Question about Equity Time USA Sky Scan 44100 Clock Radio
Equity 44100 clock radio problem
I just bought this Equity 44100 today and I am having a hard time setting the time. I plugged it in and it right away went to the right time. I wanted to move the clock to another spot and unplugged it. When I plugged it in again it just went to 12:00 and started to keep time from there. The est time is correct however but I am in pst. I have followed the directions on the instuctions but I must be missing something or doing something wrong. How can I adjust time and minutes when I need to? Thanks for any help. Monica
  • robbijane Jul 13, 2008
    The clock has lost an hour and 4 minutes. I don't know how to reset time though there are isntructions for resetting the alarm. I can't find the manual.
  • figrod Sep 16, 2008
    OMG I am sooo frustrated I don't know how to reset the time on this clock radio either. If you found the solution please let us know.
    Thanks
Hold the Alarm Set button down for about 5-7 seconds. The year will flash. Skip the year and date by pressing Alarm Set a couple times until the time is displayed. Use the Up and Down to change, then press Alarm Set one more time to save it. This clock is ****, by the way. I run into them in hotels and it makes me nuts as well. Very non-intuitive.
On the time lost issue...there is a button battery (CR2032) in a compartment underneath. That battery keeps the internal time so when the clock is plugged in, it "instantly" sets the time. Problem is, if the internal time is set wrong, then it instantly sets the wrong display time when it it plugged in. See procedure above to correct that.
Posted on Feb 26, 2009
How to set time on a equity 44100 clock
Try Googling (equity)(44100)(manual) without parens to get instructions.
Nov 15, 2017 | Audio Players & Recorders
How do I switch Equity 44200 from Celius to Farenheit?
Hold the Alarm 2 button down to change from Celsius to Fahrenheit.
Jan 19, 2012 | Equity Time USA Insta-Set 44200 Clock...
Need to know how to set time on ISTA SET 40009
Instructions
    • 1 Press and hold the "Alarm Set" button for five to seven seconds if you have an Insta-Set 40001, 44100 or 44200 model; the year will begin to blink when the clock is ready for adjustment. If you have an Insta-Set 40009 or 40018, hold the "DST" button for five to seven seconds (until the hour begins to blink).
    • 2 Set the year by pressing the right-arrow, "Up" or "+" button, depending on your model of clock.
    • 3 Set the month, day, hour and minute. Press the "Alarm Set" or "DST" button to cycle through each field, and use the "Up," "+" or right-arrow button to adjust the values within each field.
    • 4 Press the "Alarm Set" or "DST" button after setting the date and time to store the information into your clock's memory.
Read more: How to Change the Time on an Equity Insta-Set Clock ' eHow.com http://www.ehow.com/how_5657092_change-time-equity-insta_set-clock.html#ixzz1d1qIibS4
Nov 07, 2011 | Equity Time USA Insta-Set 40009 clock
I have a clock that will not get correct time. I have no way yo set it . Model #44100 Equity.
All Equity Insta-Set clocks automatically set the correct time and date when you turn on the power. Occasionally, the automatic time-setting feature malfunctions and you must reset the time yourself. Manually changing the time to the correct time on an Equity Insta-Set clock requires the push of only a few buttons to get the clock back on track:
1. Press and hold the "Alarm Set" button for five to seven seconds, the year will begin to blink when the clock is ready for adjustment.
2. Set the year by pressing the right-arrow, "Up" or "+" button, depending on your model of clock
3. Set the month, day, hour and minute. Press the "Alarm Set" button to cycle through each field, and use the "Up," "+" or right-arrow button to adjust the values within each field.
4. Press the "Alarm Set" button after setting the date and time to store the information into your clock's memory.
Best regards,
gylacz
Mar 18, 2011 | Audio Players & Recorders
Need to reset the time display on a equitytime model 40009
This solution from the answers below worked on my model 40007 clock today: If you hold down the button on top that says DST for like 10 seconds it will allow you to force change the time.
Thanks. wd 11/21/2010
Mar 15, 2010 | Equity Time USA Insta-Set 44200 Clock...
I have the 444100 model and for somw reason i see
to change the clock from 24 hour time to regular am, pm time, all you have to do is press and hold the "up" button. it should change back to regular 12 hour time.
Oct 29, 2009 | Equity Time USA Sky Scan 44100 Clock Radio
Setting my clock,model88000/86601
For any Equity clock, press and hold down the Alarm Set button. First the year will flash, if you don't care about the year, press the Alarm Set button again, if you do care about the year, press the arrow button (it could be an UP/DOWN arrow or a side arrow which is usually used to change from Centrigrade to Fahrenheit).
Basically, you begin by pressing and holding the Alarm Set button, then you use the arrow buttons, then again press Alarm Set to go to the next thing you want to set. If you wait too long, it will not set it, so begin again. I do this all the time, esp when DST occurs as the clock, when manufactured did not have the rules for the new DST time.
Jan 29, 2009 | Equity Time USA Sky Scan 44100 Clock Radio
Set time
To adjust this clock's time: Press and hold the Alarm
Set button for 5-7 seconds, and the year will
begin to blink, then press the "UP" or "DOWN"
button to set the year. Press the Alarm Set
button again to set the month by pressing the
"UP" or "DOWN" button. Press the Alarm Set
button again to set the day, again to set the hour
(be sure the AM/PM is correct), again to set the
minute, and once more to secure all in the
memory
Nov 02, 2008 | Equity Time USA Sky Scan 44100 Clock Radio
Equity Time USA Sky Scan 44100 Clock Radio Logo
1,186 people viewed this question
Top Equity Time USA Audio Players & Recorders Experts
handy2011
Level 1 Expert
Tom Chichester
Are you an Equity Time USA Audio Player and Recorder Expert? Answer questions, earn points and help others
