Question about EliteGroup Computers & Internet
Bios Setting I have the elitegroup motherboard p4mpro800-m bios version AMI 2.56 512 nvidia 7600 graphics card apg 8x, 1.5gig ddr 400mhz memory, 3.0gig duo processor and vista basic sp1. Once in a while my pc crashes and at first i thought it was hardware but now i believe is the bios setting. It is an out of date bios from 1995-2005. so the auto settings require some manual setting change to optimize its perormance.the games play great and do not lag or crash. But i do notice that when installing new software such as a game, it loads slowly and slugish and creates error.it will give me a retry to install fille for it to load. after 1 or 2 errors the game completes install succesfully. Ready to play. usually after an install it will crash. only once in a while it crashes when closing an aplication like a web browser. never crashed after closing a game.could you give me some input what to set my bios for my video card and memory ect....
  • 1 more comment
  • Leader_Cross Jun 11, 2008
    Yes i checked The hard drive.Originally i had 250 gig EDIE hard drive. I thought my hard drive was bad. So i replaced it with 500 gig sata hard drive,since my board is set up with SATA. But here is the thing, Before i installed windows SP1 update I did increase the ddr ram voltage. It made a difference. Loading software such as games installed great with speed and no error. But since Vista Basic has tons of issues, I installed the Vista SP1 which fixed a lot of performance errors.And it did. Once in a while i will get the memory management error or some other blue screen when closing an application, but not as often as i did before. So any way. I triyed boosting the voltage on my memory assuming that lack of voltage could be the issue as it made a difference before, but this time as a result of the sp1 update it had a reverse effect.I Lost performance increasing the voltage. So i set memory voltage back to auto setting where it worked the best. As a result of Windows Basic I have replaced Video card,DDr memory, harddrive,and even power supply. But having done this the last thing I could think of is that the bios settings could be the issue. It is not uncommon for bios to be set on auto configurationg and create problems and yet correctible with a few manual setting changes. Which leaves me at this point. What manual changes can I make which will allow improvement and possibly correct issue if that? I only know how to make basic changes in the bios and do not know how to make more advance manual changes in the bios. What do I change and what do i set it at?
    yes i have tested the hard drive with the diagnostic tool. it checked out good.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Have you tested your hard drive?
  • 2,794 Answers
ThaI don't mess with those settings for that particular reason.
good luck on that.
Posted on Jun 11, 2008
  • 25 Answers
The problem is with the hard disk...its making write failures...
How do I disconect the built in video card from my HPd530CMT to replace it with my Nvidia FX5200 ?
hello sir
u can deactivate it from the bios configuration
just choose the first vga source is pci-e x16
i will be providing a video if u didn't knew how just tell me
Feb 28, 2013 | Nvidia GeForce FX 5500 / 256MB DDR / AGP...
How frecquecy it must to have from RAM ? how nvidia it is OK from mpga478b ?
The Foxconn K8S755A6ELRS motherboard uses DDR Sdram at a frequency rate of either,
266MegaHertz, or 333MHz, or 400MHz.
PC2100, PC2700, and PC3200, respectively.
The Maximum Total Amount for the motherboard is 3GigaByte (3GB)
There are 3 Ram Memory slots.
The Maximum Amount for EACH Ram memory slot is 1GB.
{Has an AGP expansion slot for a graphics card.
Uses AGP 8X graphics cards}
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?id=en-us0000066
Under the Related Links heading to the upper right, the;
A) Motherboard manual
B) Drivers
C) BIOS update
D) Sample of the manual for disassembling is listed.
(Among other things)
Regards,
joecoolvette
Dec 10, 2010 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Cant log on xp.
hi..if u want to run as good that VGA u need to set in the Bios as init fist display as AGP then find what AGP size appear on bios..if this all OK try to booting the system..thanks and Good Luck..^_^
May 11, 2009 | NVIDIA GeForce 5500 / 128MB DDR / AGP 8x /...
