Phone rings only once; voice mail does not pick-up.
AnonymousDec 16, 2008
wtf it must be contagious its because verizon is to f in cheap to run new lines in the area, the lines around our place must be 60 years old, their just a bunch of cheap bastards who don't give a **** about the public but are quick to charge the rediculous rates,
good luck fighting with those cheap bastardswtf it must be contagious its because verizon is to f in cheap to run new lines in the area, the lines around our place must be 60 years old, their just a bunch of cheap bastards who don't give a **** about the public but are quick to charge the rediculous rates,
Phone only rings once on incoming calls and does not go to message recording.Phone only rings once on incoming calls and does not go to message recording.
AnonymousMar 16, 2014
Phone goes directly to voice mail and doesn't ringPhone goes directly to voice mail and doesn't ring
You can't post conmments that contain an email address.
When someone calls, the phone rings only one time. calling other people works normally. Is this due to a lack of sufficient current to activate the bells of the three telephones we have in the house?
Who is your carrier? the voice mail is set up via them call or web site. Your phone rings or not rings check ringer volume and ring tone and check if you always have a good signal.
You can set your ring time to 5, 10, 15, 20, 25 or 30 seconds.
Tap **61*121*11* into your phone as if you're making a call.
Next enter a time between 5 and 30 (the number of seconds in multiples of 5)
Press # and then the call button. Don't put the phone to your ear - just look at the display until you see a message confirming your ring time has been set.
For example, **61*121*11*25# followed by the call button would set your ring time to 25 seconds.
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
I have contacted Verizon tech support for this issue. They say it depends on where you are (what towers are responding to your incoming call) and can not be changed. I told them that Cingular could entend the ring time, not number of rings. The rude customer-no-service person told me "well, you need to go to Cingular-now AT&T". We will see what type of response I get from the letter I wrote to the President of Verizon.
Jennifer209, if you press FEATURE + the button VM is pre-programmed on what does it display? It should show the extension number pilot to VM. If you call it directly, what happens? If you get no answer calling it directly, your VM may be down.
Kaait, is it getting into the VM that's the problem, or doing things inside the mailbox that is the problem?
Typically you want your phone system to ring your phones (say extension 10, 11 and 15) and then if no one answers after so many rings the call is transfered to the port the voice mail is on (let's say it's port 16) The voice mail is set to answer right away but does not "ring" until the call is transfered to it.
This way (at 4 rings) if a call comes in on line 1 and you answer after 3 rings but a call comes in on line 2 at the same time, the first ring on line 2 will not make the total = 4 and set off the voice mail.
I would guess the port at your voice mail is not set to ring and nothing is set up to transfer calls to your voice mail.
Did you set this up yourself? How did you program the phone system?
First, try going to motorola.com and downloading their software upgrade. (this is free by the way). You'll just need to connect your phone to the computer with the proper data cable and run the software. This program will do the rest.
