Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Saeco Italia SUP021 YR - Red light #29 on solid
Saeco Italia SUP021 YR. Machine runs for 30 seconds but no coffee dispensed. Red light #29 on solid (Empty bean container/full grounds drawer) - not empty/not full. Help please.
  • 4 more comments
  • ZueT Jun 19, 2008
    I was trying to say that Ive emptied the bean drawer and brushed it clean til I could see the grinder(and refilled it). Also that the grounds drawer is not full. I've unscrewed the little metal disc filter, cleaned it and put it back on.
    I get steam but no water comes out of the coffee nozzles. the machine stops before that cycle. It has water and has been descaled.
    It makes the grinding sound but doesn't do the pressing clik-clak sound that happens before the coffee is dispensed. Red light #29 will come on and the machine stops.
  • ZueT Jun 19, 2008
    Also, as the grinder runs no beans move around and there doesn't appear to be any beans being ground up.
    Thanks for replying.
  • ZueT Jun 20, 2008
    Will try the above instructions tonight. Didn't try to line up the arrows on the grinder and upper burr. I cleaned the channel from the grinder but will do it again (better this time). I'll also try resetting the outer ring since my unit is a couple years old and we use oily beans.
    Will post the results.
    Thanks so much !
  • g1carver Sep 02, 2008
    I found out the problem with my machine. Light 29 and 30
    Situation 1) Light 29 was on, 2) The fresh beans container was full. 3) The grounds container was empty. Yet the light stayed on and I could not brew. Why? Their is a sensor switch in the back wall of the unit. You can see it on the lower left side after you open the front door and pull out the grounds holder. This sensor is turned off or triggered by a piece of plastic sticking out of the grounds container. The problem was that the little plastic extension is not long enough or the fit is not good enough and it does not trigger the switch. I fixed it by finding a thin piece of metal that I taped onto the plastic extension. Voila, it now pushes the switch down and the light goes off. I can now brew coffeee.
    I also had the same problem on the switch that is triggered in the upper right hand area by the main door when you shut it. The light for parts being aligned properly (#30) was on. Again I added a thin piece of metal of the same width the the plastic extension with tape. Again, the light went off and I could make coffee.
    These are both design flaws as they should stick out further. I believe the problem is both length and firmness as the slight back pressure from the metal switch pushes back just enough on the plastic since there is some give on the door and grounds container that they can move back and up preventing enough pressure to trigger the switch.
    Now if I can only figure out why I am not getting steam I will have solved all my problems.
  • c61894 May 11, 2010
    i request someone who has this machine to tell me ..what settings to put the machine on for a normal cup of strong coffee..because it seams like i am at a loss. just give me the numbers to set these dials at
  • Anonymous Mar 18, 2014
    my coffee machine works on mains as soon as i put it on my generator it will heat up but when i try and dispense it flashes up 6.6bar. The machine takes 5600 watts iam running it on a 12kva single phase generator. The coffee machines been serviced and tested mint condition no faults, i thought it was water preasure but its not as the water pumps runs fine on mains electric. It 230v single phase with grounded neutral, 30 experts have looked at it and noone can solve why it wont run on my generator please help...
Comment on oily beans - try not to use them. If you are looking for a stronger flavor coffee, an an extra shot to your drink. Oily beans cake inside the grinder, brew group + components and strains them potentiallu causing malfunctions.
Also dark beans are usually over roasted which makes the makes real coffee flavor lose. Espresso coffee beans should have very little to no oil and be unifrom in color.
Another approach if you are looking for stronger coffee flavor. use less water instead of more coffee. Two shots of 2 oz. espresso (made with 7 grams of coffee) are more flavorful & sweeter than one shot of 4-oz. espresso made with 14 grams of coffee. Visit http://www.coffeetico.com/did_you_know.htm for some more interesting information.
Posted on Jun 20, 2008
Ensure that you are putting the grinder and upper burr at the correct position and that if you are following the grinding cleaning instructions, you are aligning the arrows as it is indicated in the instructions, then re-setting your grinder. This problem is common when the grinder is set at too fine- thus no beans come out and the machine works hard but nothing comes out. Clean the channel from the grinder to doser door too as that could also be clogged with very fine coffee- it is too hard for the machine to push through too fine coffee. Then, make sure that you re-set the grinder correctly. If you are following the exact instructions but still no coffee coming out- then do the following.
Adjust one notch the outer ring in either direction and see if it makes a difference, if not try two or three. Sometimes, as the grinder gets worn out ( more commonly with oily beans and coffee that is kept in refrig/or freezer), you may have to play with the re-set (outer ring) until you begin to get coffee.
  • 40 Answers
Not clear on "Empty bean container/full grounds drawer) - not empty/not full. " But I gather that coffee is not being dispensed. Most Likely the grinder needs cleaning + brew group needs cleaning ( filter ). Do you get water/steam?
Posted on Jun 19, 2008
Water light stays on....no water dispensed, even
My Machine will grind-tamp but will not add water to push through.It will send water out tap on the side.
Apr 14, 2010 | Starbucks Saeco Italia Digital Barista...
Flashing lights on my saeco italia espresso machine
I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Feb 22, 2010 | Starbucks Saeco Italia Digital Barista...
Saeco Italia SUP021 YR green lights and red water light flashing
You can't manually reset. The machine will have to do it. I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Sep 14, 2009 | Starbucks Saeco Italia Digital Barista...
SUP021 YR keeps getting clogged
go to espressotec logo there you find how you can clean grinder.if still you dont have coffee try explain better whats hapend with machine when you want make espresso,good luck
Sep 04, 2009 | Starbucks Saeco Italia Digital Barista...
Machine won't return to the home position
Hi
2 things.
1. You may have a broken brew drive.
2. You may have a brew drive that has jumped its micro switch.
Call a service center
Apr 23, 2009 | Starbucks Saeco Italia Digital Barista...
Saeco Italia SUP021 YR how to clean metal filter?
The item you were refering to is: http://cerinicoffee.com/Saeco_Brew_Group_key.asp
It is used for removing the screen on brew groups: http://cerinicoffee.com/saeco_vienna_brew_Group.asp
It connects to item #4 below.brew_group_vienna5.jpg Authorized Saeco Service Center
www.CeriniCoffee.com
Oct 28, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco Italia Sup021 YR flashing red malfunction light
I found a link in the forum where there are some informations.
http://cerinicoffee.com/Saeco_technical_documents.asp
Hope this will help you.
/Mirran
Aug 22, 2008 | Starbucks Saeco Italia Digital Barista...
Starbucks Saeco Italia sup021 coffee dispenser stuck problem
Hi
Open the front door. Remove the driptray. On the left back side of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly. The brew group should come out. There is a piece that remains in the machine. Slide the piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position. If your brew group did not come out call a service center.
To return the brew group to the centered position, you first need to drop the funnel. To do this look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. Push the "Press" button and the shark fin moves up and down. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between. these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not just push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First
you must close the door and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and insert the brew group.
Done
Apr 25, 2008 | Starbucks Saeco Italia Digital Barista...
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
1,126 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
