Question about Singer 3820 Mechanical Sewing Machine
Singer 3820 How I replace the bobbin case, it's loose and I can't sew!
  • 323 Answers
Remove the 2 screws in the needle plate. Lift off the plate.Take out the bobbin case and examine it for rough spots or nicks. If there are any it will be necessary to buff them with an emery stick or fine sandpaper. Once the rough spot has has been smoothed, buff it with some very fine steel wool. There must be no rough spots on this bobbin case.Clean all the lint from inside the hook area. Do not pull the wick from the center of the hook. Place the bobbin case in the hook area so that it sits flush and does not bind when the handwheel is turned.Reinstall the needle plate, thread the machine, insert the bobbin and turn the wheel to pick up the bobbin thread and see that it doesn't bind.Test sew
Posted on Jun 12, 2008
The needle hits the bobbin casing when trying to sew.
Posted on Sep 12, 2011
Why does my Singer 3820 bobbin winder not disengage the sewing foot now?
sounds like the clutch is stuck I would take it into a repair shop
Aug 05, 2014 | Singer 3820 Mechanical Sewing Machine
Singer 7462 not picking up bobbin thread
it's very possible that the machine could be out of time & needs to
be checked by a sewing machine technican
Jul 29, 2012 | Singer 3820 Mechanical Sewing Machine
Bobbin casing not in properly, needle stikes
take the bobbin assembly apart and replace it properly.
Jul 19, 2011 | Singer 3820 Mechanical Sewing Machine
I need to order a new bobbin and bobbin case? Where can I get one?
hi i am from trinidad. if you need to buy, i can sell you. we stock all sewing machine parts for all brands
Sep 20, 2010 | Singer 3820 Mechanical Sewing Machine
The bobbin thread will not feed up to the sewing deck
Get a q-tip and clean out all of the lint from the bobbin area. Then make sure the bobbin case is in properly. Make sure you're using the correct bobbin size. Then thread the bobbin again & see if it's working properly
Jul 16, 2010 | Singer 3820 Mechanical Sewing Machine
Does the singer model 3820 take a special bobbin? I cannot get it to feed the thread up to the needle.
It takes a singer or universal bobbin with a flat top - not one of the plastic ones that has a curve to the top.
Jul 11, 2010 | Singer 3820 Mechanical Sewing Machine
Bobbin tension too loose
there is a tiny screw on the bobbin case that increases the tention on the spring that the thread needs to be placed behind.
May 22, 2010 | Singer 3820 Mechanical Sewing Machine
Singer 3820 Bobbin Issues? I can't sew!
Unthread the machine completely, remove the bobbin.
Make sure that the bobbin case is securely in its place.
Turn the handwheel and ensure that the bobbin case is not jamming.
Turn the handwheel until the take-up lever is in the highest position.
Raise the presser foot and rethread the machine.
Chaeck the upper tension setting and set it around 5.
ALways make sure that you start sewing, stop sewing and thread the machine with the TAKE-UP LEVER IN THE HIGHEST POSITION.
Jul 11, 2009 | Singer 3820 Mechanical Sewing Machine
Singer 3820 Mechanical Sewing Machine Logo
313 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
