Question about Muratec F320 Plain Paper LED Fax
Move to a different phoneline
Fax machine was set up in my office and now i brought it home and I can't get it to work.(new phoneline number)
    Problem Solver:
  • 12 Answers
You need to change the phone number in the settings menu to reflect the new location. Erase the old, enter the new. Dont forget the area code, if different.
Posted on Jan 07, 2009
HELP ERROR 344 ON MY HP J4680 CANNOT SEND OR RECEIVE FAXES
Welcome to FixYa!
There are 4 reasons for Error 344 to occur when sending or receiving afax.
1. The remote machine failed to respond to a fax command from the local machinebecause the connection was interrupted. These errors can occur if the phonelines in the area to be faxed are old or there is noise (static on the phoneline). Other reasons can include power outages and other power-relatedproblems.
2. The call-waiting service can cause this error. The click, heard for anincoming call, is actually a momentary disconnect of the line.
3. The remote user pressed the Stop key while the reception was in progress.
4. Under rare conditions, incompatibility between the two machines might causethe remote machine to abandon the call.
Solution 1
Try to send a fax at a different time when telephone line conditions haveimproved.
Souliton 2
Try sending at a lower transmission speed.
Keep me posted and thank you for using FixYa!
Jas247
Mar 08, 2011 | HP J4680 Office Jet All-In-One Printer
MFC-8820D we have moved our office and have a new phone numder. How do we re program that number into our fax. Thanks matt
The following procedure will reprogram a new station (home fax number) for your machine. Thank you for using Fixya and please post back with any questions or to rate the answer provided.
Greg
  1. Press MENU 0,3
  2. Enter your new fax number (if the old still exists, move the cursor/arrow back ward to the first position to change the number displayed
  3. Press SET
  4. Enter telephone number (if it's the same as the fax number, enter the fax number again)
  5. Use the dial pad to enter your name (if your name still exists, leave it as it reads)
  6. Press SET
  7. Press STOP/EXIT
You will be given a choice to press 1 to continue with the change or 2 to exit without changes.
Press 1
The date and time will now appear and the change is complete
Sep 10, 2009 | Office Equipment & Supplies
Toshiba estudio16s need to change fax# inside machine
You have to change your OWN ID (fax) number through the menus.
Aug 03, 2009 | Office Equipment & Supplies
Need to set up phone/fax instead of just fax
I have a HP Officejet J6480 All-In-One and needed the answering machine and fax to be on at the same time.  I called the help line at HP and they said I needed another phone line into the home but I tried this and it worked.
First I got a different phone number for the fax machine - they do this for no charge at my phone company. This is not another physical line into the home - it is just another phone number with a different ring - it rings 2 fast rings for the fax machine instead of the phones regular one ring. I set the answering machine built into the phone to pick up after 4 rings and I set the fax machine to pick up on 2 rings. Be sure to set it so the fax pick up number of rings are less than the answering machine pick up number of rings.  It worked for me. Hope this works for you too.
Apr 24, 2009 | Brother MFC-260C All-In-One InkJet Printer
When people call our home number sometimes the fax machine is reached instead of the home number. What would cause that? I called Quest and they said it was a problem with the fax and to call you. Our fax...
Make sure the fax machine is correctly set up for the ring pattern of its number. I suspect it's either not set or set for the wrong ring pattern, and is answering the phone before you do when people call. Once the fax machine is set for the proper ring pattern the problem should clear up.
You can download a copy of the manual here if you've misplaced yours. Just pick your product (fax machine) and model from the drop-down menus.
Mar 13, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
On hook dialling
on hook is for dialing out some machine you push this button and dial the number to fax out.
there should be a off hook or stop button to release it
Aug 11, 2008 | Sharp Office Equipment & Supplies
Resetting the phone number currently displayed on the top of the page
On your fax control panel, press the MENU button. Choose either INITIAL SET-UP or FAX SET-UP, from the display. You should be able to scroll through the settings until you come to either HEADER, TITLE, NAME, STATION ID., or PHONE NUMBER. You can then use the number and letter keys to change the title and phone number.
Aug 09, 2008 | Brother IntelliFAX 560 Plain Paper Fax
How do I get a fax number?
you are correct just use a splitter and if you hear a fax . beep beep then hit answer
or just set your fax to answer on the 6th ring.
or purchase a dedicated phone line for faxes.
who uses faxes any more.
May 12, 2008 | Philips FaxJet 375 Plain Paper Inkjet
It is called 'Station ID', press Menu/Set 1 then 3 then put in your number.
Jan 24, 2007 | Brother FAX-575 Plain Paper Thermal
Muratec F320 Plain Paper LED Fax Logo
77 people viewed this question
Top Muratec Office Equipment & Supplies Experts
NewYork kyocera HP...
CheckitRight
CheckitRight
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
