Coleman tsr mach 3 RV Air Conditioner
I bought a Camping trailer that has a Coleman Tsr Mach 3 Air conditioner on it. I can run the fan on it on High, or Low for hours. When I put it in the "cool" position it cuts off after about 10 min. This happens wheather it is in the high or low setting. I believe I'm having the same problem. I just bought a used travel trailer equipped with the Coleman TSR Mach 3. We started using the a/c this past Saturday morning and was working fine until about 2:00 pm when the sun was directly over the camper. Then the compressor kept shutting off and when it tried to kick back on it just couldn't. So we turned it off and when the sunset and everything cooled off we started it back up and it ran all night long because we stayed in it just to make sure. We left it running all day Sunday until 2:00 pm came again and the compressor shut off again. Again when it cooled it ran fine. Now two days later it will run for about an hour and it will cut off and when it tries to come back it just cant't make it. Nothing is tripping inside the camper or the house, water is also dripping from atop the camper so I don't guess it is freezing up. Could this be something major? Please help I hate to buy a new one.
  • BIGHUNTER3 Jun 14, 2008
    I think we figured it out!! I took everything apart and cleaned thoroughly while it was still messing up. I kinda tapped the starting capacity and then all a sudden it started working for a few minutes. I replaced the wire connectors and put a new starter capacitor and is now running very good. Thanks for the valuable information.
    Scholar:
  • 54 Answers
I don't think you need a new one just a good cleaning and service. The unit has a liquid high temperature line near the compressor with a fan blowing outside air across it this coil gets clogged over time with air-borne dirt and pollen and leaves and such and must be cleaned regularly or the unit will be unable to remove the heat from the coil and during the peak demand (3pm) the circuits that protect the compressor and the trailer wiring from being overloaded and burning or melting will trip. From what you have described it sounds like the RV is working as it should with a condenser coil that needs to be cleaned. GL and happy camping!
P.S. I've only serviced the occasional RV unit but in those cases I laid a piece of plywood on top of the Rv for work platform removed the retaining screws from the top cover and used a spray bottle with a good heavy foaming cleaner a shop-vac and a brush to get the job done.
Posted on Jun 11, 2008
My Coleman mach air conditioner on my pop up needs to be replaced, per a friend. He when the freon is gone, so is the unit. Is their a part that can be replaced and just add freon.
Posted on Feb 09, 2009
2 Suggested Answers
SOURCE: coleman tsr mach 3 RV Air Conditioner
the fan motor bearings need lub....the shaft has a tiny access hole to put some oil into. because the fan shaft is slowing down, it is putting more strain on the voltage current, and eventually the internal breaker shuts down the ac........plus your condenser is not getting enough air accross it, compressor heats up, and it too will shut the unit down......older units have to be oiled every year, and eventually it too will fail, and a new blower motor assembly is needed or replace the ac unit.....blower motor units are around $130....now you install it or pay to have it done at around another $150 labor,,,,,try yourself, if it fails then call the tech........let me know ..ray..yyzazz@ao.com
Posted on Dec 31, 2008
COLEMAN TSR FULL LOAD AMPS
Go to airxcel.com, you should get some options, to get either their literature or tech support and they should be able to help you.
Aug 07, 2012 | Coleman Mach 15 Air Conditioner
HOW OLD IS MY UNIT? IT'S A TSR MACH 3 WITH BLUE LETTERING THANKS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Feb 20, 2010 | Coleman Mach III Air Conditioner
Coleman tsr rv air conditioner leaks into rv when running
It probably has a clogged condensate drain. Take off the cover on top the RV and check hoses or tubes leaving unit for debris or lint. Often this water is used to help cool the condenser so look for leaves pine needles etc in the pan. There may be a cover you can remove on the evaporator section that will allow you to clean the collection pan and hose or trough. Is it possible the RV is far enough out of level that the condensate can't "run uphill"? Always power off while working on this unit unless you are electric savvy. Good luck!
Jun 28, 2009 | Coleman Mach 15 Air Conditioner
Coleman tsr rooftop airconditioner
NEED A FREON RECHARGE AND MAY POSSIBLY HAVE A FREON LEAK
STEVE'S APPLIANCE
516-300-3249
Apr 05, 2009 | Coleman Mach 15 Air Conditioner
What are the 1st 3 blower settings for?
Those are for the run time of the circulating fan after the heat has been satisfied.
Jan 26, 2009 | Coleman Mach 15 Air Conditioner
Tsr mach3 conditioner
The smell is because of the stuff growing inthe water from the air conditioner. When you run the a/c it keeps the water condensed on the coil. When you turn the a/c off and run just the fan, it allows the water to warm up and start evaporating thus allowing the goodies in the water to become airborn. It would be adviseable to have the unit disassembled and cleaned by a professional due to the obvious danger of mixing water and cleaning chemicals with electrical equipment
Jun 25, 2008 | Coleman Mach 15 Air Conditioner
COLEMAN TSR MACH 3 COMPRESSOR
I would check the thermostat based on what you said it could be out of calibration
Jun 11, 2008 | Coleman Mach 15 Air Conditioner
Coleman TSR RV air conditioner
There should be a solar panel on top of your roof top air conditoner. There is a quick disonnect for the solar panel. If the monitor light illuminates the solar panel is working.
May 21, 2008 | Coleman Mach 15 Air Conditioner
May 20, 2008 | Coleman Mach 15 Air Conditioner
Heating & Cooling Logo
2,406 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
