Question about Asrock K7S8X-R3 Motherboard
No beeps on boot up with asrock mobo? help plz
Hi i have just replaced my mobo with an ASrock penryn 1600sli-110db, i also have a pny 8800gts card 3 gig of memory, On boot i get no beeps and no display. However i do get all fans cpu and case fans running and all lights on h/d's floppy etc, also the network connecter lites up to be active also. My psu is fine as it runs the same system but just another asrock board with no problems, I have tried reseating cpu and fan etc changed all cards memory etc etc ...Is it just a case of a dud board?
Well i have done all barbones tests and the mobo is now on its way back as its a dud :( even with just cpu in and mem it doest beep to say theres no graphics.
Posted on Jun 11, 2008
  • 105 Answers
While booting BOIS goes for POST check for detecting the all the hardware .
Disconnect all the connection to DVD, HDD, FDD from MOBO.
Rmove all RAM and start the ssytem from testing RAM Serviceability. If you listened a long intermittent beep place a single pices of RAM in MOBO ( repeat test with other RAM also).
Other wise your video card is unserviceable, if you have any addon plugins like NVIDA graphics card you can check
Posted on Jun 10, 2008
New motherboard GA-p67x-ud3-b3 no video on boot
  1. 1 x PCI Express x16 slot, running at x16 (PCIEX16)
    * For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
  2. 1 x PCI Express x16 slot, running at x8 (PCIEX8)
    * The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot will operate at up to x8 mode.
  3. 3 x PCI Express x1 slots
    (All PCI Express slots conform to PCI Express 2.0 standard.)
  4. 2 x PCI slots
Apr 29, 2012 | Gigabyte Computers & Internet
Got an AsRock P4i65G mobo and bought 2 gig RAM for it. However, I have bought ECC memory by mistake instead of Non-ECC. PC wont boot with the new RAM. Is there any way I can get this to work such as with...
Hi, you can download a manual here:
http://www.asrock.com/mb/overview.asp?model=p4i65g
Your mainboard DOES NOT SUPPORT ECC RAM.
This ram type is ONLY intended for servers
or mainboards that are compatible for that ram type.
This is what your mainboard supports:
Dual Channel DDR memory technology
- 2 x DDR DIMM slots
- Supports DDR400/333/266 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB
Use only the asrock site when upgrading the bios.
And a bios upgrade does not supports the ecc ram anyway.
Hope this will help you.
Aug 20, 2011 | Asrock P4i65G Motherboard
When i open my system unit it beeps 3 short beep and it does not boot up.
Hi
beep error is a problem in hardware. most likely it is a problem in the ram or the display card. perikasa and do the tests on two devices, better you use a 100% working hardware to perform troubleshooting.
regards
Mar 16, 2011 | Asrock Computers & Internet
2 LONG BEEPS BUT THE PC STILL BOOTS mobo asus m4a785-m phenom ii x4 945 c3 4 gigs kinston ddr2 800 thermaltake 600w pny gtx 460
Beep codeswere first introduced by IBM on their first PC as a means of trouble shooting failures. The two long beeps are not familiar, but who knows. look at the following site for some of the Bios beep codes.
http://www.pantherproducts.co.uk/Articles/Motherboard/BIOSbeep.shtml#Phoenix BIOS
Jan 03, 2011 | ASUS M4A785M (890552666775) Motherboard
My motherboard gives 8 beeps and shows no video, I tested with several video cards and gives the same result. when the computer beeps (normal as it recognizes that although the bios), then emits...
Continious beep codes are caused by the memory (RAM). Try reseating your RAM just plug it out clean it then put it back in. Or try the other memory slots. Just transfer your memory to the other slot if you have an available slot on your motherboard. Or simply buy a new memory (RAM). Just make sure it is compatible to your motherboard. Beep codes means the computer is not reading the memory (RAM) properly. There is no post and no video in your computer because the RAM is not working properly.
Dec 19, 2010 | Intel ASRock Penryn1600SLI-110dB LGA 775...
Asrock p4vm8 beep codes
How does it sound? Does it beep with memory card seated? one long- 3 shorts beep bad graphic card, one long repeated 3 times bad memory card
Apr 12, 2010 | Asrock P4VM8 Motherboard
Have Comp. w/Asrock MOBO.It's been sitting
For that open cpu cabinet
Reattach the RAM memory.
Open processor fan and processor reattach both.
Make sure motherboard circuit could not ground with cabinet.
Pull cmos cell from motherboard for 10 minutes .
Remove pci cards from motherboard if any.
Reattach VGA card if installed.
Then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 13, 2010 | Computers & Internet
Computer sounds like its on but no display
Remove all plug-in cards including the memory and clean the contact points with a pencil eraser... Insert them back and try... You should hear 2 short beeps, which means Okey... Long beep means that there is a problem with the memory or one of the memory... Keep me posted if not solved...
Happy Fixya...
May 21, 2009 | AOpen AX4B-533 Tube (91.8A210.102)...
Asrock K7S41/K7S41GX problem
2 x DDR DIMM slots
- Supports DDR400/333 non-ECC, un-buffered memory
3 beeps is usually either video card related, or memory. be sure your memory is UN buffered, and DDR400 or 333 DIMM not DRam.
Remove and re-seat your video card as well.
there should be a troubleshooting guide in your install manual stating the designation of 3 beeps.
Dec 22, 2008 | Asrock P4VM890 Motherboard
ASrock beep sounds???NO display
hi cathy
please specify
1.- pc?
2.- os
3.- model
and the properties about this
example... hard disk, ram, proscesor...
i think the problem is any hardware but i need more data
Oct 21, 2008 | Asrock Computers & Internet
Asrock K7S8X-R3 Motherboard Logo
276 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
