Question about Sirius Sportster 4 SP4-TK1 Satellite Radio Receiver with Car Kit
"no antenna" message
My sirius radio started giving me a "no antenna" message, in addition to the usual "acquiring signal" message. Although I have worked through every possibility of the antenna being somehow disconnected (it is not) this message seems to come completely at random, but now, more and more frequently... BTW, I keep my unit plugged into its dock and even have a securing screw in it to keep it from moving in and out, so I don't think the dock connection is worn out.
Does the message mean anything besides an actual disconnection of the antenna? Anything else I can do? The unit is less than a year old. -Chuck noantenna message when connected
  • Anonymous Sep 29, 2008
    I have the same issue. I checked all the antenna connections and they seem to be fine. Any soloutions?
Broken connection pin
Posted on Aug 06, 2008
  • 52 Answers
It could be the wire that connects from the actual antenna and the radio. Even if it is new it might just be wrong from the factory.
Posted on Jun 11, 2008
My receiver comes on and I get the error message "Acquiring Signal" and everything appears to be connected. Just started doing this. Using the Aux. jack in my Nissan.
First...you still need a sirius antenna plugged into the device. If you just started using this you may just need to resend the signal. Just call the sirius/xm people and follow the recorded prompts to send a new satellite signal. Then make sure you are parked somewhere that it is receiving a good signal and wait. It could take up to 30 minutes to reset completely.
Oct 24, 2009 | Sirius Satellite Radio Receiver
Drops signal as soon as location changes
You may have a dead zone in lake area !! I experianced alot of signal lose on a lake in oklahoma last year !!! swampratt200 !! AAEEE!!!
Jul 21, 2009 | Sanyo CRSR-10 SIRIUS Radio Receiver with...
Sirius satellite radio constantly shows "acquiring signal"
it could be the connection on the back of the reciever that could be bad. I would call sirius and see if your reciever is under warranty still, if not i can almost garauntee that your tuner antenna input is bad, if your antenna is brand new.
Apr 15, 2009 | Sirius Audio Players & Recorders
Acquiring signal
This unit looses reception all of the time even with the antenna headphones placed right next to my cars antenna.
You need the car or home kit or else you will suffer many drop outs "aquiring signal".
Dec 17, 2008 | Sirius Hoods Stiletto SL100-PK1 Satellite...
It could be the antenna wire is shorted especially if its the lower gauge wire.
Antenna's are fairly inexpensive to replace you could test it by setting a different antenna on the dashboard and see if the previous antenna is bad.
May 15, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Sirius sportster sp-tk1, always displays "acquiring signal"
Hi guys!! I am a sirius satellite radio employee and unfortunately, when this happens (usually when the receiver is about 2 years old) the radio is pretty much shot. It is a common problem with the older sportster models, but not so much with the newer one. As the receivers are probably more than a year old, they are now out of warranty and the only resolution is to call us at sirius and say you want to cancel the subscription on the radio. When cancellation is imminent, we will offer to send you a replacement (although it will be a different unit not compatible with you current docking stations) at no cost to you. Sometimes an antenna replacement will actually stop the problem, but it will happen again very shortly afterward, and thus it is only a temp fix to a permanent problem. Hope this helps you out!!
Feb 15, 2008 | Sirius Satellite Radio Receiver
SIRIUS Sportster "Acquiring Signal"
Let me save you $30.00. A new antenna will not help, nor will cleaning the contacts. I just did both of those and it did not help. I have mine in the freezer right now cooling it down. Sirius told me that I should not leave it in the car because it gets to hot. They told me to buy another unit....
Feb 07, 2008 | Sirius Satellite Radio Sirius Sportster...
Sirius does not stand behind their products, There is no out of warranty repair for their radios,  and they do not offer sites for repair. Seems  like this is a definite problem with this model. Their solution is to buy a new radio,(with all the new-docking,boombox etc) accessories. also they charge $75.00 to change to the new radio.I liked my sportster 1 because of the FM modulator. It just had to be centrally located and all the radios in my home picked it up(no docking) the new radios require $50.00 docking stations for each stereo location and radio location, unless you bring a boombox everywhere, and the sound isn't the same.    I feel there should be a class action lawsuit against Sirius for these reasons and I might look into it. What do all you think?
Dec 03, 2007 | Sirius Satellite Radio Sirius Sportster...
Asquiring signal
yes everyone is getting "aquiring signal" problem, why isn't sirius radio taking responsibilty ???? it's thier satttelite ??????
glenn
Nov 10, 2007 | Sirius Satellite Radio Sirius Sportster...
Starmate 4 acquiring signal
With the antenna plugged in, it may take a minute to aquire the signal. If it takes more than a minute there is a problem with the antenna or the reciever.
Sep 09, 2007 | Rio SIRIUS Starmate Replay Receiver
Sirius Sportster 4 SP4-TK1 Satellite Radio Receiver with Car Kit Logo
313 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
