I own an Entiveo DP3220 player. Suddenly, I cannot get the picture to come on when I insert a DVD. What could be wrong?
2 Suggested Answers
leecom72
  • 4806 Answers
SOURCE: I own a Entiveo DVD
I'm sorry to tell you that it sounds like the lens on the DVD player has failed so it can't read a disk, thus the message No Disk that you see on the display.
You could try putting a lens cleaning CD in the player to see if this caused by dust but its highly unlikely that dust is the problem.
You maybe able to have a new lens fitted to the unit if you take the player to an electrical repair store.
Kind regards.
Posted on Dec 14, 2010
Have a GE universal remote trying to program to my
GE remote control have no set-up code to this brand DVD player.
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Aug 30, 2014 | Televison & Video
Problem with vertical hold.
with your control push the set up button and on TV Output choose NTSC and Video Output choose S- Video.
Feb 15, 2009 | TruTech TT320
When i hook my dvd player up i don't get a picture, when i play the dvd, i get sound. what is wrong? thanks bonnie
If Progressive scan is turn on the player and not on the tv it wont show a picture, or it could be your tv doesn't have progressive can, or check your AV cables, if through componet you have to make sure your tv is on the componet channel and that the colors all match and are inserted fully into the jacks.
Dec 29, 2008 | Philips Magnavox MWD7006 DVD Player
Have picture, no sound
I've had this trouble too. Not sure how to fix it, but I've found a work-around:
Remove DVD.
Insert Audio CD.
Wait for audio to play.
Remove audio CD.
Reinsert DVD.
Sound should work again.
If you power off the unit, you may have to try this procedure again.
Sep 27, 2008 | Cyberhome CH-DVD 300 DVD Player
"Wrong Disc" error message
do you insert DVD-/+R? or original DVD
  1. if you insert original DVD you have to search the code to change your regional code and try with ALLZone. search on the web with your model.
  2. if you insert DVD-/+R probaly you have just to clean up your laser with a clean up CD
Apr 22, 2008 | Televison & Video
DVD not reading but spinning
Are you using +R discs(not the -R)? Use Sony brand +R or try using a few +RW's and see if that corrects the problem.
Feb 23, 2008 | iLO DVD Recorder DVDR05
NexxTech DP3222 DVD Player
Open tray, press on the remote, stop-2-3-7-9, press arrow down until 0 and press ok.
Make shure you put TV TYPE --> ntsc in the general setting
I tried this (on a multisystem set that can be "made to think" that it's a PAL or NTSC set as the case may be) and it worked. The Nexxtech DP3222 and the Entiveo DP3220 are basically the same unit except that (a) the hack for the Nexxtech doesn't require resetting every time you turn the unit on and off, unlike the Entiveo (this is really annoying) and (b) you can set the Nexxtech to multisystem, NTSC, or PAL standards, whereas the Entiveo is NTSC-only, but (c) the fast-forward on the Nexxtech is somewhat less intuitive than on the Entiveo (involves holding a button down). All in all, I prefer the Nexxtech, if only because it is more easily hackable. And I would have sworn that the Nexxtech had a blue screen saver on it before I started hacking it, because now it has a really gross-looking black-and-white screen saver. But I don't care about screen savers as long as the unit does what I want it to do.
Jan 28, 2008 | NexxTech DP3222 DVD Player
Televison & Video Logo
152 people viewed this question
Top Televison & Video Experts
Electro Med Services...
