Question about Garmin nuvi 350 GPS Receiver
No sound and screen shuts off after 5 seconds.
I have no sound and now when i turn unit on, it shuts off in 5 seconds before getting going.
    Scholar:
  • 174 Answers
Did you fully charge the battery?
Have you tried it with the wall charger connected?
Posted on Jun 12, 2008
Outside unit runs for about 5 seconds then shuts off for a few seconds. It repeats this cycle.
Put in a 5 minute time delay. It is a two wire device in line with the contactor. Sounds like it is set to 75 turns of at 74 and repeats. The tstat should have a differential of 2 degrees as well.
Dec 22, 2013 | Heating & Cooling
I have sony Bravia KLV -32V300A suddenly shut-off while I am watching power indicator went off and standby red light blinking 5 times then after 2 seconds off then red light blinks again 5 times and so...
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Mar 09, 2011 | Sony Televison & Video
I turn on my nuvi 1300 and get a white screen
Hi famoflu5,
It sounds like you have the "white screen of death" (I made that up) non-responsive screen...meaning you cannot enter data or make the unit respond to finger or sylus presses. There is a procedure for getting the screen back to normal, provided there are no other software or electronic issues.
Try these steps:
1. Turn off the Nuvi.
2. Hold the upper-left of the screen while turning power on.
3. Release the Power button when the Garmin screen appears.
4. Continue to hold the upper-left corner of the screen for 30 seconds, until a white screen with "Press dot" appears.
5. Press dot and that should get you back to normal.
Also, you may to need perform a hard reset for your unit to clear out any erroneous data.
These GPS units can be reset by holding the Power button for 10-15 seconds to completely shut the unit down. Then, do the same procedure for 10-15 seconds again, to power it back on.
It would be best to assure the unit has external power, and hopefully a full battery charge, for best results. Also you can download a complete manual from this link for more info:
http://www8.garmin.com/manuals/3130_OwnersManual.pdf
Starting on page 47 of the manual in the appendix, it tells you about calibrating the screen (problem discussed above), updating software, and clearing user data.
If these steps don't bring your unit back to life, you may need to contact a regional repair facility or the factory for service.
Let me know how this turns out, and if I can help you further.
Regards,
Bill
09-19-10
Sep 19, 2010 | GPS
TV SCREEN IS JUST A BLUE PICTURE,BUT HAS SOUND
Hi and welcome to FixYa,
Offhand it would appear that the VCR section of the combo unit would require a bit of cleaning. Specifically, head cleaning. The easiest approach is to use a VHS tape head cleaner.
The other post of "tv turns on then 5 seconds later shuts off" would be the auto-protect kicking in. This indicates that a likely hardware fault exists. Try to initially reset the unit by unplugging from the mains for an extended period. Otherwise it would require opening the unit for voltage measurement/diagnosis.
Pls post back updates. Good luck and thank you for using FixYa.
Jan 25, 2009 | Philips Magnavox Learning Universal Remote
Regional code for dvd player
Reagrding unlock of samsun ht-x715.
Found this
http://www.amazon.com/review/R2FMHKVOZYF6HX/ref=cm_cd_NOREF?%5Fencoding=UTF8&cdPage=&cdERR=noPurchase#CustomerDiscussionsPost
Worked for me with a small change
1. Remove disc from tray.
2. Switch off player and unplug from mains.
3. Wait 30 seconds, then reconnect mains.
4. Turn on player with remote. press the 'Repeat' on the remote for 10 sec'.
5. Press enter on remote. (There will be no on-screen response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be no on-screen response.)
7. Press enter on the remote. Player will automatically shut off.
8. Turn player on.
9. Turn off.
10. Turn player on then off again.
11. Player is now region-free.
Dec 30, 2008 | Samsung HT-X715T Theater System
Error Code 5 flashes when unit shuts down
Good Day;
It sounds like the TV may have a shorted CRT, picture tube, but let's trouble shoot:
1. Unplug TV from wall.
2. Remove speaker grill, two on bottom, the screws are covered with plastic caps, right and left side on bottom next to floor.
3. Remove inner panel.
4. The blue tube is the one the right side, remove socket, with phillips driver, make sure it's not touching anything.
5. Plug and turn TV back on, if picture appears with no blue it's the tube.
6. If still shuts down, bad blue CRT driver IC.
CAUTION: Call a factory authorized service dealer to give you an estimate, if this sounds too hard.
Good Luck, Day, Big Irish.
Jun 18, 2008 | Sony KP-51WS510 51" Rear Projection...
Unit turns on for 5 seconds then shuts off.
I charged the unit and now it works fine. Plug into computer and charge for a while and the unit should work fine.
Mar 02, 2008 | Garmin StreetPilot c550 GPS Receiver
Tv turns self off when turned on
Does it blink a certain amount of blinks pause a second or just blink constantly with no pauses? Let me know it will blink a code if its going into protected shutdown. And it will blink constantly for another reason.
Jan 22, 2008 | Sony KP-53HS30 53" Rear Projection...
Magellan 2200T won't completely boot up
Reset unit, and then turn off, but hold power button for at least 10 seconds, then power back on, and when ever you turn off unit, hold power button for 10 seconds, had the same problem with mine, this solved it, it seems that just turning off the unit till screen shuts down puts it in a sleep mode. Hope this solves your problem.
Dec 18, 2007 | Magellan RoadMate 2200T GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
