Question about Philips Magnavox 51MP392H Rear Projection Television
Convergence problem Hi, I read your thread desciption of the repair job. I just wanted to confirm that you have the model 51MP392H/17 so that I get the right ic's. I have this model and am experiencing the same problem. Thanks for your help
  • Philips Master
  • 8,617 Answers
Your model uses two STK392-120 ICs but you will also need at least four convergence resistors which are 6.8 ohm 1 watt metal film as that model will burn at least two often four of the resistors when the ICs go out. You can get replacement ICs at the following link with free instalation instructions and free on line tech support when you do the repair. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jun 15, 2008
Magnavox tv model 51mp392h/17 words on the bottom are double one set is red other set is green
Thats caused by failed convergence ICs and the 6.8 ohm resistors. You can get the repair kit called the DPTV305 -DPTV345 & MAG01 chassis convergence repair kit which fits your model. The kit has the components and the CD with repair instructions and its available at the following link top of the page. http://tvrepairworld.com/phillips__magnavox_repair_kits
Apr 09, 2013 | Philips Magnavox 51MP392H Rear Projection...
My 48 inch Magnavox HD is showing double Model #: 51mp392h/17
If it looks anything like the picture (3D etc) it will need the "Convergence circuit" repaired.
Let me know if you have questions.
Feb 26, 2012 | Philips Magnavox 51MP392H Rear Projection...
Magnavox
Need more info, does it click on and off, make any noises, was the picture going blurry, did you just move it, was in built into a wall where it wouldn't get air to cool???
Here is what I know about the 51mp392h this is a general post below I used for some other peoples fixes without more info on yours I suggest reading thru the below and links and add more info to your post so we can trouble shoot it.
51MP392H/17
Actually I have this TV and you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted pictures on, check out page 3
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/
Where I got all my parts that worked:
Suburban Electronics http://www.suburban-elect.com/
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
What you need:
(2) STK392-120 OR STK392-150 IC chips
(12) 6.8 Ohm Metal Film resistors
set of star screw drivers
15 watt pencil solder pencil, DO NOT use a high watt iron you will fry the surface mounted item.
good leaded solder, and flux
BTW if you don’t plan on trying this and are going to throw out the TV, I still need a IC convergence board for a 51MP392H/17 TV I'm fixing, I'm willing to pay S/H and buy your IC board that’s not been tampered with. Edwinkraus@hotmail.com
Nov 16, 2008 | Philips Magnavox 51MP392H Rear Projection...
Red and green lines on picture only in the corners of the pic
YIKES, I dont know about Coolant changes but I'll post my general post about the 51MP392H/17
it has links to the SERVICE MANUALS and info to other sites that might help...
GOOD luck
General post....
51MP392H/17
What you need:
Nov 13, 2008 | Philips Magnavox 51MP392H Rear Projection...
No Picture No Sound Magnavox Rear Projection Television
51MP392H/17
What you need:
Nov 11, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips rear projection tv-wont turn on
Sounds like your Convergence chips failed, were your red/blue/green colors slowly seperating or was the picture starting to curve on the top or bottom or both? if so see below general post.
Also what model # is your TV and what size?
51MP392H/17
What you need:
Nov 02, 2008 | Philips Magnavox 51MP392H Rear Projection...
51mp392h/17
You need to replace your STKs Big black ICs 392-020 replace both of them also check 2 resistors 2,7 ohms they may be open.this is a common repair iob.
I have a magnavox 51mp392h rear projection tv and im having problems with the convergance
51MP392H/17
Where I got my parts that worked:
What you need:
chips
Oct 05, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 51MP392H -- Multipoint Converge blue faded around edges
hey guys here is a great thread on this subject, its were I posted most of my pictures and there is a link to the manual in there. hope this helps,
BTW, IF ANY OF YOU GIVE UP ON YOUR 51MP392H/17 PLEASE LET ME KNOW!!!! I WANT TO BUY YOUR CONVERGENCE BOARD... "I killed mine" edwinkraus@hotmail.com
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/?page=1
Sep 29, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox 51MP392H/17
yes youre model will need two convergence ICs they are both STK392-120 and you will also need some 6.8 ohm resistors usually two or four resistors will need replacing as well. The site servicemanuals do have all the parts and they do provide free installation instructions with the ICs.
Sep 03, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
27 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
