To check the status of this sequence, you can simply log in to the routers interface and click the
STATUS TAB.
If this sequence never fully completes or doesn't complete properly, try
power-cycling both the modem and the router at the same time.
Please remember to reconnect the power to the modem first and then the router. Please allow a few moments for the devices to initialize and
"sync" up.
Also consider to reset the router to factory settings.Here is how:
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled
Reset.
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults.
Note: The factory defaults username is admin, and there is no password.
If you need more help come back.Post / thumbs / testimonial are welcome!
