Question about Onkyo TX-SR605 Receiver
Input selector keeps changing when select one
When I switch on my Onkyo amp and select CBL/SAT it stays for a few seconds then selects through the other input options such as Game/TV, DVD so have to keep pressing CBL/SAT to keep on that input after several unsuccessful tries. Has anyone help with this annoying problem? Thanks.
Best Regards
edc
  • 1,512 Answers
Hi goa_edc
Try resetting the amp by leaving it unplugged from the wall overnight, and then fire it up in the morning.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jun 13, 2008
Toshiba model 36A43 a Universal remote, a HD Digital Antenna the TV's settings menu no antenna as a auto ch. program search. Has TV/CABLE, I tryed cable didn't set.
I've checked the specs: of your TV. Its original remote control number is "Toshiba CT-90157". This remote control have a slide switch by the left side of it, [a selector switch]; that selects inputs TV, CBL/Sat, VCR, and DVD. You have to select the slide up position to select the TV, to select the TV function by its buttons. Just have to slide one step down to select the input to CBL/SAT; to select the CBL/SAT function by its buttons.
But, without a remote control, you can seect the TV/Video function by its front panel controls. There is press button switch, just right side of its Menu button. For each press of it, the set's input selection will change from TV to Video and vice versa.
Just press this button to select the TV as the input. Then only, the antenna socket at its back will turn effective. If you can't select input by this way, the input selector switch; specified above, has the fault, or the input selector IC inside the circuit board is faulty. Just try this after a Hard Reset to this set, and then check. If it do not help you, contact any service technician, or the authorized service center for Toshiba.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jul 22, 2016 | Toshiba Televison & Video
Onkyo zone 2
Is it possible that the currently selected input was changed? Try selecting a different input.
Jan 31, 2014 | Audio Players & Recorders
Unable to connect a blu ray dvd player to onkyo tx-sr605 via hdmi
Not sure what unable to connect means..but I will assume you have the correct cable.
First make sure you have plugged the from the HDMI cable from the DVD play into the IN 1 HDMI port on the back of your Onkyo
On the Receiver
Enter the Setup mode
Select INPUT OUTPUT ASSIGN
Next make sure the HDMI monitor out is set to YES on the Receiver
Monitor out
HDMI Monitor - YES
Next you need to assign the HDMI INPUT to DVD
HDMI INPUT
DVD - IN1
CBL/SAT - IN2
This may be your issue.
Next step would be to verify your television input settings.
Nice receiver!
Best of luck!
Apr 13, 2011 | Onkyo TX-SR605 Home Theater Receiver 7.1...
Hi, I am having trouble hooking up my new LG home theatre system with my Rogers cable. I connected the home theatre system to the TV with an HDMI cable. The sound works with watching DVDs on TV and...
To listen to Tv program sound through your home theater system you will have to connect a pair of RCA to RCA cables (Red and White pair ) from the audio out socket of the TV ( some times three sockets Yellow/Red/White labeled Monitor out. Ignore the yellow as it is video out ) to the Aux or CBL/Sat input of the LG system. Then to listen to the sound through your LG HT system switch the Input selector of the LG to Aux or CBL/SAT. Will work for sure.
Mar 08, 2011 | Audio Players & Recorders
Onkyo TX-SR805 Amp isnt projecting the picture through my Sony kdl46xbr. i am recieving sound but no picture. Reconnecting direct from source to TV and no issue so the problem is with the amp. HDMI symbol...
I have a 607 by Onkyo and you have to assign imputs to the imput selector. I don't know if your model uses the same, but if it does press setup and select input assign then select HDMI imput to see what it is set to.
Mar 06, 2011 | Onkyo Audio Players & Recorders
Pressing input selector button changes sound only, not vision.
you're right, it definitely shouldn't be doing that! i know that your cables are probably ok, but it sounds like you might have a little software glitch or something going on. i would highly recommend upgrading your cables to HDMI. not only will you have fewer wires to deal with, you will also be upgrading both your sound and your video quality. in addition, the HDMI connections should be totally seperate from the other connections internally. you might luck out and find that only the analog side of things was afflicted. check out Newegg.com. you can get a 6' cable for $10.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2104300697%20117752939%201177412127&bop=And&Order=PRICE
only other option is to send the unit in for service.
Mar 01, 2009 | Onkyo TX-SR606 Receiver
HDMI video not functioning on a new Onkyo TX-SR606
For me, it was the Monitor Out setting that had defaulted back to Component. I remembered to change the individual inputs to HDMI - but had forgotten to set the Monitor Out to be HDMI.
Nov 28, 2008 | Onkyo TX-SR606 Receiver
Onkyo TX-DS939 optical selection problem help!
That coaxial, opt-1 and opt-2 are available only if they are not selected to some other channel. So you have to check if opt-2 is selected to Video-1,2,3,4,5,6,7,CD or DAT. Change that to Analog and then opt-2 is free to another device.
Mar 24, 2008 | Onkyo TX-DS939 Receiver
Onkyo Integra A-809 input selector switching by itself
This is not an IR problem. Could be just loose connectors and dry joints. You'll need to open the unit and visual inspection of the PCB and connector for abnormality.
Good luck.
Jan 20, 2008 | Audio Players & Recorders
Onkyo TX-SR605 Receiver Logo
182 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
