Question about Sharp AL 1631 Copier
AL 1631 Cracking noise and L3 code
  • Tim Babcock
    Tim Babcock May 11, 2010
    That error message has to do with the scanner glass traveling across the machine.
    Usually this happens when the cable is jammed up underneath the scanner glass.
    The scanner glass has to be removed to fix the jam and the ribbon cable needs to be inspected.
  • Sharp Master
  • 2,794 Answers
The clarification request should solve the problem
Posted on Jun 11, 2008
Our Sparp AL-1631 is flashing 4 then H what does it need?
To reset the H4 condition on your Sharp AL 1631 copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
Thank You for using Fixya. Our solutions are being rated this month based on positive testimonials so please leave a testimonial for me if this solution works for you.
Thanks!
Oct 05, 2010 | Sharp AL 1631 Copier
Tip
All sharp 1631 and 1642 models have scan unit problem.
When scan unit doesn`t move you have (L1-from left to right)and (L3-from right to left)code or blank copy (white).first must check scan uniy lock under the scan unit-then service 2 plates that scan moves on it.
on Jun 01, 2010 | Sharp AL 1631 Copier
Sharp al 1631 need drum roller reset code
enter code 42 start 1 start.
(press C auto C auto 42 copy1 copy)
Apr 28, 2010 | Sharp AL 1631 Copier
H 4 code flashing
The H4 code indicates the fuser may have blown the thermistor. It also could be a false error code. Try this series to clear the error and if it returns, then you'll know for sure the fuser is the culprit. To reset press the following buttons:
  1. Press this sequence: CLR-Exposure-CLR-Exposure
  2. The display will go blank
  3. enter "14", press "PRNT"
  4. Press "CLR" several times to exit.
Give that a try and good luck.
Feb 18, 2010 | Sharp AL 1631 Copier
I have a sharp copier AL 1631- it's making a noise
Hello sir; Bring back the toner cartridge to the store where you bought for exchange.
Feb 08, 2010 | Sharp AL 1631 Copier
Sharp al 1631 error code l-1
The problem it in exposere lamp section.The forward scan is not compelet.Cause is the mirror motor control board or mechanical parts.
Oct 03, 2009 | Sharp AL 1631 Copier
Sharp AL-1631 copy problem
it doesnt sound like to much is rong with the scanner they all judder at start up. if there was a scan drive issue you would get a L3 error code. does the m/c continually tick over? if so then you may just be out of toner as the m/c will be trying to reach its toner levels and that can take some time.
Dec 03, 2008 | Sharp AL 1631 Copier
SHARP 1631 CODE L3
The error is for the scanner mirror home position sensor. When the scanner mirror comes back to home (start) position if the photocell sensor doesn't see it due to be dirty or faulty the L3 error will be displayed.
Hope that helps you.
Aug 04, 2008 | Sharp Office Equipment & Supplies
AL 1631& L 1 code
Your lamp carriage is most likely hung up on something. Unplug the machine , remove the glass and see if the lamp and mirror carriage are moving freely. If not, find out what it is binding on.
It may not be lining up with the home position sensor on in the optics .
Jul 23, 2008 | Sharp AL 1631 Copier
What happend with a error L3
An L3 means the lamp and mirror carriage is not comming back to the home position. Back to the left. It isn't being sensed in the home position sensor.
Are the cables on the pullies?
Have you taken the glass out and cleaned it? You can put one of the screws into the wrong place and that will hit the carriage, blocking the return.
Jan 08, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
