Question about LG Televison & Video
My 32" LG TV has no power. It was plugged in when we had a close lightning strike. It was not turned on. Afterword, the power light blinked red and I was able to get the tv on. However, after I shut it off, it would not turn on. Now the blinking red light is also gone.
    Genius:
  • LG Master
  • 1,673 Answers
This sounds like the power supply has failed. It is also possible that there are other faults in the set that occured at the same time.
Jerry G.
Posted on Jun 11, 2008
Which circuit board on my Smart TV might be broken after a possible lightning strike. There are two main ones. The power is getting to the unit, but I can't get the menus, connections etc to work.
Nobody can predict, what might have been happened to your TV after a lightning strike. Do you thing anybody can? Is any technician have a super-natural power to predict the faults that might have been happened due to lightning (More than 10 Million volts to start on stroke) ? Can you?
Sorry.
Contact the authorized service center. OK?
Jul 29, 2015 | Toshiba Cinema 47L7200U 47" 3D 1080p...
Plasma Panasonic TV stopped working
Lightning-damaged electronics are a gamble to repair. Sometimes the problem is a single component, but more often multiple components are damaged, and even if you get it working, something else may die shortly thereafter. If you are lucky, only one board was damaged. My recommendation, if you have homeowner's or renter's insurance, is to put in a claim for the TV and get it replaced.
Having put forth that caveat, the blinking red LED hints that you may have enough left of the set for it to be repairable, especially given that much of a plasma set is already built to cope with high voltages. Try downloading a service manual and following the troubleshooting procedure. Here's the link (it's a Hungarian site, but there's enough English available to find things):
Service manual eprom result list ElektroTanya Service manuals and repair...
Jun 26, 2015 | Panasonic TH-50PZ850U TV
Is the module of lg tv 32ld330-mb affected when theres a lighting strike???is there a chance to be fix??
The damage from a lightning strike tends to be random. Sometimes it's minor, and only a few parts are affected. Other times, many parts are ruined, or destined to fail soon as a result of the current surge.
If the strike came over the power line, the input surge protectors in the power supply should be replaced, even if they look good. It would be prudent to replace the entire power supply. If you had the set plugged into an external surge protector, that should have taken most of the hit and should also be replaced. (Some surge protector manufacturers will pay up to a certain amount for repair or replacement of equipment plugged into their products if it is damaged by lightning.)
If the lightning came over an unprotected input cable, fixing the set would be a gamble. You could end up changing a lot of modules, beginning with the main board.
Jan 30, 2015 | LG Televison & Video
No power o a philips 32 inch lcd tv following a lightning strike
you problem is main board got striked. replace back same seriel# main board. good luck!
Sep 04, 2012 | LG Televison & Video
Was watching tv lastnight and the TV just shut off. I have unplugged it for the 30 mins that it recommends for it to rest. That didnt work. Any suggestions? Thanks
Now,the tv turn on,the front of LCD screen panel the power LED light is blinking or no power LED light indication nothing at all?Yes.The tv power supply board have problems,it dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 06, 2010 | Magnavox 32MF338B 32 in. LCD HDTV
Power light blinks red, TV doesn't turn on
if you are not technical i sugest you have this checked out by a professional most probably a fuse has gone from iside or your driver board has gone down. The blinking should be normal after you have turneds it off because some capacitors will be discharging.
Aug 23, 2007 | LG 32LX1D 32 in. LCD Television
Does not power on. Q951 charred
you can look for the model and brand, look for it on the internet and see if you can have the schematic diagram, you're lucky if u can. Lightning will strike first the tuner side, if there is a red blink, the primary side may be okay in switching type regulator, just replacing the charred part may not solve the problem. look for shorted components on the secondary of the power section.
May 15, 2007 | JVC AV-32230 32" TV
Televison & Video Logo
114 people viewed this question
Computer Repairing
Computer Repairing
