Question about Lexmark P6250 All-In-One InkJet Photo Printer
Scanning phobia? My P6250 will copy and print, it just won't scan, and keeps telling me to check the power and USB cords to make sure it's on and connected. What do I do? It used to scan beautifully.
  • pacompton Jun 20, 2008
    I have downloaded latest driver for P6250 and when I ask it to scan it says
    "The All In One driver did not respond."
All lexmark and get the latest drivers,they help with lnstall,sorry they ignore linux
Posted on Jun 15, 2008
Lexmark x9350 will not copy or scan.
Great job on trying to do it both ways, scanning and copying. Try to refresh the printer by uplugging the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Make sure other end of the power cord is plugged in straight to the power outlet in the wall, bypass any surge device or power strips. Plugged the power adapter back in the printer after 30 seconds. It should automatically turn on. If not, press the power button. Try scanning and copying again. If problem persists, I strongly suggest you contact Lexmark Technical Support to further investigate the hardware problem in the printer. Hope I can assist you more on this.
Jun 29, 2010 | Lexmark X9350 All-In-One InkJet Printer
Trying to scan, but keep getting error code 2,162,0 My scanner printer - my Canon 4370 won't scan. Printing and copying is working fine.
This works!:
noavatar_s.gif the_sunman
Rank: Apprentice
Rating: 94%, 4 votes
I finally got a solution to my problem, which is the same as this one. When trying to scan via USB, you have to make sure the unit is set to USB. On the top panel just above the LCD display, is 3 buttons, Copy, Fax, Scan. Hit the SCAN button, till the display says USB SCANNING. Then try to scan again. Good luck!
Sep 08, 2009 | Canon ImageCLASS MF4370dn Laser All-in-One...
Exact same problem as OP
Canon support was able to help me with this issue.
First, scanning with the MF Toolbox is only supported via USB, not across the network (scanning across the network generally does work but you need another application that supports it). Second, you must make sure that you have switched the device into USB scan mode. Press the Scan button on the device. If the display says "Network scanning" press it again until it says USB Scanning. From then on, scanning works beautifully.
Aug 22, 2009 | Canon ImageCLASS MF4370dn Laser All-in-One...
Suddenly stopped scanning and now won't copy or print b/c keeps saying it's still scanning. Canon mp830. Scanning Wizard starts but just dies in the middle. Any button I'm not hitting or solution you can...
Any lightning strikes locally?
You can try to reset back to factory by removing cartridges and head.Power off unit ,then unplug for 45 minutes.repower and install all.
Do a nozzle check and see what happens.
Aug 01, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Lexmark P6250 won't scan in Vista64
Disconnect the printer or at least be sure it is turned
off. I'd do both and reinstall the CD software program
that came with the printer.
When the software program asks you to
connect the printer to the USB port, do so and it
should again work properly.
Hope this is of some help. Bud
Jul 12, 2009 | Lexmark P6250 All-In-One InkJet Photo...
White lines across my scanned images
I had the exact same problem! the problem seems to be with the CCD calibrating itself before it starts to scan.
If you look into the scanner, the scanner glass extends itself into the casing of scanner where the CCD rests. Every time before the scan starts the CCD starts to calibrate itself in its housing before it starts to scan. If there is any reminiscence of dust or anything object (like a piece of paper) stuck in the edges where the CCD rest, the white balancing is thrown off and it causes white lines to appear along the entire line where the dust was present.
Ideally the solution would be to open the scanner casing to clean the housing where the scanner CCD rest. This would solve the problem.
If you are unable to open the scanner casing, then try using a piece of paper or a thin edge of a cloth, slightly dampened to reach into the edge of the scanner glass where the CDD rests and clean it. This is what i did and this solved the problem.
Jul 09, 2009 | HP PhotoSmart C4385 All-in-One Printer
Hp Photosmart c5280 1/ 2inch thick black line
There is something on your scanner glass. Clean the glass with glass cleaner. If this happens when using the automatic document feeder, open the top side cover where the paper feeds into. There is a narrow glass strip there. Clean that as well.
If this fails, the scanner head has a bad sector on the CCD and will need to be replaced. You will probably find that it will be cheaper to replace the printer entirely if that is the case.
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
I finally got a solution to my problem, which is the same as this one. When trying to scan via USB, you have to make sure the unit is set to USB. On the top panel just above the LCD display, is 3 buttons, Copy, Fax, Scan. Hit the SCAN button, till the display says USB SCANNING. Then try to scan again. Good luck!!
Apr 23, 2009 | Canon ImageCLASS MF4370dn Laser All-in-One...
Lexmark X6150 Inkjet - Problems Communicating with Printer
For scanning - use window drivers, try under window Photo Gallery. Works fine. For printing, the problem is when it tries to "delete" a file it prints it fails. Can not figure this one out.
Apr 02, 2009 | Lexmark X6150 All-In-One InkJet Printer
Copy problems
Check Scanning via the computer and save to file. If this shows the same fault then it is the scan CCD failing- Scrap the unit not a repair option[Unless it is still under warranty that is]
Jun 11, 2007 | Lexmark P6250 All-In-One InkJet Photo...
Lexmark P6250 All-In-One InkJet Photo Printer Logo
62 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
