Question about Canon PIXMA iP3000 InkJet Photo Printer
Computer cannot detect printer
OS is Windows XP.... I tried transferring usb ports but its still not working..
Its (the printer) still not being detected. I end up with the error message saying. "Hardware wasnt installed properly there may be problems using this device" .. The other error message is printer not responding.. Then when i let the computer detect the software it says software coudnt be found even with the installation disk...
  • Raoul Recto Jun 21, 2008
    It was a busted USB cable and I had to download new drivers. Thank you so much for the big help. Both complemented the other.......
    Problem Solver:
  • 14 Answers
Ok, also try another USB cable... the printer is not being recognized by the OS as a printer, it might be that the file usbprint.sys might be corrupted. Try to install the printer to another computer with the same OS and see if the OS recognizes it as a printer. Also use the same driver CD that you've used. This is just for isolation. If the printer is recognized by the computer and the drivers are installed correctly, then the problem might be the file mentioned above.
Posted on Jun 18, 2008
  • 197 Answers
Ok..
remove all software from computer for printer
go to www.canon.com and get new drivers by model and operating system
re install
try it again.
Posted on Jun 16, 2008
Bought dongle E173 works on dell computer Xpworks on laptop windows 7 but wont install on PC Specialist windows XP why ????
Hi there! If the E173 worked with your windows 7 then that means the E173 is working properly, try to check first if the PC specialist windows XP computer can detect the dongle if not then try to use a different USB port now if is detected but won't install try to find it in the drive go to my computer then look for the removable disk or the e173 then manually install it but if after trying different USB ports and the dongle is still not being detected then check if it is compatible with that computer or you can try to use another USB device to check if the ports are working properly.
Hope this helps!
Sep 01, 2011 | Microsoft Computers & Internet
How do you get videos off your samsung vs80 12.2mp?
You have to transfer them to your computer, which you can do one of two ways. You can use the usb cable to connect the camera to a usb port (windows will auto-detect your camera), or you can use a card reader to transfer your videos to the computer via the usb port (some printers these days have card readers on them, and windows will auto-detect them when you inset them with the printer on. Hope this helps.
Apr 08, 2010 | Cameras
Purchased a belkin easy transfer cable. When
One of the most common problems is the computer's operating system not recognizing the cable's drivers. This is most common with non-English operating systems. The quickest solution is to download the most recent driver.
If the Easy Transfer Cable isn't working properly, you can try a few things to fix the problem. Make sure that you have installed the Easy Transfer Cable drivers on your old computer with the CD that is included in the cable package. If you did not do this, close Windows Easy Transfer, insert the CD that came with the Easy Transfer Cable into your old computer, and then follow the instructions on the screen. When this is complete, begin the transfer process again.
USB ports might be another cause of the problem. When Windows Easy Transfer asks you to connect your computers with the Easy Transfer Cable, try plugging the cable into other USB ports on your computers.
A more complex problem involves the F5U409 USB PDA Adapter (The USB/Serial Portable Adapter) not installing properly. If the driver is unzipping, but the unit is not working, you need to manually update the drivers. They should all unzip to a file called F5U109 in the C: drive of your computer. Point to this file through the Device Manager to update.
Hope it helps.
Mar 21, 2010 | Belkin Easy-Transfer Cable for Windows XP...
MY PASSPORT ESSENTIAL WD1600ME-00 is not recognized by plug-and-play in either of my HP Desktop Windows computers (One with XP, one with VISTA). Power light comes on when attached to any USB port. Device...
You run MS Windows Update to download and install the latest OS updates. Your WD external HDD should be detected after OS update.
For non updates system, try to connect WD to the USB Port where it worked before. If you have 4 USB ports for instance, try to connect it to these ports one try at a time. Windows XP might have assigned one USB port for your device before when it was working just fine.
Feb 02, 2010 | Western Digital WD Passport 250GB Portable...
Asus p5kpl-am in USB and Sound not detectiing
try to make an adjustment on your bios i think usb is disable try to enable it and sure all your usb will work.
Oct 12, 2009 | ASUS P5KPL-AM SE Motherboard
Windows is not detecting usb mouse and mouse is not working
which OS you have..? xp/2000 , both OS not need USB driver but auto detecting.., i request you to try another usb socket.
Jun 28, 2009 | Lenovo IdeaPad S10-1211U Netbook
Camcorder not detected by my computer
I had the same problem with my Canon HF S11 camcorder and found the solution was to connect the usb cable to the back usb port of my computer. Imagemixer then detected the camcorder to transfer videos. Hope this helps.
May 04, 2009 | Cameras
CANNOT TRANSFER AUDIO FILES FROM WS-100 OLYMPUS VOICE RECORDER TO PC (Windows XP)
I wrote this for the Olympus VN-3100PC although it may work with this device as well.
Try this:
This problem can typically be solved by unplugging the device from your computer's USB port and plugging it in to another USB port on the same computer.
Also be sure you have Olympus Digital Wave Player installed and open with your Transfer Options set to Auto Transfer. To do this, follow the steps below:
Open Digital Wave Player > select Transfer from the menu > select Transfer Options > under Auto Transfer, check the box which reads "Transfer all audio files after detecting Recorder."
Mar 04, 2009 | Olympus WS-100 Digital Voice Recorder
A vista OS is failing to detect lexmark 8300 via USB port When i plug a flash or another usb device on the same port it plays i tried to reinstall the drivers but they cant work. what could be the problem...
ok.....
  • click the start button.
  • type "services.msc" in the run bar.
  • Allow it through UAC.
  • now search for an entry called "print spooler
  • double click it
  • in the startup type type select "automatic".
  • restart system
  • this should fix ur problem.
Jan 13, 2009 | Microsoft Windows Vista Ultimate Edition
CL51-15 USB Port Problem
I have the same problem with the USB's not working. Suppliers say Motherboard problem. solved it by purchasing a PCMCIA to USB port. at least i now have 2 USB ports. you could probably get one with 3 ports.
Kevin S.A.
Sep 26, 2008 | ASI CL51-15 Notebook
Canon PIXMA iP3000 InkJet Photo Printer Logo
173 people viewed this question
old marine
old marine
