Air conditioner wont stay running
Kenmore 15100 btu model number 25373156301. it starts for a second then shuts off. only used 2 years. bought in late 2003. worked in one house on its own brreaker. moved and hasnt worked since. handled gently
  • lillysdaddy Jul 01, 2008
    my air conditioners will not stay running. it shut off then the code (E I) come on the screen
    Scholar:
  • 54 Answers
Is the compressor running at all? During the move was the unit kept upright? The compressor cant compress a liquid so if the unit was set on one of its sides or upside down for very long the oil drained into the compression chamber and it will take an equal amount of time for it to drain back out do not try to run it until it has set upright for a day at best it will trip the overload at worst it will break a valve. Hope this was some help GL!
Posted on Jun 11, 2008
Model 25373156301 air conditioner: What are the dimensions? How many BTU? Last year they were manufactured?
Found very little on that model: Kenmore 25373156301
24 in. Wide, 18 in. Height, 24 in. Depth and approx. 112 lbs.
15,000 BTU, Parts are still available.
Unknown date(s) of manufacture but Sears (Kenmore) does have similar (exact matches) models still in production.
Sep 13, 2014 | Heating & Cooling
I have had a MWK-05CMN1- b17 5000 btu window mounted air conditioner unit that i bought last year. It was only used a couple times. It never cooled down the room. And when i finally used it and relized it...
From what you are saying, it sounds like the air conditioner is a lemon.
Unfortunatly, these small room size air conditioners are not worth the cost of reapir.
May 12, 2014 | Heating & Cooling
Heat pump wont stay running
could be as simple as anits in the
cut off switch.
Nov 12, 2011 | Heating & Cooling
Does the 15100 Kenmore BTU need a dedicated line in order to not blow a fuse?
Is this a 120 volt unit? If so, you might try to find the amp rating on the unit itself. A 120 volt unit that big will have to have a circuit all by itself. Probably a 20 amp breaker, no less than 15 amp just for the air conditioner.
If it is 240 volt, it will definitely have to have its own circuit.
Jun 21, 2011 | Kenmore Multi-Room Air Conditioner
Can a frigidaire (mod.no. fam156r1a) 15100 btu a/c unit be recharged
Hello, yes the unit can be recharged but a piercing valve must be added to the low side of the system in order to do that. The valve pierces the tubing and then the refrigerant can be added.
Apr 25, 2011 | Frigidaire FAM156R1A Wall/Window Air...
Kenmore 12000 btu turns on fine but after a few minutes fans shut off and compressor keeps running this is a heat and air model
First replace fan capacitor and try, if not, bearings worn out in your fan motor. Replace bearings or motor with new capacitor.
Jan 14, 2011 | Kenmore 76081 Wall/Window Air Conditioner
I have an old Kenmore 25,000 BTU Air Conditioner (Model number 253.7792580). Recently it started blowing air that is not really cool, it's actually room temp. It makes a slightly different sound when it is...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 29, 2010 | Kenmore Heating & Cooling
I am looking at buying a used kenmore 15100 btu unit model 253-355-350 that is supposedly 5-6 years old but little to no use. Is there any issues with this regarding losing some of the coolant? Does it...
This is a catch 22....this is a good unit, but I would try it before you buy. If you get it cheap enough it will pay for itself. Are there more efficient units? Yes , but at what cost? This will be a decision between long term and short term. I would get a new unit if you want long term....and short term if you just want toget by a couple years.
May 10, 2010 | Kenmore Multi-Room Air Conditioner
Heating & Cooling Logo
234 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
