FixYa.com
Tags:
Gateway FPD1960  19 in. Flat Panel LCD Monitor
Erratic display (by 3 users)
posted by cnb382000 on Jun 11, 2008
My display was dark when I returned home. After turning it on and off a brief flickering image appeared then the display turned dark. The computer works fine with another monitor. Turning it on and off brings up a brief flickering image, but it only lasts a second or so before going dark.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by martinezlen, posted on Jun 25, 2008
when I turn on computer the monitor goes on for a second and says "input analog" and then goes black. I have double checked all connections.
Comment by reble, posted on Jun 14, 2008
have a Gateway flat screen monitor model 900G. When I plug the flat screen in and turn it on. the screen will come on just fine for a minute then go dark. the monitor power light stays on but the screen is blank. I can ether push the power button off and on or hit the input button on the side and the screen will come up normal for a minute then go blank agen.
Best Solution
posted on Jun 11, 2008
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
it sounds like a blown cap.. you can replace it if you know how to soder
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Monitors problems?
Gateway FPD1960 (Silver) 19 in. Flat Panel...
Power Board
How much for a power board and... Answer This...
dead or ?
my monitor started showing... Answer This...
Gateway FPD1960 bad power...
I saw your previous posting... Answer This...
Gateway 19 in flat monitor...
My monitor won't turn on. Is it... Answer This...
3 prong power cord and dvi-usb...
I need to know where can i find... Answer This...
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
