Question about Brother MFC 420CN All-In-One InkJet Printer
Error message Out of Ink
When I turn on the machine it says out of ink. I have purchased new ink and installed it. It worked for a day then next time I turned it on got the same message. I tried taking out the ink and reinstalling but no luck
  • Anonymous Jun 18, 2008
    Mine keeps telling replace black ink. I have done that. I thought maybe it was a bad ink tank but tried another still keeps telling me replace black ink.
  • chickpea Jun 23, 2008
    It told me to replace cyan ink cartridge. I did and the message won't go away!
The answer to all printer problems is to go buy a new one of the same exact model put your broken one in the box and return it for your money back. Tell the store it was'nt working correctly.Make sure you buy the new one at a store that has a good return policy. Problem solved!!
Posted on Jun 24, 2008
My printer says it's unable to clean 46? it's a mfc printer LC-51 Series ink
Please note that this error code appears when the container in the printer that is responsible for storing used / discarded ink is full or registers as full.
The following instructions will guide you through the process of resetting the printers self clean counter so the error will go away but in the event that the ink absorbing box is actually full and this is not an erroneous message the error message will trigger again immediately.
Machine Error 46 - Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An "initial purge", for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an "Unable to Clean" external message and will be unable to use the printer. The "Unable to Clean" external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter MFC620CN/420CN/410CN/210C and FAX2440C
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Also please note that if the ink box is full and the error code is reset the printer may begin to spill out excess used / discarded ink.
I suggest purchasing a new ink absorber box and installing it.
May 04, 2011 | Brother MFC 420CN All-In-One InkJet...
I have installed 2 new inks and still get a message asking me -- install new ink cartridges to continue .. I purchased these new inks 2 hours ago.
Install the cartridge by following the steps given in this link.
If the problem persists you will need to reset the printer.
Follow these steps to reset the printer:-
  1. Without turning the power off, remove the power cord from the back of the printer and from the wall socket.
  2. Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.
  3. Check the printer for the error message. If the error message continues, go to the next step.
Also, Don't forget to remove nozzle protective tape from the cartridge using the pink pull-tab.
Do not touch the copper contacts or the ink nozzles
Good Luck and have a nice day.
Jun 09, 2010 | HP Photosmart D7460 Printer
My dell 924 printer shows right cartridge incorrect and I just had both cartridges refilled what is wrong?
I purchased remanufactured ink cartridges through amazon.com. I got 4 for the price of 1 through Dell. After installing the first cartridge, it printed for a few days and then I got the same message "left cartridge incorrect". Unfortunately, I did not read the piece of paper that came with my cartridge that says "STOP" read this before you install the cartridge.
I had to throw out the cartridge that I had just installed and put in a new one and follow these steps:
1. If you recieve a pop-up message indicating that the cartridge has been depleted or a low ink level warning, please disregard.
2. Check "Don't display this dialog again" and click "ok" or "continue printing" if necessary.
3. In the printer status window, since you have already ordered ink, do not click the "order ink online" button. If you have the option, check "I have ordered my ink, please don't remind me again." If not, close the window and continue printing.
I'm not sure why, but these instructions were vital to getting my remanufactured cartridges to work.
I am posting this reply to hopefully help out the next person that has this problem. Unfortunately, I lost a perfectly good ink cartridge because I failed to read the instructions the first time. But the next one worked just fine when I followed the instructions. Good luck!
Mar 09, 2010 | Dell 924 All-in-One InkJet Printer
Error message more than one ink tank of the same color is install
You need to take all inks out and install 1 at a time to see what the display says after each. Sometimes you get a defective ink tank and it will report on the wrong one. Canon will replace a defective tank within 30 days of date of purchase.
Nov 04, 2009 | Canon Pixma iP6600D InkJet Photo Printer
I haxe recently purchased a brand new canon mp530 that is still under warranty.I don't allways have the problem but often enough for it to be one.Adout 90% of the times I try to print I get an error...
I notice that you saw error message 'check ink c'. This means the printer want you to observe cyan ink cartridge. so,what happen before this message appears?. Please make sure that cyan ink is not empty. if you are sure the ink not empty,then remove cyan ink and reinstall it,else try dry clean ink cartridge contact or you may use contact cleaner before reinstall it. if you have have another cyan ink cartridge that is in good condition,compare it. if this works,means cyan ink cartridge is faulty then you need to replace with the new one. but if the problem still persist,it may caused by carriage unit or logic board problem.
Soruce: Inkjet Forum
Oct 11, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Dell a940 error code 50c
From doing my research, I have found that the 50C Error message comes from the cartridge, usually if it has been refilled. If this cartridge is new, please return it to the place of purchase for a new one or a refund.
Here's what happens when you refill the Dell Series 2 ink cartridges. There is a sensor in them that cannot be reset.
Dell ink cartridges can only be purchased at Staples, Walmart or Dell's website.
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
if u have not refilled ur cartridge and u still get this error i suggest u buy a new cartridge.....
good luck
have a nice day
Jul 08, 2009 | Dell Office Equipment & Supplies
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Canon PIXMA MP530 printer repeatedly getting LCD Error Message: "CHECK INK U071 5Bk". I have removed, reinstalled, reseated the 5Bk and all other ink tanks multiple times. Usually when this...
I have Canon M560 printer installed 8 months ago. I replaced the CLI 221 Magenta and CLI221 Cyan ink cartridges, won't work and got this message Error 1411. Tried repeatedly to reinstall the ink cartridges and still have this message coming back. Any solution you could offer? I would appreciate it. Thank you.
ben
Nov 06, 2008 | Office Equipment & Supplies
MFC 210c Unable to Print Use Troubleshouting and routine maintenance chapter in Users Manual
My color has not worked well in the past few months. Now I get the message Unable to Print, Use Troubleshooting and rountine maintenance chapter in user's manual. I've tried everything it told me. I've removed all ink cartridges and left them upright (they are ALL brand new) and cleaned all the ink ports. I've cleaned the machine several times. It's told me there's no ink cartrige, I've replaced them, turned the machine off and on, unlplugged, etc. Then go to print and I get the same message again and it won't print. The machine is almost 2 years old and has worked fine until about 6 months ago when the magenta stopped working all together. Now this. Any help? Thanks.
Nov 05, 2008 | Brother MFC 210C All-In-One InkJet Printer
Epson stylus R 310 "general error" message
Those generic refills are not worth i, plus they may void the warranty. Try removing them and cleaning the little circuit board sensor. Make sure leaked ink hasnt covered them.
Oct 22, 2007 | Epson Stylus 1000 InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
29 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
