Question about Panasonic Toughbook CF-51 Notebook
Toughbook CF-51 Laptop DVD Drive Problem
Toughbook CF-51 laptop DVD drive previously could burn CD's but now it won't recognize the "blank" CD's at all, it WILL read CD's with data on them already so we can say the drive actually works but it may be a software issue.
Any suggestions?
    Genius:
  • 2,028 Answers
It could be a software or driver issue. First try updating the drivers for the drive, and try either using different burning software or uninstalling & reloading your current software. I had a cf72 with a DVD/CD combo drive that the DVD reader went out. This could also be the issue, if so you'll need to replace it in order to burn CD's.
Posted on Jun 13, 2008
Panasonic cf-51 bluescreen unmountable_volume
Run hard drive diagnostics: http://www.tacktech.com/display.cfm?ttid=287 (or http://www.bleepingcomputer.com/forums/topic28744.html)
Make sure, you select tool, which is appropriate for the brand of your hard drive.
Depending on the program, itll create bootable floppy, or bootable CD.
If downloaded file is of .iso type, use ImgBurn: http://www.imgburn.com/ to burn .iso file to a CD (select "Write image file to disc" option), and make the CD bootable.
You could also try a Live Linux like Knoppix Live from here:- http://www.knoppix.net/get.php,
download the Free ISO using a Torrent, burn it to a CD then run that it will load into Ram and then ith all the software in the CD you can examine the hard drive
hope this helps
Jul 02, 2012 | Panasonic Toughbook CF-51 Notebook
Panasonic Toughbook won't load Windows XP CD
You can check to see if the hard drive is dislodged, but other than that I don't know what to tell you. If you know the drive is functioning correctly then your motherboard is probably dead.
Jun 25, 2012 | Panasonic Toughbook CF-30 Notebook
DVD drive read/burn problem
From the description the new DVD driver is defective and should be returned if still under warranty. The only concern that I have is the replacement you got is identical to the original and that it is not a aftermarket product, because they don't have the same specifications as the original.
Apr 05, 2012 | Lenovo 3000 Y410 Laptop
Irql not less or equal blue sreen cf-51
reformatting the disk / restore computer back to company settings...is only the resolution for this...
To reinstall your operating system, you must have a CD drive in your multimedia pocket.
Note: CF-51 (Mk2) and CF-51 (Mk3) can also boot to an external Panasonic USB CD drive.
When the laptop is first powered on, the Panasonic name appears in white lettering with the phrase 'Press F2 to enter Setup' directly below it. When this phrase appears on the screen, immediately press F2 on your keyboard. Put the Panasonic recovery CD in your drive and use the arrow keys to move to the boot tab. Change the order of boot so the CD drive boots first. To do this, highlight the CD drive and press F6 until CD drive is the No. 1 listing. Press F10 to save your changes, exit and follow the instructions when your CD starts running.
Jun 14, 2011 | Panasonic Toughbook CF-51 Notebook
Panasonic CF-51 computer getting stuck, and making clicking noise. Have to turn off manually and restart.
Listen carefully to the HDD bay of the CF-51, If the "Clicking" sound is coming from that area then it is possible that the hard drive is failing causing the whole laptop to freeze up.
If that is the case then you're looking at a new or replacement hard drive.
Regards.
May 27, 2010 | Panasonic Toughbook CF-51 Notebook
Panasonic toughbook cf-27 cd/rw drive
www.Newegg.com is a great place to purchase this product. Nice laptop BTW...
Armymason
Feb 26, 2009 | Panasonic Toughbook 27 Notebook
I have a Panasonic Toughbook CF-51. It fell off
i repair laptop every day and i have never seen and inverter board shut down the computer.in less it was total shorted. it sounds more like the fall my have damaged the hard drive. if a the drive wont spin it will cause the laptop to power down cause the little motor will over heat in a matter of seconds.if the laptop was on when it fell then its more than lickly the drive.
Feb 20, 2009 | Panasonic Computers & Internet
Cf 51
The drive is slotted into the left hand front of the laptop. If you turn the laptop upside down you will see 2 slider buttons. 1 is used to remove the battery and he other is to remove the hard disk. You push and hold the button and slide the hard disk out.
Sep 22, 2008 | Panasonic Toughbook CF-51 Notebook
The cd drive does not recognize any discs
That is not a DVD drive, it is a CD-ROM drive. It can not play DVDs.
Jan 20, 2008 | Panasonic CD FOR TOUGHBOOK (cf-vcd721w)...
Panasonic Toughbook CF-51 Notebook Logo
196 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
