Question about Saeco Incanto Classic Espresso Machine
Saeco incanto deluxe
Suddenly, the coffee is coming out in spurts(not one steady flow). The amount of coffee produced is half of what is used to be. We have tried rinsing the machine and it will not let us descale it. We are very frustrated because we use this thing several times a day.HELP!!
  • darl3 Jun 21, 2008
    After I posted this message the descale came up on its own and we descaled the machine. A new problem occurred though. At the end of the descale when the machine rinses, it only rinsed for about 5 seconds and then stopped and said that it was finished. I rinsed it manually from there but then the water comes out of the steam spout instead of the coffee spout. Now when I make a cup of coffee and the machine rinses, only about a tablespoon of water comes out. It used to rinse out about a quarter of a cup worth of water. I am not sure what to do. The machine seems like it is working very hard. We called up Saeco but they seemed to think that this was not a problem.
    Help!
  • Anonymous Mar 22, 2014
    Sirena coffee maker suddenly stopped producing crema. hoses look good. temperature as before. Is it a problem of the tired crema disk in the portafilter?
  • 40 Answers
Try descaling it manually- by adding the descaler into the tank, letting the machine warm up and then open the water spout to fill one cup at a time. wait 15min. in between. Also clean brew group and grinder.
Posted on Jun 20, 2008
  • Ligia Moss Jun 21, 2008
    Try rinsing or running a tank of water manually again- by letting water out- this should rinse any residual descaler in the lines. Yes the water when rinsing should come out from steam spout, not the coffee spout. The rinsing after each cup is o.k. with small water coming out. You can also do another trick to rinse the machine manually and that is, at the end of the day, select ground coffee setting, do not add ground coffee, and let the machine make a cup of coffee without the coffee. This will clean the brew group as well.
  • dcpes1 Sep 14, 2010
    The lack of water coming through is probably a mis-setting of the fill level. Just press and hold the half or full select button and release it when the cup is appropriately filled.
Saeco incanto del luxe coffee machine dumps coffee into waste drawer
Your brew unit may be set in the wrong position inside the machine if someone has had it out to clean or try to fix. The unit has two positions open and neutral when putting back into the machine it should be neutral. This is something I would try first. Now if it is in the open position you will need to reset it. Resetting is better explained on video so I have put a link for a Youtube video. This guy is great and guides you through step by step. Hope this works for you good luck. Please post and let me know.
Cheers
How to Remove Stuck Brew Unit Q
Feb 06, 2015 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Deluxe won't dispense coffee while it making a sound of brewing coffee
try to make pregroun coffee ,but without beans,just press pre groud button -if water comes out then yuor coffee beans are too fine- turn to hight number the grinder
Aug 21, 2013 | Saeco INCANTO DELUXE Espresso Machine
Hot water ventilate problem for Saeco INCANTO DELUXE Espresso Machine 2 signs at a time "hot water" +"ventilate" "
Place a jug under the milk frother and turn the steam knob to allow hot water to flow.
Ventilate will clear after a short time
Jan 27, 2013 | Saeco INCANTO DELUXE Espresso Machine
Seams that my saeco incanto deluxe has a problem with the brew group possibly the boiler the grounds come out dry. If I do a rinse cycle the water still flows help? How do I clean the boiler?
Hi
Dosage lever or knob (small knob in the bean hopper) is to the max positive and the brew unit can not compress the coffee, so the machine dumps it into the dredge drawer to prevent breaking the machine. Reduce the amount by 1 click back from the full positive, and that should take care of the problem. Another thing that can cause this is the grind is too coarse or the grinder has come apart. The grinds should look like coarse sugar.
PS. It will usually work if the brew unit is clean, but when it is used once it will go back to dumping dry grounds.
Aug 19, 2011 | Saeco Incanto Classic Espresso Machine
Make coffee stronger on a saeco machine
Hi, adjust coffee amount knob more towards +, which will grind more coffee for brewing. The knob is the smaller one inside the bean hopper.If the machine has digital display(Incanto Deluxe) it can be set in the menu.
Jul 29, 2010 | Saeco Incanto Coffee Maker
How to drain coffee machine saeco s-class incanto classic
Subject: How to drain boiler of Saeco Incanto Deluxe
I got an answer from Saeco Customer Service as follows:
Good Afternoon,
All you need to do is have the machine turned on and up to temperature. Make sure that you have a full tank of water as well. Make sure the machine is set for hot water, then turn the knob on the side of the machine to start water flow. Once the water is flowing out, remove the water tank and, leaving the knob turned open so that the water that's in the system drains out. Once water stops coming out, close the knob and shut the machine off.
The water is now drained from the system.
Thank You,
Customer Service
Saeco USA
800-933-7876
Feb 23, 2010 | Saeco Incanto Classic Espresso Machine
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
Saeco incanto deluxe gear or splinbe drive out 180 degrees.
Thats a tough one without seeing the unit, use the pic below to help align the unit.5101bd5.jpg
May 31, 2009 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
338 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
