Question about Motorola Mobility RAZR V3
People on other end hard to hear
I have the volume all the way up on my razr and i still have problems hearing. they can hear me just fine. its a new phone too. any ideas?
  • 1 more comment
  • lillady79 Jun 11, 2008
    I have the same problem. I can use my phone on speaker but if it isn't on speaker I can't hear what they are saying but they can hear me. What can I do about this?
  • Anonymous Jun 11, 2008
    I can hear the ring but no voices
  • buckeyestu Jun 11, 2008
    same problem.... must use speaker phone
    Brigadier General:
  • 7,752 Answers
The problem with the phone is the speaker is faulty in the headset you just need to get that replaced
GUEST - you need to take the phone to a repair store and have the microphone replaced
Posted on Jun 11, 2008
    Guru:
  • 859 Answers
Hello all,
This is a factory defect from the switch inside the headset plug which when used will disconnect sound to the ear speaker on the phone and route it to the headphone or an ear piece.When this switch is closed by a fault you won't be able to hear anything through the ear speaker once the connection is established.
Take it into your Service Provider's store.
Regards,
Worldvet
  • Glenn Rogers
    Glenn Rogers Jun 12, 2008
    Hello all,
    When posting questions regarding the Razor V3 it is helpful and in many cases necessary for us to know if you purchased via Spring or Verison, etc.
    Thanks,
    Worldvet
I have a motorola razr v3 that i hear fine out of but others cant hear me
You will have to get your cellphone repaired that is the only solution to fix this problem.IF it is under warranty then please get it replaced.
You can try taking the phone apart if you want and clean and reattached the connections to the speaker in the phone.
Good luck,
Please don't forget to rate the solution.
Mar 30, 2008 | Motorola Mobility RAZR V3
Motorola Razr in water for about 5 min. dry now
From all indications, everything is functioning fine, just that they can not hear you at the other end.
The problem with your phone is the mouthpiece, the mouthpiece of your phone is bad, that is why they can not hear you at the other end.
All you need to do is change the mouthpiece of your phone and you will see that they can hear you at the other end.
Take care.
Apr 30, 2010 | Motorola Mobility RAZR V3
"unable to charge" message & person on other end cannot hear me
Go to a skilled mechanic, request him to check the charger, the charging connector, the charging controller IC to solve the problem.
Supriyo DG
Jun 12, 2008 | Motorola Mobility RAZR V3
Have no volume in ear piece to hard to hear
replaced the speaker in the ear piece this will correct the problem
Jun 05, 2008 | Motorola Mobility RAZR V3
Volume
When you are on a call, press the up or down buttons on the "top" part of the phone, to the left side of the main screen. If you are on a call, these buttons adjust in call volume. Otherwise, they adjust call ringer volume.
Dec 18, 2007 | Motorola Mobility RAZR V3
Auto bluetooth problems with Motorola RAZR V3 cell
don't think so.
maybe while pairing up the new phone you have turned down the volume on the earpiece?
Nov 28, 2007 | Motorola Mobility RAZR V3
Can't use earpiece...? (Motorola Razr)
Have you raised the volume while you are on a call as this is the only way the ear piece volume increases.
If this doesn't work then I'm affraid you have a faulty earpiece
Nov 06, 2007 | Motorola Mobility RAZR V3
Razr Hearing problems
drahma: If your RAZR is from the older ones, I strongly suggest you to replace it with an L7 (SLVR) or another model. The old RAZR's had too many problems (Voice, Data, Bluetooth, etc.), that's why MOTOROLA quickly release the SLVR L7. If it's a new model, definitely should take it to a dealer to replace your cell's microphone. SithPitt
Jun 11, 2007 | Motorola Mobility RAZR V3
there is some mic or speaker problem , just change it its cheaply available also
Motorola Mobility RAZR V3 Logo
149 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
