Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
1200 Sportstart won't start, just clicks.
Bike sat in garage all winter and battery was dead. Charged it and it started for a couple days then nothing. Put a new battery in and still just clicks. What am I missing?
Thanks for any help.
    Problem Solver:
  • 9 Answers
Sounds like something is hanging or froze up or the starter/solenoid contacts need to be cleaned or the battery cable connections at the frame ground and starter are either loose or corroded and need to be cleaned or maybe a wiring harness plug has corroded over the winter and needs to be cleaned.
Posted on Jun 11, 2008
Can't start my Honda CB400-Four 1997. Battery seems to be ok. Could it be the Regulator/Rectifier? It has been lying up over the winter. It did start a couple of weeks ago, cut out and hasn't
if the headlight dies right out when you crank the motor then the battery is usually dead. It may read on a voltmeter that it has 12 volts but that does not necessarily mean the battery is charged.Have the battery checked and charged properly then try and start the bike again.Regards
Feb 15, 2012 | 1997 Honda CB 400 Four
The bike sat for nine months I kept it in the garage and covered but when try starting nothing happens but oil light
Sounds like the battery may not be charged. Put a charger on the battery, bring to a full charge. Try starting. If it won't crank, locate a load tester and check the battery for weakness/dead cell. If the battery is not the problem, the starter/starter solenoid may have corroded/dirty contacts.
Apr 18, 2011 | Yamaha FZ 600 Motorcycles
My bandit won;t start. It had started previously in the winter, however it won't turn over, the battery is fully charged and the tank is full. I have a bit of starting fluid but it does no good if I...
if the bike does not turn over as you describe clean the switch on the clutch and side stand as these can stick which will not allow the bike to turn over.
Mar 08, 2011 | 1999 Suzuki GSF 1200 Bandit S
I got the bike rode for a while it sat for a couple of weeks and when I tried to start it it was dead. I tried getting the battery charged and it didn't work. I got a new battery and that worked for about...
If the bike is losing ALL power, I'm talking about dash lights, headlight, tail light, ALL lights, it's probably something tripping the main breaker. The breaker should be located either under the seat or behind the trianglular panel on the right side of the bike. I'd look for a frayed wire near the starter or around the rear cylinder due to the head in that area.
Good Luck
Steve
Nov 12, 2010 | 2005 Harley Davidson XL 1200 C Sportster...
Bike was sitting in garage. Dead battery. Charged it. Fuses good lights horn ect work. Nothing happens when I press start button. No click. Nadda. Ignition? starter? Or am I way off base? Thank you!
I would have the bbattery tested, bike batteries are prone to just going oopen and u have zero output, it is very unlikely anything else is wrong.
May 21, 2010 | Motorcycles
My suzuki gsxr 750 sat all winter and i didnt winterize it at all. the battery died... i charged it and my bike just wont start. It cranks over just won.t start. What should i do?
check spark plugs,check for spark. check fuel is good. possible needle and seat gummed up in carb float bowl. disasemble and clean with brake or carb cleaner.do not change float level. re assemble ,you can use the cleaner to help to fire the motor with a shot through the carb. make sure you cleaner says flammable. good luck.
Mar 22, 2010 | 2007 Suzuki GSX-R 750
Replaced battery,left key on baterry dead charged 1986 1200gl
If i had this problem, I would find i good battery and eliminate the 'new' 1 from the equation 1st, So try this 1st,
Ian
May 25, 2009 | 1985 Honda GL 1200 Interstate Gold Wing
Won't start without charger on battery.
when you charge the battery make sure that its cable is is loosen from the motor coz it can damage your charging system. on your case you have damage it already that's your light dims whenever you rev the rpm up. so change your voltage regulator of your charging system, charge the battery and it is done easy.
Apr 25, 2009 | 2003 Harley Davidson XL 1200 C Sportster...
The neutral light on my 1997 Honda Magna 750 does not light up.
change the battery then change the neutral saftey switch if the battery does not help
Apr 10, 2009 | 1997 Honda VF 750 C Magna
Lands Phones Logo
167 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