HAVE A 6200ALE256DDR2 ON 845GV/GL. WILL NVIDIA 8XXX SERIES WORK?
what slots u have on motherboard if u have u can look it in here http://www.nvidia.com/page/geforce8.html mostly they use pci express slot
Dec 26, 2008 | XFX PVT44AWAH GeForce 6200 AGP 8X DDR...
8800gt black screen
Hi Juan016, you have done everything right. I'd say the 8800GT is bad & return it for a refund. Run the 8600GT & the NVIDIA 6100 at the same time. If you check the middle of page 9 in your manual. NOTE: It states; if a PCI-E is inserted the bios will automatically run the PCI-E card. (No need to make a bios setting change).
It also says if you change the setting in the bios to, OnChip and PCIe VGA, the motherboard should run both. Depending what amount of memory you set the NVIDIA to run with. Once in windows check the amount of total memory the NVIDIA or 8600GT reports.
Example: You set the NVIDIA to use 64MB & the 8600GT has 512MB than the NVIDIA or the 8600GT should show 576MB. Its not that uncommon one buys a bad video card.
Reading the manual & windows not seeing the 8800GT tells me the bios did not see the 8800GT card. The card is bad. You’re doing just fine.
Mike
Sep 14, 2008 | PNY XLR8 NVIDIA GeForce 8800 GT 512MB...
Nvidia Geforce FX5200 128mb DDR AGP 8x
Hi, since you mentioned you installed an MSI card & it worked well. I can assume you changed the bios & to boot to the AGP rather than the Integrated 3D video. This is good. Notice the message you got from Nvivia. It could not locate any compatible drivers. This can indacates 1 of 4 reasons.
1. The 5200 was not completely incerted into the AGP slot.
2. The AGP slot is dirty & needs cleaned.
3. Nvidia software was installed but previouse graphics software was not removed (un-installed) before the installation of the nvidia software.
4.The card is bad.
Suggest you download the latest driver software from Nvidia.
Jun 17, 2008 | EliteGroup L7VMM2 Motherboard
New graphic card
ya go for it it will may lower card specks if u have any limitations but your ok agp 8x 4x slot
Jan 24, 2008 | Computers & Internet
New motherboard and graphics card can only get into bios scrambled graphics any ideas gurus???
when inin safe mode the grapics card will intialize in default mode please reduse the resolution if that doesnt work that means u dont have the orginal driver for the graphics card please find the orginal driver version which is compactable with ur OS versionand ur graphics card
Nov 29, 2007 | EliteGroup P4M800PRO-M Motherboard
4 x 1GB DDR400 installed; only 3GB recognized by MOBO
If you installed total 4GB memory, the system will detect less than 4GB of total memory because of address space allocation for other critical functions, such as: - System BIOS (including motherboard, add-on cards, etc..) - Motherboards resources - Memory mapped I/O - configuration for AGP/PCI-Ex/PCI - Other memory allocations for PCI devices Different onboard devices and different add-on cards (devices) will result of different total memory size. e.g. more PCI cards installed will require more memory resources, resulting of less memory free for other uses. On a SLI system, since PCI-Ex graphic cards will occupy around 256MB, another 256MB will be occupied after you install a 2nd PCI-Ex graphic card. Hence, 2.75GB memory left only if two SLI cards installed on A8N-SLI Premium while 3.0GB memory left with one graphic card without other add-on devices. This limitation applies to most chipsets & Windows XP 32-bit version operating system. If you install Windows XP 32-bit version operating system, we recommend that you install less than 3GB of total memory. If more than 3GB memory is required for your system, then below two conditions must be met: 1. The memory controller which supports memory swap functionality is used. The latest chipsets like Intel 975X, 955X, Nvidia NF4 SLI Intel Edition, Nvidia NF4 SLI X16, and AMD K8 CPU architecture can support the memory swap function. 2. Windows XP Pro X64 Ed. (64-bit) or other OS which can address more than 4GB memory. You can check below URLs for reference: http://dlsvr01.asus.com/pub/ASUS/mb/4GB_Rev1.pdf http://www.intel.com/support/motherboards/server/sb/cs-016594.htm
Sep 06, 2007 | ASUS P4S800D-X Motherboard
Computers & Internet Logo
406 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
