Question about Garmin StreetPilot C330 GPS Receiver
New Garmin 330 stuck on kansas
I just purchased a refurbished Garmin 330 unit. I am trying to use the unit for the first time, but no matter what I enter, it says I'm in Kansas and gives me directions from Kansas to the location I entered. When i try to set a new home address it ignores it or gives me directions from Kansas to Minnesota (Where I actually am.) I tried to reset the unit by taking off the face plate and pressing the rest button. I also downloaded the update and updated the unit. Am i doing something wrong?
  • 174 Answers
Take the unit outside and turn it on. Then select View Maps, at the top of the screen it will say either "Locating satellites" or "Acquiring Satellites". Once the garmin has locked onto the overhead satellites, then it will say "Ready to Navigate".
Locating Satellites take longer than Acquiring Satellites.
Posted on Jun 11, 2008
My garmin street pilot c330 won't aquire satillite. this unit is 2 years old, but never out of the box. i got it from my son and tried to set up. when you turn it on all of the data in the unit is...
Try connecting in your car and leave it on and let it charge while you are driving it may eventually find the satellite, it probably remembers the last satellite it found which was in Kansas. You may not be getting a signal where your are right now so run some errands and leave it connected in your car.
You can also go to the garmin web site and try updating the unit. You will need a usb cable and will need to install garmin updater. Make sure the unit is fully charged.
If this does not work you can call garmin and they are usually very helpful. Here is the garmin link which will help answer some more questions.
http://www.garmin.com/garmin/cms/site/us/support/
Let me know what solved the problem. thanks for using fixya
May 14, 2011 | Garmin StreetPilot C330 GPS Receiver
Garmin Nuvi 205
You will have to send the unit to Garmin in Olathe, Kansas with proof of purchase
Jun 15, 2010 | Garmin nuvi 200W GPS Receiver
The unit comes on, but it says that the GPS is turned off. It is stuck in Kansas.
Kansas is the default location when the unit comes from the factory or when a factory reset has been made. You haven't mentioned the model you have. Have you opened the antenna and let it acquire a satellite lock? Without a lock it has no way to know where you are.
Sep 15, 2008 | Garmin GPS
Garmin 330 GPS using abroad
In order to use the C330 in foreign countries, you need to purchase the maps for those countries and insert the SD card into your unit. You will then have to select the proper maps to use on the unit. These maps are available for purchase at www.garmin.com.
As far as getting around closed roads, your unit will automatically recalculate your route if you are unable to take the suggested route. You can purchase updated maps, but I do not believe this will help you will roads closed for repair.
Aug 01, 2008 | Garmin StreetPilot C330 GPS Receiver
Nuvi 360 Stuck on loading maps
Have you reset the unit yet (little pusbutton behind the aerial)
Jul 30, 2008 | Garmin nuvi 350 GPS Receiver
Garmin c330
Purchase an external antenna from Best Buy or on line from Garmin.
Jun 27, 2008 | Garmin StreetPilot C330 GPS Receiver
Went to garmin.com/vehicles can"t load it onto streetpolit 330
It is unclear what you are trying to load from the Garmin site to your unit. If you are trying to update the software in your unit, it must be the EXACT model otherwise it will not work, and could render your unit useless.
If you are trying to update your maps on your unit, you will need to contact Garmin to purchase an update code.
Apr 21, 2008 | Garmin StreetPilot C330 GPS Receiver
No signal
You will have to leave the unit out in the open so it can 'see' the satellites. It might need from 20-30 minutes to acclimatize itself to the new location. It is set at Kansas because that's where the manufacturer is, so that is the last recorded satellite signal.
Apr 16, 2008 | Garmin StreetPilot C330 GPS Receiver
Location says I'm in Kansas
I got stuck in Kansas also. But, now I'm not in Kansas anymore! Are you trying to set your Garmin up indoors? That was my first problem. Go outdoors and try it. I did that and Toto and I were still in Kansas. SO, I pluged it inot my cigarette lighter and drove down my driveway. It took a few minutes for Garmin to locate a satalite, but once it did I was all set. No problems since, hope it works for you. I really enjoy using my Garmin. I'm one who ofter ends up on the road less traveled so, Garmin has come to my rescue a few times already. Have fun and say hello to the Wizard of Oz for me!
Christine
Dec 25, 2007 | Garmin StreetPilot c340 GPS Receiver
GARMIN BASICS FOR THE ELECTRONICALLY CHALLENGED
first turn it on and let the unit acquire satellites to find your home state. Then you can set up your address as your "home location". When I first set it up, I was able to pick up the satellites in my bedroom (scary....)...everything worked just fine.
Nov 26, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
382 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
