Question about Video Game Consoles & Games
PS3 60gb Red Flasing Light
PS3 60gb Turn power on at back. Press the on button, get a few beeps then the red light flashes.
  • Derrick Knight Jun 10, 2008
    Already tried that. Red light still flashes after.
  • Derrick Knight Jun 11, 2008
    I have paid for Premium Assistance plan so where is the answer to my problem
Try holding front power putton until u hear 2/3 peeps
Posted on Jun 10, 2008
Luxor tv will not power up and red light just keep flashing
I just pull out the mains plug for a few seconds then put it back in. The red light keeps flasing for a while (be patient) then stays solid red. When I then switch on again with the remote it is fine. I often have to do this.
Jul 27, 2012 | Televison & Video
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
My ps3 is dead!!!. flashing red light
Follow the procedure below to fix the problem on your ps3,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System.
Take care.
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
Turn power on press swich at front red goes to green ie on 2 seconds turns off red
Its called the red light of death, turn it back off then hold down the button, it should beep once then beep twice quickly. It takes a few tries
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
Ps3 problem
if it wont load your icons and freezes before your xmb, put it into safemode and try restoring the filing system. to get it into safemode...
hold down the power button while the console is in standby. the light will go from red to green.it will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
May 03, 2009 | Sony Playstation 3 (PS3) Console
Ps3 says cannot start the correct hard disk was not found
try safemode
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
Flasing red light
If you've got a flashing red light on your console, it's probably overheated. Make sure you've got plenty of space around your system for it to breathe and it isn't in a location that's hot or enclosed. If you've got flashing red lights on your controllers, that means they're charging or that they're not paired with the system. Press the PlayStation button on the controller to make the flashing stop. Good luck!
Jan 09, 2009 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
73 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
