Zenith E44W46LCD I purchased a used Zenith E44W46LCD RPTV Lamp, but there's apparently a problem with the power supply (that's what the repairmen said). I need to know where I can buy a new power modulator and how I can replace it, so I don't have to pay $360 to get this TV working again.
    Problem Solver:
  • 61 Answers
Yes you could be missing your 300v to the ballast or you could have a bad ballast in any case this set is very difficult to disassemble be careful
Posted on Jun 11, 2008
Zenith E44W46LCD TV power/operation indicator lamp blinks green then goes red when power switch pressed. I can hear the fan motor but no picture. No history of lamp indicator warning.
If the tv projection lamp already been inside the tv now like a 1 1/2 or 2 years?Tv used it every day like 4 or 5 hrs every days?Yes?Than it is the tv projection lamp have to be replace,because the tv projection lamp life span have ended.
Sep 04, 2011 | Zenith E44W46LCD 44" Rear Projection...
The light to the right of the power button (Looks like a light bulb) is on. It is an orange color. It usually is not on.
You need to replace your projection lamp. We were able to purchase ours online for $124.95 and we put it in ourselves .I purchased this from http://www.discount-merchant.com/
they also gave the directions to replace it. You have to also reset the lamp and they give you those directions also
Jun 21, 2010 | Zenith E44W46LCD 44" Rear Projection...
I have a zenith e44w46lcd tv, while watching it, it turned off and now will not turn back on again. Green light flashes for a bit then goes back to red. Also lamp light is on orange. Do I need to replace...
More then likely your lamp is faulty, you can replace this lamp urself, but on zenith models the lamp comes as a bulb only, you will have to change the lamp and use your original housing. Also lamp timer will have to be reset. The only reason you might need a repair man is to go into factory mode and reset lamp timer. But if you are mechnically incline you can swap the lamps yourself..
Thanks any questions email me at -
Delhielectronics@live.com
Sep 27, 2009 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD SCREEN GOING DARK
The lamp will dim as it ages and will do so quicker as it approaches end of life.  Do you know how many hours the lamp has been used.  How old is the TV?
May 27, 2009 | Zenith E44W46LCD 44" Rear Projection...
Lamp has been replaced but TV wont power up?
If the lamp is a known good one, the next most likely suspects are the lamp ballast/power supply board or a mis-aligned lamp door. There's an interlock switch which opens when the lamp door is removed. Try removing and re-installing the lamp and the door.
Feb 15, 2009 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD tv
TAKE THE FRONT COVER OFF THE PANEL AND REMOVE THE BULB USEING A PHILLIP SCREW DRIVER AND JUST PULL USING THE HANDLE ON THE OUTER COVER OF THE BULB.
Feb 24, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD turning off
That would be the first thing I would try as it is probably flakey.
Jul 06, 2007 | Zenith E44W46LCD 44" Rear Projection...
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
