Posted on Oct 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My coppier ir 2016 shows error code number E808 what is the problem
Anonymous
Level 2:
New Friend:
  • Expert 148 Answers
  • Posted on Oct 30, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
148
Questions
0
Helped
27486
Points
492
That error is a DRIVE CIRCUIT FAILURE.
Canon ir 1024 iF shows E808 code error. How can it be fixed?
1) The error E808 occurs when one of the connectors in the fixing assembly is not properly plugged in when the unit is on.
2) This might have occurred while replacing the fixing assembly or performing a troubleshooting attempt on the machine.
3) You can find the connector above the fixing assembly at the right corner, behind the cover on the machine's side.
4) To clear the E808 error, unplug the machine from the power supply for at least 10 minutes. The error will appear again if the thermistors are in bad condition.
5)The fixing film assembly should be replaced in such case.
For more printer related assistance get in touch with our experts by just giving a call @ 1-866-293-9220.
I have Canon iR 2016 it show E808 code error
That error is related with the fixing unit. Check the connectors or replace the fixing film assy
5helpful
2answers
How can i solve this E244 error code
A E244 error code deals with the scaner. When you turn the copier ON will the scanning lamp turn ON? If it dose and you make a copy and thhe scaner moves & start to make a copy and then codes out. The problem is the BLACK scaner power cable has a crack in the coatting and is arching out to the frame o the copier..... It is not a easy fix.... If the scaner lamp is not turning ON???? You may have a blown Lamp or thermal fuse.... You can still find these parts..... The code will not go away till the problem is fixed.. Good Luck
7helpful
2answers
I have Canon iR 2020 it show E808 code error
conon ir2020i can not innitiallise asking to switch off and on the main power switch
Where can i get the codes canon ir 2016 series.
Hi, here you go:
E000 0000 Fixing temperature abnormal rise
E001 0000 Fixing unit temperature rise detection (by main thermistor)
0001 Fixing unit temperature rise detection (by sub thermistor)
E002 0000 Fixing unit temperature insufficient rise
E003 0000 Low fixing temperature detection after standby (by main thermistor)
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 Fixing film rotation error
E010 0000 Main motor rotation error
E019 0001 Waste toner full detection
0002 Waster toner full detection sensor failure
E052 0000 Duplex unit connection error
E100 0000 BD cycle out of range
E197 0000 Erroneous communication with printer engine
E500 0001 Finisher communication error
E520 0000 Offset error
E531 0000 Stapling error
E540
0001 Paper surface not detected (standard tray)
0002 Not moved within the specified time (standard tray)
0003 Sensor not reached within 3 seconds (standard tray)
0005 Encoder clock failure (standard tray)
E542
0001 Paper surface not detected (optional tray)
0002 Not moved within the specified time (optional tray)
0003 Sensor not reached within 3 seconds (optional tray)
0005 Encoder clock failure (optional tray)
E575 0000 Stack delivery error
E584 0000 Shutter failure
E716 0000 Erroneous communication with optional cassette
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E733 0000 Erroneous communication between controller and printer
E736 0000 CCU communication error
E739 0000 Erroneous communication between controller and network board
E744
0001 Language file/boot ROM/USB memory error
0002
0003
0004
E805 0000 Fan failure
E808 0000 Fixing drive circuit failure
1helpful
2answers
Error 001, error 808
the e001 code is something is going with the fixing assembly. one of the thermistors could be going bad.
E808 is a Zero Cross error. We most commonly see power supplies or bad wall voltage cause this code.
The following information is coppied from the IR2016 Service Manual.
E808-0000 DRIVE CIRCUIT FAILURE
A zero crossing signal cannot be detected.
A fixing drive motor failure has been detected.
  • The heater does not turn on.
  • A fixing drive motor failure was detected.
  • Check the connector of the fixing film unit.
  • Replace the fixing film unit.
  • Replace the fixing drive motor.
  • Replace the DC controller PCB.
  • Replace the power supply PCB.
M201 - Fixing Drive Motor - FK2-1067 - J202 on the DC controller PCB - E007, E808
Power Supply - FK2-1074
38helpful
5answers
i have canon Ir2016 it give 808 error code can u help me please
2helpful
4answers
CANON IR2016
hi... try to clean up your copier... usually dust accumulates inside the copier that's why paper inserted will always jam....always see to it that you copier is free from dust and other small particles that would cause your machine to get errors....
old marine
old marine
ZJ Limited
ZJ Limited
