Pool Heater Question
Our pilot comes on and stays on. When we turn heater on it comes on fine but then shuts down minutes later. Pilot goes out at that point, also. We have backwashed and have plenty of pump pressure. There is a "click" sound by the "pilot on" button when it shuts down. Any ideas or suggestions?
    Problem Solver:
  • 12 Answers
The pilot is there for two reasons one is to light the main burners the second is the safety feature. when the pilot is on there should be a cylindrical tube of metal near the flame. that tube is either a thermalcouple or a thermalpile. the t-couple or t-pile converts the heat energy to small amounts of dc voltage. the dc voltage powers a small magnet inside the valve when the voltage gets to low the magnet will release causing a small "click" and the gas will shut off. one thing that you can do to try and fix it is make sure your pilot is encompassing the top 2 3rds of the T-couple or T-pile and that the flame is strong and not blowing around when the burners come on. the second thing is that the T-couple or T-pile may have become weak with age, the only way to test the out put is with a special inline adapter. nice thing about T-couples and T-piles is that there a fairly in-expensive part. hope that helps some. good luck
Posted on Jun 11, 2008
Need to light pilot light
You need to turn the knob on the gas valve (inside the heater) to the "pilot" position. Then, while holding a flame over the pilot assembly push down on the knob.
Gas should come out of the pilot and ignite. Continue holding the knob down for 10-15 seconds. Release the knob and the pilot should stay lit. If not the pilot generator may need to be replaced.
Turn the knob to the "on" position, close the heater and turn the heater on and turn the thermostat to hot. The heater should fire. If it does not fire and the pilot goes out, that may also indicate a pilot generator problem.
Nov 20, 2013 | Teledyne Laars Pool & Spa
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
How to light teledyne laars 1 series pool/spa heater
turn on gas turn to pilot then hold down button light underneath where the small silver tube goes from the gas valve hold down lite then hold for a minute then turn to on should stay lit if not need new pilot generator
Jan 28, 2012 | Teledyne Laars Pool & Spa
I have an H250 NG and when I light the pilot it goes out when I release the pilot button on the gas valve?
The first thing That comes to mind is a bad pilot generator or thermopile. This makes a small half volt charge that energizes the magnets that open the two stages in the gas valve. Next would be a bad gas valve itself. You will need a milivolt meter to check both of these. Lastley is the safty circut. This is the string of switches that can shut the heater down if problems exist. Their are two sets of wires connected to the gas valve. One set goes down to the pilot, this is for the pilot generator. The other set is the safty circut. If you remove these wires and the pilot lightes and stays lit the problem is in the circut. Still no pilot then it is in the pilot or valve. Good luck.
May 28, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
The heat wont turn on and pilot does not stay lit
If this is a M/V heater you must have at least 400mv/dc to hold the pilot valve open. Check to make sure that the pilot is lighting, then hold the pilot valve down for about a minute. If the the pilot goes out you need to see what the m/v reading is. Chances are you have a bad pilot or gen. Replace.
Mar 06, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot will not stay lit after button release
most likely you have a thermopile that has low output. it takes about 100mv to maintain pilot light
Jun 24, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
The propane ignites, but shuts off after 2-3 minutes
check to make sure the thermocouple is stays in the pilot flame could be bad i think lowes has them in the water heating section
May 11, 2009 | Stainless Garden Sun Steel Propane Patio...
Heating & Cooling Logo
108 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
