Question about Dishwashers
Maytag, Quiet Partner II. Top water wheel is not getting does not get sufficient water pressure. Without sufficiant water proessure the water wheel won't spin, without the spinning effect dishes on top rack do not get clean.
  • mctp Jun 11, 2008
    Bottom rack gets clean, top rack and utensils do not. Spary arm are NOT CLOGGED, food is obviously trapped in the filter, very difficult to clean the filter
  • 868 Answers
Motor-Pump Drive assembly is defective.Hey while you have this machine apart pull the drain pump off and look for a jammed flap,it's rare but check it anyway.(to remove the drain pump just twist it and pull it off).For the non believer's out there ,this will be a learning experience.You will NOT resolve this "not clean dish" problem unless the Motor -Pump assembly is replaced with the one they now make that works. THIS to some repairman was called POWER DRIVE ASSEMBLY. Quick note: motor - pump does NOT include the drain pump.Think about that for awhile.Any way the drain pump will not be the problem,the Motor-Pump is!
Posted on Jun 11, 2008
Whirlpool quiet partner ii dishwasher has quit working. Power is getting to the dishwasher but it is not coming on at all. There is water standing in the bottom of it and a very foul smell is present.
This dishwasher has a thermal fuse that attaches to the main control board that may have failed, it can be tested with a meter for continuity if it does not have continuity then it is your problem.
Apr 21, 2012 | Whirlpool Dishwashers
Quiet partner 1 top rack does not get clean at all
I would suspect you have debris in the pump that is causing a pressure drop so the water is not spraying well in the upper arm.
Try this procedure to clean out the sump. Let me know if it helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Apr 24, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
I have a whirlpool Quiet partner II. It will not fill w/water.
ck the float in bottom of tank . it may be stuck n the up pos .. moce it up and down and listen for click of the sw .. very common . also the water valve may have failed and it will need replaceing . mm
Dec 07, 2009 | Washing Machines
I do not seem to get sufficient water pressure in the machine.There is sufficient pressure at the faucet adjacent to the machine. Is there a filter that could be removed and checked for debris in the water...
there is a screen in the water control valve try disconnecting water line at the d/w with water turned off after line is off get a bucket and turn water on to see if there is good pressure if there is good pressure I would say it is the water control valve
Oct 29, 2009 | GE 24 in. Profile PDW7800 Built-in...
Washer not fill sufficient water
the inlet pressur water is the secret
follow the input inlet hose, the input filter,the solenoid valve.
it is a good job thanks
Jul 09, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
I have the Whirlpool Quiet (??) Partner II. My
Have this same problem with my Whirlpool DU1145XTBA. Found out that when you start the unit, it fills with water. If the water does not rise above the filter mesh in the bottom center of the unit then the pump doesn't have enough water to supply pressure to the upper sprayer. Had to replace the Flow Meter. It tells the unit how much water to supply to the unit.
Apr 12, 2009 | Dishwashers
Whirlpool Quiet Partner II not washing or sensing.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
Nov 16, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishes not thourghly cleaned on top sheelve
generally dishwashers rely on the pressure supplied by the water supply line. check to see if it is enough or if inlet pipe is of sufficient diameter for needed flow.in some instances i know of seperate lines needing to be run directly instead of coming off of supply to sink area.
Apr 07, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
371 people viewed this question
Top Dishwashers Experts
