Question about Apple 20" Flat-Panel TFT LCD Cinema Display
Power light flashes
Hi, I hope you can help me solve this problem. For the last 72 hours the power light on my apple LCD monitor flashes 3 times, then no light for 5 seconds and repeat, constantly. The monitor looks good, but I'm wondering if it's trying to tell me something horrid is about to happen.
  • noordmitpf Apr 24, 2009
    The monitor LED does sequences of 3 flashes.
    I have a G4 Apple Cube with 15" LCD Monitor.
    I wonder what this means.
    - Apple User
I have an older 20" display. I have had this same problem on occasion, and coincidentally, just experienced it again this morning. It seems to occur after I do an OS update. I powered down the computer, disconnected the display, reconnected by pushing firmly into place, then powered up. The flashing stopped and the display works fine. You might have a different problem, but that simple solution worked for me.
Posted on May 14, 2009
Intermittant power up. Would work for a couple of hours then completey turn off no power at all. No standy by light. Reboot computer a few times then it would come on.
the power supply is separate from comp. see if transformer is getting hot. that box with power wire thats between the monitor and outlet if there isn't one that means the transformer is inside the monitor is if faulty you need to change the transformer. hope this helps
Nov 28, 2009 | Apple Studio Display 17" LCD Monitor
Power light flashes continually but monitor will not work. I leave computer on at all times but turn monitor off. I did that last night but today it was flashing and won't come on or off. I tried turning...
Yes. Flashing LED with no image on the screen is the first sign of the power supply gets overloaded. That may be caused by blown/shorted electrolytic capacitors. Open the monitor, take metal lid off and observe for those caps which are rounded on top. Replace them with proper ones.
Sep 11, 2009 | Acer AL1916W 19" LCD Monitor
I have a monitor HANNS-G It worked 3 years. And exactly after 3 years warrant policy ended my monitor got a problem. It looks like there is a problem in power connection on front buttons. After I connect a...
This is a problem with the power supply unit inside the monitor, there is no easy way out here. If you keep on using your monitor like this eventually it won't switch on no matter how long you wait. Keep on using it like this for the time being without switching off anything but ultimately you will have to take it in for repairs or otherwise purchase a new screen..
Aug 02, 2009 | Microsoft HannsG HU171D 17" LCD Monitor
HP vs17x flat screen monitor won't come on, blue light flashes.
Try taking on the back of the monitor and pulling the power plug all the way out of it for about five minutes and then plug it back in and restart the computer see if it solved it thanks
May 27, 2009 | HP vs17c 17" LCD Monitor
My dell E196FPF 19'' lcd screen acting strange!
Are You using a extention cord or a ups that is not funtioning properly....?? if yes try connecting the power for the monitor seperately or directly to a plug base...
this mi8 solve ur problem
Apr 10, 2009 | Dell E177FP LCD Monitor
Apple 23 monitor 3 blinks and then pause, top screen is dim.
Apr 04, 2009 | Apple Cinema Display 23" HD Monitor
Flashing green power light - Black screen
I had the same problem with an AOPEN 17' lcd that was left behind at a rental property... I plugged it into my dell dimmension 4400 in place of my old analog. It worked fine the fist night, and got up and when turned it on again it had the famed green blinking power light. I switched back to the analog, and just disappointed I plugged in the AOPEN to another power source, and power came on a steady red light. I plugged it back into the puta and it came on again. I have not turned the monitor off again for fear of the blinks, and has been working great for close to a week now. Hope it helps someone else out there. Richard
Mar 27, 2008 | AOpen F75PS 17" Flat Panel LCD Monitor
Apple Studio Display Flashing Power Button
For the brave of heart, You can disassemble the monitor. After you get in to the inside of it, you'll see a circuit panel with 6 ballast coils on it. On my Cinema display, what happened was that the solder joints on some of those coils had cracked, causing intermittent connection. After hitting all the connections with a soldering iron to heal the cold solder joints and re-assembling it, it is working perfectly fine now.
Jan 29, 2007 | Apple Cinema HD 23" LCD Monitor
Acer AL1715 17" LCD Monitor
Certain versions of the Acer AL1715 monitor had a problem with the VGA socket. Specifically, the plastic case around the socket was not wide enough. The plastic interfered with the plug and so the plug did not seat properly. I fixed several of these monitors by shaving off some of the plastic with a dremel mototool. A hand file would probably work as well. You have to remove the plastic back to do the job.
Sep 02, 2006 | Acer AL1715 (Black, Silver) 17" LCD...
Apple 20" Flat-Panel TFT LCD Cinema Display Logo
199 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
MarkMAlford
MarkMAlford
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
