Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer beeps and will not allow temp change
This Washer is less than 6 mo old. Machine worked fine a day or two ago. Now it will not allow any changes to the temp, rpms or anything else. It will allow you to choose Normal, Heavy, Bulky etc. and will run but it does a double beep the entire cycle. Is this a control board issue?
    President:
  • 331 Answers
Norma,
It's likely that this is a control board issue. Luckily you are still within your warranty period. I'd recommend contacting Whirlpool about this.
You may also try "re-booting" the CPU by unplugging the washer for a few minutes then plugging it back in.
Posted on Jun 13, 2008
My washer will run for a short time and them stop and just beep repeatidly
Frigidaire washer beeps for no reason, driving us crazy ...
? 1:03
https://www.youtube.com/watch?v=gP51k2bhbbg
Nov 6, 2011 - Uploaded by NatalieJonathan
Our Frigidaire washer keeps giving us ridiculous beeping issues, and for no reason. ... Mine stack dryer above ...
My washer pauses during wash cycle and will not restart ...
www.shopyourway.com > Manage My Life > Questions
The washer will stop during wash cycle and just beep. Sometimes we can turn it off and it will run again. Getting worse ... My washer is a Whirlpool 3.5 cu. ft.
FIXED Whirlpool Duet Washer Stops and Beeps - ApplianceBlog
www.applianceblog.com/.../48786-Whirlpool-Duet-Washer-Stops-and-B...
Jan 16, 2015 - 6 posts - ‎2 authors
It's a front loading Whirlpool Duet Washer 4.0 cu ft, with Tumblefresh ... wet it stopswashing and starts beeping (three beeps, pause, three beeps, pause, etc). ... The clip that holds them into the CCU (I think that's the right term) has a ... with my fingers so I could get a couple loads of laundry done until I can .
Jan 05, 2016 | Washing Machines
Model #GHW9150PWI not workin
If you look under the washer and see rubber shavings your motor coupling went bad-not a part you should replace yourself or you can ruin the whole machine, the part only costs less than $5.00 though. That's all I remember from working Whirlpool Customer Service years ago.
Jan 27, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer stops towards the end of the cycle and flashes 6 then F. The door stays locked and the washer beeps. It has happened before, the machine is about 6 years old, how can I fix
F/06
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Feb 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Gurgling sound from Whirlpool Duet washer when not in use
Check your drain line. You may have a siphoning condition. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
If you have the water source turned off, the only other way water gets into the washer is through the drainage system. If you do not have the proper air gap or placement on the drain line, it can create a vacuum and allow water to siphon back into the washer.
NOTE: Some residual water in the drain line is normal.
If you have any questions, please let me know. I hope this helps you.
Oct 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I was told the bearing is shot on the Whirlpool Duet Washer and it is not worth repairing, the machine is only 6 year old, any advice?
a 6 year old washer should not be scrapped unless it is made in china, replacing a 5$ bearing is worth fixing. even if you need to buy a drum unit.
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer will not start
This is joyce
Go to whirlpool.com and download your document to your machine and see what it has to say about your particular machine if that will help if not you may have to get some proff. help.
thanks
joyce
Feb 19, 2009 | Washing Machines
Whirlpool Duet GHW9150P Frustrated with machine
Could be the mother board!
I would call serv ice rather than risk ordering that expensive part!!!!
Appliance & Electronic Parts
NASTASI’S DISCOUNT
APPLIANCE & CONSUMER ELECTRONIC PARTS
TOLL FREE 888-338-3790 (PARTS ONLY)
8:00AM to 12:00AM - 7 DAYS A WEEK Usually next day delivery if part is in stock
You will need service at this time!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Aug 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer problem
Our machine was giving the HF code at 37 min after over filling with water. I unplugged the machine, popped the top (took the 3 torx screws off the back) pulled the small hose off the pressure switch sensor (round sensor on the upper back right of the machine) and blew it out just by mouth. It obviously cleared some junk. It works fine now. (also unplugged the 6 wires on the sensor, turned it around and blew on that and heard it clicking, so I knew that was ok.) Hope this helps someone.
Oct 14, 2007 | Whirlpool Duet GHW9150P Front Load Washer
WHirlpool Duet Washer
Swede, you need to replace the water inlet valve. Part number 8181694. This is an easy fix. Just remove the 3 screws that are in back holding the top on. Slide the top back and you will see the valve. Couple of screws and a clamp and it will come right off. Catriver..post back.
Jan 19, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
133 people viewed this question
Dan Webster
Dan Webster
Sal De
