Question about Lanzar Car Audio & Video
Lanzar optidrive series 4000watts mono block digital compitition class amplifier
I have two subwoofers and on the amp for the speaker conection there is only one positive and one negetive. How do I hook up both of my subwoofers? Do I twist the two positive wires from both of the subs together and the same for the negetive?
Regards,
Sean
  • 2 more comments
  • seanoszal Jun 11, 2008
    The amp I have is a Lanzar optidrive 4000D mono Block.
    1x 2000 Watts rms @ 4 Ohms
    1x 3000 Watss Max @ 2 ohms
    1x 4000 Watts Rms @ 1 Ohms
    It seems that it is only for one subwoofer? One positive and one negetive. How do I conect two subs to the amp?
  • seanoszal Jun 16, 2008
    If I get a set of subs that are Lanzar opti 1234D 750 watts rms and 1500 watts peak, 4 ohm dvc 12 inch, can I put more then 750 watts rms into each one?
    I'm going to get a pair of 12 inch Lanzar opti 1234D 750 watts rms and 1500 watss peak. At 4 ohm dvc..can i run more than 750 watts rms into the speakers? Someone told me that i can run up to 1500rms into each sub and they will be fine and pounding hard? Is this true? I have a Lanzar opti 4000D amp
    O je, I think they are dual 4 ohms voice coils.
Thanks Paul. I'm getting the speakers next week. the ones I had I sold because they where only 550 watss rms ( vibe cbr 12 ) I did'nt want to fry them. I'll find out the name of the speakers maybe tonight and write back. The place where i purchased the amp also have the speakers that where designed for that amp I ordered them and they will not be in till next week but I'll ring them back and get all the specs.
Regards,
Posted on Jun 12, 2008
    Scholar:
  • 71 Answers
Firstly, sorry to to tell you, but their is no such thing as a 4000 watt car amp. Google Ohm's law and RMS .
Check the owners manual or website to find the amps minimum impedance. Usually 4 or 2 Ohms. Next,
check the woofers impedance , If unsure check with a Ohmmeter,
It's actually the resistance,but close enough.
If they are 8 Ohm and you twist those wires together (parallel circuit) your amp will see 4 Ohms.
If they are 4 Ohms (paralleled) your amp will see 2 Ohms.
Do not connect in a series circuit (+ amp terminal to a + speaker terminal and that speaker - terminal to the other speakers + terminal and that speakers - terminal to the - amp terminal) .
It creates phase problems, and sounds like ****.
Most mono amps are really internally bridged stereo amps ,it's cheaper that way, but it limits how low of a impedance they will handle. Read the specs. Use the correct size connectors, scrape off paint for a good ground connection.Use the right gauge wire and above all. Fuse that power lead at the Battery!!!!!!!!
ps . if you have dual voice coils thats another chapter.
Good luck, Sumthin
Posted on Jun 11, 2008
  • Paul Hering
    Paul Hering Jun 11, 2008
    Hi seanoszal,
    I need the specs. on the speakers if they are double voice coil.
    ( the impedance of each voice coil.) If they are single, see below.
    Your amp is capable of running eight, 8 Ohm speakers at 1 Ohm, wired in parallel.
    Or four, 4 Ohm speakers at 1 Ohm, again in parallel That is assuming that all the speakers are single voice coil.
    Anyways, two 8 Ohm speakers in parallel will be 4 Ohms and Two 4 Ohm speakers in parallel would be 2 Ohms.
    Any further questions, Let me know
    Regards, Paul
  • Paul Hering
    Paul Hering Jun 17, 2008
    Hi Sean,
    You know have a few choices,
    Remember I said you shouldn't wire speakers in series.
    Great news, it does not apply to voice coils.
    Here's what you can do...
    If you parallel the voice coils each woofer will be at 2 Ohms.
    Parallel the woofers and you will have 1 Ohms, 4000 w
    Series the voice coils and each woofer will be at 8 Ohms.
    Parallel the woofers and you will have 4 Ohms, 2000 w
    Try them both way's and see which you like better.
    Use 12 gauge wire for everything and buy terminals large enough to accept the wire.
    Let me know more about the enclosure, home built?
    pre made? or did the shop build it ?
    3/4 MDF I hope,
    The next step will be to seal, and stiffen the enclosure,
    properly.
    Send me the speakers recommended enclosure size.
    and I'll tell you how to make that thing bang better, without losing power due to box construction.
    Glad you finally got them.
    Remember at those levels, they will cause permanent hearing damage. But the chicks dig it, and you learn to read lips ( lips are good ).
    Regards, Paul
How can I connect 2 15 (inch) Lanzar maxp15 subwoofers to a Lanzar 3000 watt 2 ohm mono block amp?
You need to find out the voice coil ohms and if you have 1 or 2 voice coils in each sub and then wire accordingly.
