Question about SanDisk Sansa m240 MP3 Player
Sansa MP3 Was working. Turned it off. Went to turn it back on. NOTHING ON SCREEN. Blue circle lights but nothing on screen. Plugged it into USB, nothing showed, such as CONNECTED ... Left it plugged, MP3 got very, very hot. HELP ... thank you!
  • 8,596 Answers
Very hot = not good - replace the player
For laughs, Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jun 13, 2008
My SanDisk 4.0 will not turn on. I plugged it into the computer to add music and the blue circle light is on but nothing else works. The light will not turn off either.
Try to reset your SanDisk Sansa as follows:
1. Press and hold the Power/Menu button for about 20 seconds. 2. Release the button. 3. Press the button again to try to turn it on.
Mar 02, 2011 | SanDisk Sansa e260 MP3 Player
My sansa fuze 8gb won't turn off the screen is blank but the blue light around the wheel is sitll lit. When i tried to plug it into my computer it still did nothing. i just bought this 2 months ago and am...
You should be able to hold the power button (as if you were turning it on) for 20-25 seconds, which will shut it off completely. It should work as if nothing happened when you turn it back on again. Hope this works for you!!
Jul 10, 2010 | SanDisk Sansa Fuze MP3 Player
Sandisk Frozen Pale Blue Screen
Having received no response in over a month, I assume this is no longer a problem.<!-- from fixya rte -->
Jul 05, 2010 | SanDisk Sansa e260 MP3 Player
My m3 player froze while charging and now it wont turn on
I held it in the off position while at the same time pressing the menu shut off, then I restarted it. It will repair the media itself.
Jun 26, 2009 | SanDisk Sansa e250 MP3 Player
Nothing but the blue ring lights up
ok..idk if this will work but it might...first turn off the sansa...then turn the hold switch on (it should turn red). hold down the record button on the side of the player..then while still holding that hold the power button down...but keep holding them untill a screen shows up saying something about recovory mode..itll say to plug in the usb..u could do that..idk it that will it doesnt instead of plugging in tthe usb in the computer..wait about 15 seconds after the recovory mode screen shows up and then hold down the power button for about 15-20 sec...then itll go all black (including the blue light) press the power button again like u would to turn it on...and everything should be back to normal..hope this helps...:)
May 04, 2009 | SanDisk Sansa e250 MP3 Player
The screen on my sansa e260 wont turn on
hold down the power button for 15 seconds and it shoud reset the whole player
Dec 28, 2008 | SanDisk Sansa e250 MP3 Player
Frozen mp3 player Sansa Sandisk 6.0 gb
Have you tried taking out and reinserting battery? That worked for me.
Jul 14, 2008 | SanDisk Sansa e250 MP3 Player
My sansa e260 doesn't even turn on
Had the same problem, blue light no screen, took the cover off found a small black rectangle block not completely pushed in. the block is located on the right center on the part above the battery and right behind the screen.
Jan 12, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e200 won't turn on
Load main image failed refers to a bad firmware file on the device. You can download and run this recovery tool from the SanDisk website. Best of Luck.
Sep 07, 2007 | SanDisk Sansa e200 MP3 Player
Went off, the light on the circle button went on an nothing else
Press and hold the power button for 20 seconds to "reset" the device. If that doesn't work, you can call Technical Support to resolve your issue.
Sep 01, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
