Question about Microsoft Xbox 360 Console
Please insert disc into 360
I get a 'please insert disc into a 360 console' message. It isn't the laser, because I have swapped drives, and cleaned the lens and nothing helps. Is there any other solutions?
    President:
  • 4,402 Answers
Posted on Jun 11, 2008
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
Is not reading game disks
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this mayhappen:
Apr 14, 2010 | Microsoft Xbox 360 Console
Everytime i put in a game in my 360 it says open tray
1. Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser. The laser is the part that actually reads the disc. The reality is... with all the hours and hours of gameplay, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
3. Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything, including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock. The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
Mar 17, 2010 | Microsoft Xbox 360 Halo 3 Special Edition...
When i try to play a game it keeps sayiny play dvd
Jan 15, 2010 | Microsoft Xbox 360 Console
Xbox 360 wont load any disc and have tried 7 steps of repair on your websitse and it still wont work
Xbox 360 cd drive comes up with please insert disc into an xbox 360 cd drive no matter what game i put in all the games are brand new and are xbox 360 games, the drive has not been change or altered the...
This is going to be a bit long -- but very detailed, so please readit carefully. There are several reasons that an xbox 360 system willhave problem reading discs. The error messages also vary fromunreadable disk, no message at all but the game skips, "please insertdisc in a360 console" to "open tray." There are a few reasons this mayhappen:
1.Bad disc. Check the back of your disc for scratches.If it looks good(or plays fine in another console), then the disc isprobably fine.Also-- try more than 1 game to be sure.
2. Badlaser. The XBox360 has a DVD drive very similar to a PC's DVD driveinside. The drive contains a bunch of parts including a few motors andgears and a laser.The laser is the part that actually reads the disc.The reality is...with all the hours and hours of gameplay, lasers doeventually wear out. The laser isn't very easy to replace, but it isreplaceable. You can find any and all XBox 360 lasers at the followingwebsite:
3.BadDVD Drive. Sometimes other components inside of the DVD drive can becomebad such as the motor that spins the disk, the motors that open thetray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360'sDVD drive is tied to the motherboard using a software lock.The easiestway to overcome this lock is to buy the exact same manufacture DVD drivethat is in your system now, remove the circuit board from the old DVDdrive (which contains the software key) and transfer the circuit boardinto the new DVD drive that you purchase. If you do this simpleprocedure, there is no flashing involved. The following website carriesDVD drives and also provides instructions on swapping the circuit boardfrom the old drive into the new one.
Nov 18, 2009 | Microsoft Xbox 360 Console
Xbox 360 not reading discs
Nov 17, 2009 | Microsoft Xbox 360 Console
It keeps on saying open tray
Nov 11, 2009 | Microsoft Xbox 360 Console
Wont read the disc itll jus say readin then say open tray
HTML clipboard This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
Nov 09, 2009 | Microsoft Xbox 360 Console
Just changed xbox 360 dvd drive, when you insert a game disc it says to play this disc please insert into an xbox 360?
You have to swap out the old drive PC board
to the new drive inorder fo it to work.
P.S. It may have been just a bad laser
not the drive motors in the old drive.
Rob
Sep 08, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
16 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
