Question about Frigidaire FDL45P1 Dehumidifier
Fault codes in a Frigidaire Dehumidifier - Frigidaire FDL45P1 Dehumidifier
  • gtg922e Jun 10, 2008
    F1 and F2 what do they mean?
I have a Frigidaire LAD504TDL dehumidifier and code 'ES' shows on display. What does this code mean? Unit runs but not much water in tank.
Good Morning Mark, thank you for your post!
I see that your Frigidaire dehumidifier is displaying an error code of "ES" and you would like to the meaning of that error code. The "ES" error code stands for evaporator thermistor error. This could be a possible problem with your control panel, thermistor, or a wiring harness. I would recommend contacting your manufacturer for further assistance with your dehumidifier. Best of luck! -Matt
Jun 08, 2015 | Frigidaire Dehumidifiers
The F2 code is on in the humidity window of my Frigidaire dehumidifier? Not in manual. What does this mean?
Good Morning friend, thank you for your inquiry!
I see that you are having trouble with your Frigidaire dehumidifier displaying an error code of "F2". Typically, an "F2" error code stands for a miscommunication error. This could be a possible problem with a sensor or control panel. I would suggest performing a reset and that can be completed by disconnecting the power from your dehumidifier for roughly ten minutes. If you are still under warranty I would recommend contacting your manufacturer to see if any additional assistance can be provided. Hopefully this is helpful. -Matt
Feb 13, 2015 | Frigidaire Dehumidifiers
What does an A-5 error code on a Frigidare dehumidifier mean, and how do I correct it
Good Afternoon Friend, this is Z. I am happy to assist you!
I show that the correct error code your Frigidaire dehumidifier is receiving is "AS". Typically, it means that your dehumidifier is experiencing a sensor failure. I show there aren't any manufacturer replacement parts available for your dehumidifier. This could be because it is a smaller appliance and repairs are often more costly than the actual appliance replacement. Is your dehumidifier still in warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your dehumidifier and the procedures to any potential remedy in that regard. Best of luck!
Aug 25, 2014 | Frigidaire Dehumidifiers
What is A5 on our frididare dehumidifier?
Hello Friend, this is Z. I am happy to assist you!
If you are receiving an error code AS on your Frigidaire dehumidifier, it typically means that your dehumidifier is experiencing a sensor failure. Because it is a smaller appliance, repairs are often more costly than the actual appliance replacement. Is your appliance still in warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your dehumidifier and the procedures to any potential remedy in that regard. Best of luck!
Jul 27, 2014 | Frigidaire FDL50R1 Dehumidifier
What are the codes. i get co as a code. itruns but will not remove the humidity
CO just means it is in continuous mode, that is not a fault. It may take quite a few days to settle the humidity.
The codes are AS or ES which indicate sensor faults
Jun 21, 2014 | Frigidaire FAD704TDP Dehumidifier
What is an as fault code
Hello Friend, this is Z. Thank you for allowing me to assist you!
If you are receiving an error code AS, your dehumidifier is experiencing a sensor failure. Because it is a smaller appliance, repairs are often more costly than the actual product replacement. Is your dehumidifier still in warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your dehumidifier and the procedures to any potential remedy in that regard. Best of luck!
Jun 12, 2014 | Frigidaire Dehumidifiers
My frigidaire dehumidifier fad704dud does not turn on when plugged in
Good Morning Robert,
I understand your Frigidaire dehumidifier, model# FAD704DUD, does not turn on when it is plugged in. I also see that the display lights up briefly and there are no error codes. Your appliance is designed to operate between 41 degrees F (5 degrees C), and 96 degrees F (35 degrees C). It will not work properly if the temperature is out of this temperature range, or the performance of the unit will fall greatly. The "Compressor" circuit has an automatic 3 minute time delayed start if your dehumidifier is turned off and on quickly. This prevents overheating of the compressor and possible circuit breaker tripping. Make sure the tank is fitted correctly otherwise your appliance will not turn on. If you are still having trouble, you can contact your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Frigidaire Dehumidifiers
No power, no error code
No power, no error code equals a dead dehumidifier. Far too costly to repair. I recommend putting those repair bucks towards a replacement dehumidifier. Frigidaire units are highly rated.
Apr 02, 2014 | Comfort-Aire BHD-501 Dehumidifier
Our FDF50S Dehumidifier keeps showing AS or ES. We tried to hook an hose to the drain outlet and it never worked. So what is wrong with the dehumidifer?
AS or ES is fault code for Humidity Sensor Failure. Contact Frigidaire Technical Service at
800-944-9044 for assistance. This part may be warranted for 2-5 years from date of purchase. You must have a Proof of Purchase for a warranty claim. If nothing else, they can tell you which sensor needs to be replaced and supply the part at your expense.
Hope this helped steer you in the right direction.
Jul 06, 2011 | Frigidaire FDF50S Dehumidifier
I have a FDL70S1 dehumidifier that runs and runs but doesn't take out any moisture from the air. I have cleaned out the filter and front screens thoroughly but it still doesn't work. The unit...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 10, 2011 | Frigidaire FDL50R1 Dehumidifier
Dehumidifiers Logo
626 people viewed this question
Top Frigidaire Dehumidifiers Experts
Charles T Nevin
Charles T Nevin
Oloyede Monsuru
richie46
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
