Boot Manager is missing - Computers & Internet
  • 3 more comments
  • aatom Jul 11, 2008
    But the VISTA DVD "Repair" cannot fix my Boot Manager Missing. It takes you online to find a solution but then I was told to see my system administratior or PC Supplier. No help there seeing it is a VISTA problem.
    I think the cause was plugging in a USB external HDD before booting. This HDD worked OK if plugged in after boot-up.
    Problem, how do I solve this problem?
  • Anonymous Oct 13, 2008
    vista recovery tool does not work? it says unable to restore? how do i reinstall vista?
  • classychic86 Dec 22, 2008
    My dell laptop is showing boot manager is missing and wont do anything but press ctrl,alt,del but when i do that nothing happens i need to get on my laptop bad what could have caused this problem and how can i fix it asap
  • Anonymous May 03, 2009
    This for my sister's computer. She puts in the disc that came with the computer. And does every thing that it tells her to do. And it tells her that the boot manager is missing .What does she need to do?
  • positive01 May 11, 2009
    I have restore cd for toshiba 200. Message is no boot mgr. Got passes this hurdle then it loaded files. Screen come up asking to select drivers but there was none to select. Then it asks me to load from disk.. I don't have disk as Vista Premium was on my machine when purchased. If I run system restore will this delete vista from my computer? Can anyone help with steps from here to attempt to get my computer running again. Thanks in advance
    Sergeant:
  • 243 Answers
You can often fix it right back up using the original Vista installation disk. Which comes with a pretty extensive System Recovery Tool that's got lots of options. Set your computer to boot from DVD (using the Boot setting in the BIOS), insert the disc and restart. Vista will prompt you for language and keyboard layout options, then ask if you want to reinstall Vista or repair your installation. You want Repair. From there Vista's System Recovery Tool will take over. this is the only way to get back from the dreaded boot manager missing error.
Posted on Jun 13, 2008
What happens if the boot manager is missing
Posted on Jan 13, 2009
What if you were upgrading form xp and now currently have no os on your system and i get that bull s*** im just trying to put ubunto and that wont work even too because boot manager is missing and hig ctr+alt+delete
Posted on Jan 25, 2009
Bootmgr missing ctrl 7
try to boot from a live distro and to see the hd status in a program like GParted. eventually you can install a boot manager from there
Nov 14, 2013 | ASUS Computers & Internet
How do I fix missing boot manager
There can be different causes for this problem:
If having reset the motherboard BIOS configuration, then check that the primary boot device is configured properly.
Mar 08, 2013 | Computers & Internet
Haveing problems with hp notebook 1100 boot mgr missing error while initializing NIC
Hi There,
I'm having trouble understanding what you mean by this - are you attempting to boot from LAN? Are you able to boot into windows at all?
What it sounds like is that your computer is either missing a boot manager, or you've assigned (in the bios) LAN boot as the priority boot device.
If that's the case, you can change the boot device priority back to internal hard disk in your BIOS (pressing F2 or F10 at startup splash screen)
If you're missing a boot manager for a windows installation, you can insert your windows installation disk and select "repair an existing installation" to repair your boot manager
Jun 06, 2012 | HP Computers & Internet
Says boot manager is missing
Try inserting the windows recovery disc and reboot the machine. At the language screen, bottom left, click repair your computer. At the recovery options screen, click on startup repair. This should recover the boot manager file. Reboot machine when completed.
Mar 22, 2012 | Acer Computers & Internet
Boot manager is missing
Hey Edward E. Hammett,
Thanks for being here with me.
Follow my tip here . i am sure you can do it. and if you succeed then review me.
Tip For Boot Manager Missing
Optional My Article Page just for Technocrats
Nov 24, 2011 | Compaq Computers & Internet
Boot mgr is missing
Boot Manager is missing If the boot partition no longer can be found, then Vista will display the following error: BOOTMGR is missing. Press Ctrl+Alt+Del to restart
The Windows Boot Configuration Data file is missing required information
More Info MS KB 919529 More Info MS KB 927391 Check points for fixing missing boot-manager: Check that your boot device is configured properly Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". Boot Manager is compressed If by accident having compressed the entire boot partition, then Vista will display the following error: BOOTMGR is compressed. Press Ctrl+Alt+Del to restart OR maybe try this first. Check points for fixing compressed boot-manager: Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". If the above doesn't solve the problem then boot into WinRE again, but when selecting the Vista-installation, then press "Load Drivers" (Instead of "Next") and use the mini Windows Explorer to right-click the boot-drive and deselect "Compress this Drive" and choose Apply to sub-folders and files. If that also fails then boot into WinRE again, and go to the "Command Prompt" and execute these commands: compact /U C:\bootmgr compact /U C:\ntldr If you for some strange reason have lost your Vista DVD, then you can also use a Windows 2000 / XP install CD and enter the recovery console instead and execute the following commands: attrib -c c:\bootmgr attrib -c c:\ntldr
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 21, 2010 | Acer Aspire 8920-6048 Notebook
Boot manager is missing how to solve
Jun 10, 2009 | HP Pavilion dv9000z Notebook
Toshiba Satellite a135-s4427 Boot Manager Missing
its not the hard drive my frined, its the boot loader it has been deleted or it has been compressed the only way to fix this is to use the recovery cd you have, to boot from cd-rom you need to go into bios which is usualy F2 or F5 key, then under boot manager or somthing is the primary and secondary boot, change the primary to CD-ROM, then save it and restart then it should boot from cd-rom then you have do a start-up recovery.
Jan 22, 2009 | Toshiba Satellite P205-S6287 Notebook PC
Computers & Internet Logo
7,647 people viewed this question
David Payne
David Payne
