Question about Aiwa HV-MX100 VHS VCR
Trouble recording and playing NTSC tapes on NTSC TV!!
I never had this problem before. Nothing has changed! I used to be able to play & record PAL & NTSC videos with my VCR but now, all of a sudden, I cannot see anything (just black & white fuzzies) and if I hit the Menu button and pull up the blue menu screen, I can hear the audio but can't view anything!
Heeeeeeeelllllllpppppppppp!!!!
    Novelist:
    Champion:
  • 254 Answers
Sounds like the video head is dirty. Take the top cover off VCR, locate the video head, which is the rotating shiny aluminum cylindrical piece. At the lower edge of this drum are the actual heads. Use a lint free cloth moistened with rubbing alcohol or product specifically designed for such cleaning, and carefully wipe the heads and drum. Just hold cloth over a finger, and rotate the drum. Sometimes you will need to do this a couple of times.
If VCR has alot of hours or an abrasive cleaning tape has been used excessively, the head could be worn out and a candidate for the trash, unless it is a high dollar unit.
Posted on Jun 12, 2008
Honestech tvr video recorder
The Color subcarrier is different on pal. NTSC tapes , cameras, VCR's will all show B/W on a NTSC TV.
May 09, 2013 | Fulltone Ruby GrabBee Deluxe USB 20 NTSC...
Picture rolls on playback
Try cleaning the heads, but it seems like the heads may be faulty, you might need to replace the vcr, they don't cost much these days, the repair might cost more than a new vcr these days.
heres a cheap headcleaner, look for one at local shops, wallmart bestbuy and so on
http://www.pcconnection.com/IPA/Shop/Product/Detail.htm?sku=7632166&oext=1038A&ci_src=14110944&ci_sku=7632166
Sep 24, 2008 | Panasonic PV-V4021 S-VHS VCR
Can I use Hi8/Digital8 NTSC tapes in my DCR_TRV250E?If so would I be able to playback recorded tapes on the UK televisions?.
DCR-TRV250E is a PAL version camera of the Digital8 format.
Yes you can use Hi8/Digital8 NTSC tapes. The camera will record a PAL digital picture on the tapes which means that you can play back the tapes in PAL and therefore you will be able to playback recorded tapes on UK televisions because they are also of the PAL format.
Oct 10, 2009 | Sony Handycam DCR-TRV250E Digital...
Converting NTSC home Video tapes to Pal DVD or NTSC DVD
You need either an NTSC DVD recorder (keep in mind that the US has 110 voltage, while Australia does not), or a computer card that supports NTSC. Some video capture cards support both NTSC and PAL (often switchable). Choose good quality, and pay attention to video/sound sync - some bad quality cards loose sync. Once the tapes are transferred to DVD - and keep it native NTSC all the way, they can be played on virtually any PAL DVD player/TV combo. With an NTSC source, it's best NOT to convert to PAL, while with a PAL source in the US, you'd need to convert to NTSC or only show the DVD on a computer (where NTSC/PAL doesn't matter).
Feb 19, 2009 | Panasonic DMR-ES35VS
When I try to play PAL tapes, there is no picture
You also need a PAL television or monitor to be able to view them. If you don't have a PAL compatible monitor or TV it will not work because the resolution and scanning is very different than an NTSC monitor. Your canon camera is probably designed only for NTSC use if it was sold in North America and can't be used for PAL use.
Jul 31, 2008 | Sony DSR-11 DV / Mini DV VCR
Black and white playback with sony handycam dcr-hc20
There is no problem on your camera, DCR-HC19E is PAL system(European system) DCR-HC20 is NTSC(American system). Are you in US or Europe? I think your TV is NTSC, cause the tape recorded on DCR-HC19E you played has no color. To confirm, connect your HC20 to TV in camera mode, not recording yet, just look at the TV as your monitor, If its in color, no problem, just erase the old video recorded on the HC19E, but if its important to you, you can convert it to NTSC using a PC. thanks
Sep 12, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
Pal to NTSC
Hi, Based on your post/description, you need to get a multi-system TV to go with your multi system VCR if you are going to playback VHS tapes from different regions. You are quite correct "Plays NTSC tapes to NTSC, Will not Play Pal to NTSC" to play PAL (even Secam) you would need a PAL/Secam TV. They have a different system for color and audio. In some cases, you can still play PAL but you get it in black & white and picture squeezed from top & bottom. Hope this be of some help to you. Good luck and kind regards.
Aug 22, 2007 | Samsung SV5000W VHS VCR
NTSC to PAL
You have to buy first a VHS player that can play NTSC, might not be available locally in Ireland so you have to probably buy online (US). The DVD recorder is fairly comnon nowadays and all of them are capable of recording and playing NTSC and PAL. You can then connect the AV out of VHS player to the AV In of the recorder. Or you can use a VHS-DVD combi. You can google in UK, here is an example: Toshiba RD-XV45, according to the specs, it can play NTSC on the VHS and you can record to DVD on any format that yoou want You can go to this link to view other product: http://audiovisual.kelkoo.co.uk/b/a/sbs/100304323/16875665.html My father died of cancer 6 years ago and I am also transferring the Hi-8 videos to digital format using PC.
May 23, 2007 | Samsung SV5000W VHS VCR
VCR not working for some cassettes
What do you mean by "not able to play my VCR with some cassettes. " Is it that some tapes do not display images? No Video? From your name it seems that you are from India, Assuming that to be so, I also presume that you must be possesing a Multi-System VCR, to play back PAL Tapes from India, and NTSC tapes from the US. And if that is the case, I guess it is a simple problem of resetting the System standards. Please go to the Main menu of your VCR using the Remote, and select AUTO in System (You will be given choices of AUTO, PAL, NTSC 3.58, NTSC 4.43 and NTSC PB PAL. Likewise, it is entirely possible that your Television SYSTEm Standard has been accidentally changed. If it is Multi System TV, Then, again, using the Remote of the TV, select Menu, and then select AUTO in System. In all likelihood your problem should get solved.
May 13, 2007 | RCA VR605HF VHS VCR
Jvc 200u problem recording to vhs video tape, from camcorder
Yes, if the camera is a US camera then it is NTSC. That would be your problem, you are trying to record an NTSC signal to a PAL video. THe frame rates and resolutions are all wrong. I am even surprised that it is playing back on your TV okay...
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Aiwa HV-MX100 VHS VCR Logo
147 people viewed this question
Top Aiwa Televison & Video Experts
romy sibug
romy sibug
 Grubhead
Grubhead
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