Apr 15, 2016 | Lanzar Car Audio & Video
Is a boss ce2800 amp a good amp it says its 2800 watt class d mono block
It's over rated on it's specs and they run real hot when working hard. Make sure to located in an area with good air flow and away from material that may melt.
Nov 15, 2013 | Car Audio & Video
My Lanzar Optidrive plus has a green light and a red light. I assume this is a sign of safe mode. normally it is just green. How can i get it back to normal and in working order. I already tested other...
your output of the amplifier have been distorted. I suggest you take this to a reputable service technician that has experience with lanzar OptiDrive old school Rockford Fosgate or Orion. These technicians are hard to come by nowadays but they definitely are worth the money that they charge. I happen to be one of those such technicians.
Nov 15, 2010 | Lanzar OPTI 50c Car Audio Amplifier
How do i install 2 ckicker cvr to my amp
Here are a couple of diagrams 2+4 ohm dual voice coil wiring.
Option 1 (parallel/parallel) = 1 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono 2_4ohm_dvc_1ohm.gif
Option 2 (series/parallel) = 4 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif
Option 1 (parallel/parallel) = 0.5 ohm load
Recommended Amplifier: Stable at 1/2 ohm mono 2_2ohm_dvc_05ohm.gif
Option 2 (series/parallel) = 2 ohm load
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_2ohm_dvc_2ohm.gif
Option 3 (series) = 8 ohm load
All voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif
Apr 12, 2010 | Kicker CVR12 Car Subwoofer
How do i install my L5 solo barics to a 2 channel amp if there is only one connection on the enclosure next to the vent? If I bridge the amp to 1x1000W will the power distribute evenly between both...
Option 1 (parallel) = 2 ohm load
Speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_4ohm_svc_2ohm.gif
Option 2 (series) = 8 ohm load
Speakers wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_svc_8ohm.gif
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif Option 1 (parallel/parallel) = 0.5 ohm load
Apr 09, 2010 | Kicker Solo-Baric L5 Car Subwoofer
What is the rms for a single max12d lanzar is it 500rms or 250rms
Description One of the oldest and most respected names in automotive sound is also one of the most consistent winners on the competition circuit. Lanzar offers a wide range of high performance subwoofers, from the pounding OptiDrive Series to the rugged MAX Series. The MAX12 dual-coil subwoofer offers high power handling, great bass response, an economical price, and a 3 year warranty. Specifications: *Power handling: 500 watts RMS/1000 watts peak *VCdia: 2" *Impedance: 4 ohms per coil *Magnet weight: 130 oz. *Fs: 33.6 *SPL: 88 dB 1W/1m *Vas: 3.19 cu. ft. *Qts: 0.47 *Xmax: 10mm *Dimensions: A: 12.09" B: 11.15" C: 6.42"
Oct 27, 2009 | Lanzar MAX12D Car Subwoofer
Speakers stopped playing
if the speakers are wired in series, if one goes out the other one wont play either. series is when one wire of first speaker goes into amp, then the other wire of first spkr is connected to one of the wires of second spkr, then the other wire of second spkr goes to the other conection on the amp. kinda like forming a chain. use a 1.5v ( AA, AAA, C-CELL)battery to check your speakers. connect one wire to + side and the other to - side of battery. they should move either in or out. if they move they are still ok. this wont cause them any damage. i use this method all the time to check for spkr polarity.
Oct 21, 2009 | Pioneer 800W Class-D Mono Amplifier With...
How to wire 2 opti1533d by lanzar with the optidrive 2000d amp? how do i wire them if i put 1 amp on each sub
your speakers are 1 ohm per voice coil, dual oice coil. your amp is no lower than 2 ohms stable mono.
the proper way to wire this so that you do not burn out the amp is to run the 2 vioce coils in series. run the positive lead from the amp into the positive lead of one of the voice coils, then run a jumper wire from the same voice coil's negative lead to the same speaker's 2nd voice coil's positive input. then run from the 2nd voice coil's negative back to the amplifier's negative speaker lead.
you will be running for each speaker/amplifier set: amp + to terminal set 1 +, terminal set 1 - to terminal set 2 +, then terminal set 2 - to amp -
Oct 06, 2009 | Car Audio & Video
Car system
if you have dual voice coils connect on each seporate sub negative left channel to possative right channel of the subwoofer same to other sub then conect the left possative and the right neggative to your box power terminal same to other sub then conect the two sub outs on your box left speaker positive to your positive left channel bridge then conect left speaker negative to the right speaker possative then connect your right speaker negative to your right channel negative brigdeg to your amp is single coil hook the box its self up the same way to your amp i have two dual voice cooil 12" hooked up to the same amp that way and it rocks without the power protecter turning on
Nov 09, 2008 | Pyle PLA2200 Car Audio Amplifier
Car Audio & Video Logo
985 people viewed this question
Top Lanzar Car Audio & Video Experts
Joe Alexander
Joe Alexander
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
