Question about Dynex DX-SC5.1 Sound Card
Mic will not word sc5.1 win xp pro
hello , I have a sc 5.1 sound card works with spks./.......opened properties for win sound turned mic on unchecked mute button but no soud from mic.Mic works great on 4 other computers using buitin ports on mtbd.
check device mgr - ok
check all ports on back of dynex ? no worky ? mic prob only
help expert it user ubt not on sound cards
  • Anonymous Jun 11, 2008
    having macbook loaded with windows xp os. mic not working but speakers do work. how to get the mic going
  • Anonymous Jun 29, 2008
    yhrye
I fixed mine already.First jack at top solution was to
reconfigure settings for sc51 in control panel-sound. voice and audio
I am still the man
tech support was completely useless as is this email....not listen not a driver problem.
Posted on Jun 12, 2008
  • 53 Answers
Sound like driver problem
Not voice coming & going
Hello
In control panel.Go to sound .Once there open your speaker properties then go to level tab.To the right is a list.Scroll down to mic and turn it up.
Then go to recording properties.Custom tab.Check box for 20db boost.
Mic should work now.
Sep 17, 2011 | Creative Labs CT4870 / CT4780 Sound Card
Hp compaq dc7600 front panel 3.5 mm jacks not working so no mic and headset and my os in win 7 x32
That can either be a software or hardware problem. Please check BIOS and Sound card drivers to see if the front Headphone and mic jack are enabled. (right click computer ->properties-> device manager) or start programs -> realtek (depending on sound card)
Was it ever working before and do the plug in the back work for your computer?
May 06, 2011 | HP Compaq dc7600 Convertible Minitower PC...
Got an acer aspire 5517 and the build in mic is not working how do i fix this?
All I can think of is maybe it's muted? Anyway, Go to, control panel>sounds devices> goto the, Mic tab and then "enable" it.
if using windows xp or higher then you can see it ...in your Taskbar... and also goto "Sound Device" & from there, find "Mic" tab & uncheck the "Mute" button or raise the volume etc ...
Feb 07, 2010 | Computers & Internet
HP a1030e will not recognize sound device after reinstalling XP Pro
FRONT MIC NOT WORKING BUT BACK MIC IS WORKING
AND FRONT SPEAKER IS WORKING BUT BACK SPEAKER IS NOT WORKING
Jul 01, 2009 | HP (400745-001) Sound Card
SOUND IS DISTORTED.NOT TRUE ACCURATE SOUND
check ur mic in volume control its may be on boost mode
Volume.>>>>>>mic>>>>>>property>>>>>boost>>>>uncheck it
Jan 31, 2009 | Acer Computers & Internet
Microphone does not work
Hi doug810, if your sound is working your mic is most likely working too. It just needs setup. Open control panel. Than open the Sounds and audio devices icon. Click on the Voice tab in the properties window. Click the test hardware button & follow the on-screen prompts. (Win XP systems).
Good luck doug810!
Mike
Jan 13, 2009 | Computers & Internet
I can't configure or access my flexijack on Creative Labs Sound Blaster X-Fi Titanium Fatal1ty Pro Series Sound Card
well the ports on the card could be shot and the card might have been installed by a person with a static charge built on thier hands without them knowing, which can cause the card's electronics to fry and be ALMOST completely disabled. try using a different mic or taking the card out and re-installing it.
Oct 14, 2008 | Creative Labs Sound Blaster Live! 5.1...
Inbuilt microphone is not working for C765TU win xp
hello
if you want see rest volume drivers klick on options, properties
Aug 28, 2008 | Compaq Presario 700 470024-192 Notebook
Inbuilt or external microphone is not working for C765TU with win xp
Ok this could either be simple or complicated depending on what the actual problem is. Firstly if you have a sound icon on your windows taskbar (Bottom right beside the clock) double click it
It will open the Volume control.
Top left of this window, click on options and then click properties. look at the list below and make sure the microphone is checked, if its not then check it.
Now look at the volume control window and make sure that your microphone isnt muted, just uncheck the mute button set the volume half way and you are done.
If you dont have the sound icon on your taskbar, goto start then control panel, click on Sounds and Audio devices, Note if you dont see this then on the left hand side click on the classic view to show all control panel options.
Click on the volume tab, click advanced and then do the steps above to enable the mic
Then click on the audio tab Look down to where it says Sound recording and make sure it has a default device in there. that should fix the problem.
Now if you do this and you dont have a default device or no sound card then let me know and we will get the problem solved
Aug 25, 2008 | Compaq Presario 700 470024-192 Notebook
My mic doesnt work
to put that in cam microphone working, you need to see on audio settings properties and change the "recording device" to usb audio device, instaid of the soundcard as is. That means that the sound recording will be from the cam's microphone.
The steps are:
1- rigth mouse click on the speaker next to the clock OPEN VOLUME CONTROL
2- OPTIONS - PROPERTIES - RECORDING
3 - in MIXER/RECORDING DEVICE (where is your soundcard's name) change to USB AUDIO DEVICE and then OK
4- In the remaining volume control window, select MICROPHONE and then close all the volume control windows
5- you can test the mic settings in messenger (any version) because of volume and to a clearest voice sound in your pc.
ATTENTION: carefull with the distance between your cam and your sound speakers because of distorcing sound and feedback
Jan 23, 2008 | Logitech QuickCam Fusion Webcam
Dynex DX-SC5.1 Sound Card Logo
106 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
