Question about Jensen's VM9312 Car DVD Player
Burnt DVDs I have the Jensen VM9312... I saw on a previous post that burnt dvd's require a setting of macrovision in the codes screen to be switched on... I don't have a setting like that on this model. When i put in the dvd it just comes up to the navigation screen with no file infomation. Any ideas?
  • 1,586 Answers
Try this (this is the procedure for the 9311TS model, which I have, and it should be the same for yours too) - put in a regular movie, and do what you need to do in order to be able to watch the movie (cycle the e-brake handle, toggle a switch - however you have it set up). When the movie comes on, using the remote, hit STOP twice, then type in 1264, and a hidden menu will appear. This menu has the macrovision toggle - turn that on. While you're in there, you can also disable the parking brake bypass (turn the bypass on - no more e-brake handle or toggle switch!). Then hit the SYS SETUP button on the remote twice to save the choices you made, and you should be able to watch the burned movie then. You'll also find that it's nice to be able to just stick a DVD in and have it start playing.
Posted on Oct 26, 2008
Manual for the jensen vm9312
You can download and print the instruction manual for the jensen vm9312 in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Nov 03, 2010 | Jensen's VM9312 Car DVD Player
Do you know the bypass for this radio vm9312
You can try the procedure for the VM9311TS model (the one I have) - I don't know if it'll work but it's worth trying. Put in a DVD, and let it start playing. Then hit STOP on the remote twice, and enter the code 1264. If you were able to see the actual movie at this point, you'd see a menu pop up. Push down twice, then ENTER. At this point the blue screen should clear and you should see the movie itself. You'll have other options on that menu, like a macrovision option to allow you to see burned DVDs. Set what you like, then on the remote, hit SYS SETUP twice to lock in your choices.
Nov 13, 2009 | Jensen's VM9312 Car DVD Player
Jensen VM9312 problems with mp3 cd's and avi DVDs
try cleaning the laser with a CD player cleaning kit....keep in mind Jensen is low-end equipment at best.
Mar 11, 2009 | Jensen's VM9312 Car DVD Player
Captions for Jensen VM9312
go under your setup screen and press the language tab and you will see DVD subtitles then is will give you options to turn it off.
Dec 07, 2008 | Jensen's VM9312 Car DVD Player
Need bypass code for Jensen VM9311TS
Here it is how brother,insert a dvd movie,next use the toggle switch sequence to get image,next press stop button twice on the remote,then press 1 2 6 4 on the remote,you will now see a menu that says
Regon Code
Brake Override(I know you are drooling by now)
Macrovision
Loader Version
Model Version
Using the right joystick on the unit,navigate to the options of your choice,click on them to toggle on,off or which region code you want.
This wht you want.
Region Code 1
Brake Override ON
Macrovision OFF
When you are done,click SYS SETUP on the main remote TWICE to save the settings and vingo.
Nov 22, 2008 | Jensen VM9510 Car DVD Player
How to bypass a park switch for a jensen model VM9212N
all youneed todo is take ur pink wire from headunit and connect it with the ground wire and there ugo
Sep 18, 2008 | Jensen VM9510 Car DVD Player
Just installed vm9312
go to the radio press setup on your remote then press 543210, a secret screen will pop up press the hammer and skrewdriver,u will see brake overide put it on the on position,thenpress the X at the bottom of the screen,then your all set.
Jul 08, 2008 | Jensen's VM9312 Car DVD Player
Jensen VM9412 Video BYpass
May 21, 2008 | Jensen's VM9312 Car DVD Player
JENSEN VM9312 CAR DVD PLAYER HOW
go to am/fm
then open the settings screen
next on your remote type 5,4,3,2,1,0 listening for each beep
a new screen should come up
after that look for brake override
Mar 19, 2008 | Jensen's VM9312 Car DVD Player
How do i do to bypass my jensen vm9312
go to www.ecoustics.com then click on forum at top click car audio then multimidea. and read Teir are bypass codes for several models here.just have to look for them.
Dec 18, 2007 | Jensen VM9510 Car DVD Player
Jensen's VM9312 Car DVD Player Logo
154 people viewed this question
Top Jensen's Car Audio & Video Experts
Richard Foster
Richard Foster
afairman1927
Are you a Jensen's Car Audio and Video Expert? Answer questions, earn points and help others
