Installer initialization failed due to the following error:Warning:Invalid Command line argument"http://slotocash.com/u?email=opd31557%40optusnet.com.au"
    Scholar:
  • 53 Answers
IF you are getting this error at the computer startup...
Click on start ---->go to run----> type msconfig---->click startup tab at the top---->uncheck entries that you think you dont use.
Uncheck and then restart.
It will not un-install but disable those unchecked entries from startup.
Posted on Jun 10, 2008
Invalid command, line 01 code 400
Mornach 9825 printer is error "Invalid Command! Line 01 Code 400 ".How issue this error.
Apr 16, 2011 | Monarch Paxar 9855 Printer
I get an error message on start up on the desktop screen. invalid command line parameter ... mapinfo data installer. i had to add/remove 'office' due to a hard drive replacement. why do i get this error...
This is due to an Operating System File was removed during the uninstall of Office. The only way to resolve this issue is by formatting the Hard Drive and reinstalling windows. I hope this helps
Apr 04, 2011 | Dell Inspiron 6000 Notebook
Error 1722
You may encounter the following error on installation:
Installation ended prematurely because of an error
when trying to install 32-bit or 64-bit qlikView on Windows 7. With or without UAC (User Access Control), installation fails.
Suggestions to (re-)install vbscript.dll using regsvr32 vbscript.dll in the c:\windows\system32 (64-bit equivalent) directory didn't help.
On execution of the installer, c:\program files\common files\wise installation wizard has a new msi added that includes the full installer for the qlikView application.
Installation worked by opening your command window (Start -> (All Programs) -> Accessories ->Command Prompt (right-click and run as Administrator) by calling the msi, above, with a few switches:
msiexec /a WISB3[...].msi
That worked.
The command-line registry fix as below
reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f
didn't do anything...
Mar 30, 2011 | Microsoft Windows 7 Home Premium 64BIT...
I have prloblem with nsis error
The installer has failed a self-check. This means that for some actions, the installer file has been altered from its original form. If the install were to continue, the software install would not be complete and will be broken. To prevent further problems, the installer refused to continue.
If you are receiving this problem from an installer located on a disc or other media besides the Internet, then the problem may be due to a hardware failure or more likely the physical media being damaged. Try reading files from other parts of the media. If you are receiving read errors with other files on the disc, then the problem is likely due to damaged media. You will need to contact the source of the physical media for a replacement.
As a last resort, the installer can be executed even though it's corrupted. To bypass the corruption test, pass /NCRC on the command line. To do so, go to Start->Run, type cmd and hit Enter. A black console window should open. Drag the installer into the window, hitSpace and type /NCRC. Hit Enter again and the installer should start. This is not recommended!
NSIS Installer/Uninstaller will raise this error whenever you will launch the installer/uninstaller from an forbidden location (such as C:\, C:\Windows, C:\Program Files, etc).
Dec 27, 2010 | HP Computers & Internet
Error 2350
THE PROBLEM The Windows Error 2350 occurs when the installed version of the Windows Installer is too old for the MSI to execute. The registration entry for the engine has been damaged and all attempts to execute the MSI installation packages will not be successful.Errors on your system may be caused by invalid registry entries and outdated or corrupt drivers.
THE SOLUTIONTo fix the registration entry for the Windows Installer, the Installer service should first be registered then unregistered using msiexec /unregister and msiexec /regserver (Type both command in run) or the command line switches. The user will then have to restart Windows.
Feb 12, 2010 | Microsoft Windows Vista Home Premium with...
How can i repair error 2350 with no cost?
To fix the registration entry for the Windows Installer, the Installer service should first be registered then unregistered using msiexec /unregister and msiexec /regserver or the command line switches. The user will then have to restart Windows
Oct 31, 2009 | Microsoft Windows Vista Home Premium with...
Error code 345
The remote machine has failed to respond to a fax command from the local machine due to the connection being interrupted.
Number of possible causes, check the phone line, try a different fax number for a start. Is there other fax machines in the office on the same line
Sep 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
How to uninstal avg 7.5 ?
try to download the avg8 from here and install it. then if you want to uninstall run uninstaller from controlpanel for avg8.
the avg8 should be able to remove avg7
Feb 24, 2009 | Microsoft Windows XP Professional With...
Computers & Internet Logo
216 people viewed this question
David Payne
David Payne
