Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
How do you replace the forward / reverse cable?
I don't know how the end fits back on the replacement cable.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=40485&thid=661987 How do you replace the forward / reverse cable?
Posted by HANDYBILL on Jun 10, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover U6437-900 / U6439-900 Windtunnel Vacuum. There is a hook on the bottom of the vacuum and @ the top by the handle as well. You may what to get a schematic or owner’s manual to see how they hook up because of the newer and different Model #’s for Hoover. The Hoover Self-Propelled works on when the handle is lower to a comfortable position then the self-propelled drive may just need and adjustment. There is a self-propelled rod that controls the self-propelled feature and it either needs adjustment or replacement or the part that hold it may be broken but either one can be fixed. So feel free to contact your local vacuum cleaner dealer with questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 11, 2008
Dismantle philips tc722/A to repair cable rewind
Briefly, you don't remove the top section, rather you get at the cable drive / release through the cord feed hole.
To do this I use a couple of large flat bladed screwdrivers and get fairly brutal with them to lever out the plastic surround to the cable inlet. it's tough plastic so don't be afraid.
Once the plastic surround is out you can see a piece of black plastic and white plastic. The black should fit in the socket on the end of the white. That's it, just push the white plastic down and the black seats the socket. To test, press the release mechanism and you should see how the black pulls the white drum release back toward the rear of the machine.
once you have done it once it takes about 5 minutes.
Aug 25, 2014 | Vacuums
How do you attach the upholstery tube to the main unit? thanks!
The larger fitting slides into the front of the dirty water tank. Remove the lid and either remove the duct, or lift it and tilt it forward on more recent models. The hose fitting goes in with the opening up, and the "V" shaped end down. After replacing the lid, push the round connector down onto it's fitting under the trap door on top of the nozzle, being sure it is fully snapped in place.
Feb 07, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Changing the belt
Always make sure your machine is unplugged from the outlet before replacing the belt.
Newer Oreck uprights have an access plate on the right hand side of the base (as you're looking at it from the front). Remove the one screw from the access plate and slide it forward. Snake the new belt around the brush roll pulley and then strrrrrrretch it back to the motor shaft. Replace the access plate.
If your model does not have an access plate; turn the machine upside down, Remove all screws. Lift the bottom plate off. Observe the position of the brush roll ends, One side of each end cap will have several notches cut into it,this is the 'new' side, the other side is smooth, this is the 'old' side. You can reposition the brush roll the the 'old' side if your bristles appear worn down.
With the brush roll still removed; place one end of the belt over the motor shaft first, place the other side of the belt around the brush roll pulley and stretch the brush roll forward until it is back in place.
Spin the brush roll by hand before replacing the cover to ensure the belt is not pinched.
Replace to cover.
May 16, 2010 | Oreck XL Ultra Bagged Upright Vacuum
Forward/back cable broke
The cable is user replaceable, but you will need to contact Hoover, or a parts center, to purchase the cable. You will remove the Upper Handle by removing the black screws at the base of the upper handle fit to lower handle (on back).
You will also have to remove the hood to loosen the one screw that holds the cable to the powerdrive gearbox.
Oct 12, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Replacement wand for canister
Whne you had your first problem with it, the cord at the bottom probably should have replaced also, if one end gets scrotched, the other end does also. One big reason why this happens is connecting and dis-connecting the power head while power is still applied to it. When you hook your skillet and it is turned on, it will arc, so does the contacts on the hose and power head. That prong is rusty, it is scrotched. Don't know if you can substitude, you might try to find a shop that has other wands and see if you can find a fit, either that or buy the one that is supposed to be with it.
Mar 15, 2008 | Vacuums
E drive problem. Self propelled feature drives in reverse, but not in forward.
This is basically the same problem with a Hoover power drive only the forward still drives albeit slowly and a slight "push" to keep it going. There has to be a common core type of drive failure !!
Feb 27, 2007 | Dirt Devil M087700SV Bagless Upright...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
367 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
