the compressor will not kick in or start!
  • 770 Answers
I would check the thermostat based on what you said it could be out of calibration
Posted on Jun 11, 2008
3 Suggested Answers
  • 54 Answers
SOURCE: coleman tsr mach 3 RV Air Conditioner
I don't think you need a new one just a good cleaning and service. The unit has a liquid high temperature line near the compressor with a fan blowing outside air across it this coil gets clogged over time with air-borne dirt and pollen and leaves and such and must be cleaned regularly or the unit will be unable to remove the heat from the coil and during the peak demand (3pm) the circuits that protect the compressor and the trailer wiring from being overloaded and burning or melting will trip. From what you have described it sounds like the RV is working as it should with a condenser coil that needs to be cleaned. GL and happy camping!
P.S. I've only serviced the occasional RV unit but in those cases I laid a piece of plywood on top of the Rv for work platform removed the retaining screws from the top cover and used a spray bottle with a good heavy foaming cleaner a shop-vac and a brush to get the job done.
SOURCE: Coleman Mach 3 Rv air conditioning
Dirty coils might be your problem. You might have a refrigerant problem as well. Try cleaning it first then have a tech put gages on it. Doesn't sound too serious
Posted on Jun 12, 2008
COLEMAN TSR FULL LOAD AMPS
Go to airxcel.com, you should get some options, to get either their literature or tech support and they should be able to help you.
Aug 07, 2012 | Coleman Mach 15 Air Conditioner
I have a 2010 30' cougar travel trailer, we have never used the air conditioner which is a coleman mach model, when I put it on auto and cool it blows cool air but never gets cold am I suposed to
Check the temperature of the air coming out the vent If it's more than 10 degrees below the air going in it's ok. If it's the same temperature, the condensing system may be not working. The compressor may just be a quiet one!
May 18, 2012 | Coleman Mach III Air Conditioner
HOW OLD IS MY UNIT? IT'S A TSR MACH 3 WITH BLUE LETTERING THANKS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Feb 20, 2010 | Coleman Mach III Air Conditioner
Connection to difusser too short.
We used to buy a roll of 25ft, or so, at the dealer I worked for in the past, for just such an installation, of the vinyl that is connected between upper & lower units. Attach it to top as other piece is with band clamp, let it drop down through the hole, peel tape off, stick to lower and trim it off. Worked great. Dealer you bought unit from may have some. Other set-ups I've run into lately are ducting made out of 4 pieces cut to proper length 1" insulation & taped together at corners, and before that was just heavy cardboard, bent in proper shape like opening, then, vinyl taped to inside of cardboard. It all worked, but personally I'd prefer the vinyl, at proper length.
Aug 19, 2009 | Coleman Mach III Air Conditioner
Coleman tsr rooftop airconditioner
NEED A FREON RECHARGE AND MAY POSSIBLY HAVE A FREON LEAK
STEVE'S APPLIANCE
516-300-3249
Apr 05, 2009 | Coleman Mach 15 Air Conditioner
Tsr mach3 conditioner
The smell is because of the stuff growing inthe water from the air conditioner. When you run the a/c it keeps the water condensed on the coil. When you turn the a/c off and run just the fan, it allows the water to warm up and start evaporating thus allowing the goodies in the water to become airborn. It would be adviseable to have the unit disassembled and cleaned by a professional due to the obvious danger of mixing water and cleaning chemicals with electrical equipment
Jun 25, 2008 | Coleman Mach 15 Air Conditioner
Jun 12, 2008 | Heating & Cooling
Coleman tsr mach 3 RV Air Conditioner
Jun 11, 2008 | Heating & Cooling
the fan motor bearings need lub....the shaft has a tiny access hole to put some oil into. because the fan shaft is slowing down, it is putting more strain on the voltage current, and eventually the internal breaker shuts down the ac........plus your condenser is not getting enough air accross it, compressor heats up, and it too will shut the unit down......older units have to be oiled every year, and eventually it too will fail, and a new blower motor assembly is needed or replace the ac unit.....blower motor units are around $130....now you install it or pay to have it done at around another $150 labor,,,,,try yourself, if it fails then call the tech........let me know ..ray..yyzazz@ao.com
May 20, 2008 | Coleman Mach 15 Air Conditioner
Coleman Mach 15 Air Conditioner Logo
590 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
