I have a toshiba satellite a40 and it becomes so hot when i play games now, will a can of compressed air fix this? plz help :)
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 265 Answers
Hey coolsambo,
If you clean your computer's vents and case fans using an air duster (can of compressed air) you may see an improvement in performance, but please keep in mind that this may not necessarily resolve the issue.
Ideally, you'd be able to open the case and dust every square inch of the laptop, but this isn't always an option for many users who are still covered by the factory warranty. Should you choose to use an air duster, remember to hold the can at least 6-8 inches away from the surface being dusted, as the compressed air may leave liquid residue behind or even freeze some surfaces.
Blocked vents and failing hardware components have also been known to cause laptops to overheat (in addition to prolonged use of video cards by various games), so should cleaning your laptop fail to resolve the problem, you may wish to speak with your local repair facility for further assistance.
If necessary, you may always bring your laptop into your local Best Buy™ store for more information. Best Buy™ technicians are able to perform repairs on most major products we sell, and can provide service options under most manufacturer warranties.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 11, 2008
Toshiba satellite p505d s8935 overheats when playing 3d games after about an hour or so. Not every time but often enough to be frustrating. I then have to let it cool off for about 15 minutes and then...
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Sep 19, 2012 | Toshiba Satellite P505D-S8935 Notebook
My Toshiba Satellite A215-S7462 runs so hot that it shuts down? can you help
Hi. The most common cause of overheating is a build up of dust inside the laptop, mainly on the fan blades and the heatsink, This dust also collects around the exhaust and becomes matted together like a quilt, blocking the hot air from escaping the unit, causing the laptop to overheat and shut down to protect the CPU from damage. You could try to clear the blockage with a can of compressed air, although in many cases this does not work. It all depends on the level of blockage. If this does not work, and if you feel confident about taking the laptop apart to remove the blockage, you could try this...
http://www.irisvista.com/tech/laptops/toshiba-satellite-a215/disassemble-display-panel-1.htm Information courtesy of irisvist.com. Hope you will find this helpful.
Jan 31, 2011 | Toshiba Computers & Internet
I have a toshiba satellite it will not play any audio sound and when you go on the volume it says it as toshiba dvd-rom sd r2412 and all i want is sound on my laptop can you help me please
Do you have sound at all, or just not when you play a CD or video DVD?
Fist thing to check is if your audio drivers are installed and working properly.
If necessary, find and install the right sound driver for the computer.
There are some more things to try to fix sound in Windows, hope that helps.
May 12, 2010 | Toshiba (SD-R2412) for Satellite A10, A15,...
A neet drivers for my Toshiba SATELLITE A40
You can download them from here, http://eu.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=EU&mode=allMachines&action=search&teddProduct=532&selShortMod=370
Jan 26, 2010 | Toshiba P000392200 - Satellite A40, A45...
Satellita A40 problem
Your heatsink is probably blocked.
Many older laptops run HOT and will shut down very quickly if there is no ventilation.
You can check this by shining a flashlight into the fan vent and checking it's visible when looking in the heatsink vent (or vice versa)
You can dismantle the laptop to get the dust out.
OR
Or use a can of compressed air to blow through the heatsink grilles and dislodge the dust, followed by a vacuum cleaner nozzle over the fan intake to **** as much dust as possible back out of the machine.
It may take several blow/**** cycles to clear it entirely - don't be surprised to see enormous quantities of dust erupting from the fan vent when you first use the compressed air.
if you take the second option, don't dismantle the case and it's best to do this with the machine running.
Plastic vaccum cleaner nozzles carry a hefty static charge, but as long as it remains outside the case the components will remain protected and the area where the air runs through the case is entirely shielded from the rest of the machine.
If the vent isn't freely flowing air when you've tried a couple of cycles (check with a flashlight for airflow) then the machine will have to be dismantled and the dust removed manually (I've seen accumulated dust turn into 1/4 inch thick felt blocks in some laptops and have had to write off many laptops used by smokers as they had become a toxic health hazard.).
Dismantling a laptop is not a job for a novice as it is easy to damage electronic components with stray static electricity charges and plastic case components while pulling things apart It's also possible to wreck cases by overtightening or using wrong length screws when reassembling.
Sep 18, 2009 | Toshiba P000392200 - Satellite A40, A45...
System gets shut down whe play any audio or video file
it might have a driver conflict issue...try to upgrade the sound driver of your model from the Toshiba website. Hope this helps
Aug 10, 2009 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
DVD PLAYBACK TOSHIBA A40
kindly check this link for resolution. if it doesn't solve the problem, then it must be a hardware related issue. or you need to install video codecs.
http://support.microsoft.com/kb/929461
i hope this helps you.
Sep 12, 2008 | Toshiba Satellite A40 Notebook
Toshiba Laptop overheating
Your Problem is of overheating the unit.
Pls check the Air exhaust of the Laptop. The fan may be blocking air and may be causing the processor hot. It's better to
service the Laptop if problem still persists.
Viren
Jul 17, 2008 | Toshiba Computers & Internet
Counter Strike
Have you tried updating your direct-x too?
Dec 10, 2007 | Toshiba Satellite A40 Notebook
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
