Question about Euro-Pro Shark 80 - 7133
Automatic Threading It does not work; it did at the beginning but after 2 or 3 weeks of having used the sewing machine, it just not thread automatically.
  • 323 Answers
The tiny hook which goes through the eye of the needle is bent, broken or misaligned. Use a magnifying glass to watch the hook as you try the threader. Sometimes it may pass to the side of the needle and will need to be moved by loosening a screw and adjusting the assembly from side to side. Some machines don't have a screw to move. In this case you need to use a small screw driver to flex the hook to the correct position. Or you can buy a new part from your dealer for about $5.
sewman7
Posted on Jun 19, 2008
My serger singer 14u-544 cuts the fabric but doesn't sew. Whar can I do? Thanks
Probably due to incorrect threading or else one of the needles are bent. I had the same problem and it was the threading and the tension.frustrating as all get out.
Jun 23, 2017 | Singer Sewing Machines
Tip
Tips for Threading your Needle
It's my experience that the automatic needle threaders on most machines work fine for a while, then the little hook that pulls the thread through the eye of the needle gets bent so it won't go in the eye anymore.
Here are a few tips that will help threading your needle the old-fashioned way easier:
1. Use a pair of tweezers. I have a large pair of tweezers that live on my sewing table. They are great for pulling out threads I've ripped out, for helping guide fabric under the pressure foot, and for threading the needle. I hold the thread in the tweezers maybe 1/2" or less from the end of thread, and it just slides on through.
2. Instead of,or in addition to, wetting the end of the thread, wet the eye of the needle. (I lick my index finger and wipe the eye with it.) For some reason, the moisture in the eye sort of pulls the thread in.
3. Make sure the thread ends with a sharp cut. Snip off the end if it's the least bit raveled or frayed.
4. Use plenty of light. The little lights on most sewing machines are really pretty pathetic, so don't depend on that for your only light source, especially when threading your needle. I have a clamp-on light, a floor lamp, and two table lamps on when I'm sewing--and that isn't enough, sometimes!
5. Get a pair of reading glasses. They magnify small things--like the eye of a sewing machine needle!
Hope these tips help!!! Happy Sewing to you all,
Robbie
on Feb 22, 2010 | Sewing Machines
Thread error message
rethread needle using every thread guide, also try changing the needle, if that doesn't help them the machine may have a computer problem
Dec 24, 2015 | Brother SE-270D Computerized Sewing...
Keeping the thread in needle when you begin to sew
after threading the needle pull about 6" of thread out the back under the press foot
that way the thread is jammed under the foot and is held in place for the next thread
bobbin thread should also be out the back
when you have finished sewing then lift the foot and move the material sewed about 6"" away from the foot before cutting the threads
Nov 03, 2015 | Sewing Machines
I have a Huskylock 936 Serger and used it last week, no problem. I changed the threads for a new product and one thread came out and had to rethread. I know you have to thread the upper looper first then...
Recommend you remove all the threads and rethread from the beginning. ALWAYS RAISE THE PRESSER FOOT when threading and thread the upper looper first, the lower looper second. Sergers sometimes are temperamental about threading. When in doubt, start over from the beginning.
Jun 14, 2017 | Husqvarna Huskylock Computerized 936
How to thread euro pro serger. threads aren'y interlocking
If the thread guide in printed on the side of the door or on the machine, you will need to follow the threading sequence.
Turn off the power.
Raise the thread antenna to it's highest position.
Open the tensions (set at zero). If the serger has automatic tensions, raise the presser foot as this also opens the tensions.
Turn the handwheel so the loopers are at their highest position.
Begin threading from the right to the left - lower looper is usually the first to be threaded.
After threading, set the tensions back to the normal setting and stitch a chain of thread and it should be knitted/interlocking.
Mar 23, 2010 | Euro-Pro Sewing Machines
I own a singer simple sewing machine
By threading part, do you mean the automatic threader? I've never had much luck with them. Yes, you can thread the needle manually.
Happy Sewing!
Feb 04, 2010 | Singer 3116 Simple
How to thread bobbin, insert in machine correctly. Lost manual.
go to link: http://www.youtube.com/watch?v=YL433PhG05c
a vidio is here that will show you the route to follow for your automatic threading to work. You may need to watch it a few times as it is demonstrated very quickly near the begining only once.
Jan 18, 2009 | Baby Lock Esante
Quantum XL-6000 automatic threading system not working
ok it sounds like the theader is bent check to see if the that it is going through the eye of the needle if it is make sure the foot is up so the tenison dics holding the thead this may help .
Nov 24, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Automatic Threading not working
if you damp the end of the thread this seems to cure this
Jan
Leighton buzzard
Jul 02, 2007 | Brother Disney PE-400D Computerized Sewing...
Euro-Pro Shark 80 - 7133 Logo
63 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Greg Cann
Greg Cann
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
