Question about Maytag Refrigerators
My Maytag side by side freezer/refrigirator MODEL MSD 2554AR is having ice frozen at the botton of the freezer basket.This later melts and form water on the floor of my kitchen.
  • okilling Nov 29, 2008
    Magtag refrigerator water on floor
  • 878 Answers
Ukoni, the drain tube for the defrost is frozen over or clogged. When the unit goes into defrost the water is running out through the front instead of down the drain tube. You can try to pour some real hot water with a baster to clear the tube. Remove the lower basket and at the bottom of the freezer panel in back is where the drain line is located. Catriver.
Posted on Jun 10, 2008
Maytag MSD 2432GR making sheets of ice on sides and bottom of freezer
If the water is showing on the freezer side, more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt. If thats not an option that you want to use the actual repair method would be to 1) unplug the machine 2) empty everything out of the freezer so you'll have room to work 3) take all the shelving and baskets out 4) locate the screws on the rear wall inside the freezer and remove them 5) take the back panel off exposing the evaporator coils ( the aluminum ) 6) directly below the coils is a trough of sorts and the drain is usually in the middle and runs out the bottom, remove the ice by carefully chipping it out or by using a hair dryer or hot water. 7) once all the ice is gone, the drain is visible and water can flow smnoothly down the drain dry the area and reassemble.
In maytag refrigerators you should also pull the machine out away from the wall and remove the lower portion covering the compressor, etc. Locate where the drain line comes out and look at the very end of it. If there is a rubber piece, sort of like a triangle shaped cap, there reach in and remove it. This is either the reason your having the problem or will be the cause of the same problem later on.
Jun 22, 2012 | Maytag MSD2436GR Side by Side Refrigerator
Maytag side-by-side refrigerator Model # MSB2154GR: Ice is forming in the bottom of the freezer under the basket?
Hello, Thank You for using FixYa. I will be helping you today.The drain line is frozen.Remove the back wall in the freezer and remove the ice.You can either use boiling water or a hair dryer.The drain hole is in the center bottom.Be careful not to touch or poke the evaparator(big aluminum thing) You have to remove all the ice until you see the hole keep pouring boiling water until the water runs down the drain.It is a easy job just takes some time.
Thank You and please rate my answer if it was helpful..
Jun 11, 2011 | Maytag MSB2654HE Side by Side Refrigerator
One year old Maytag refrigerator with bottom freezer. We noticed recently that water accumulates and freezes at the bottom of the freezer under the basket. We don't notice it then when there is enough...
The drain to the bottom is plugged. you will need to completely defrost the unit. The way I do this is to take all the frozen food out and either put into a different freezer or pack all the frozen food real tight in a cooler then use a hair dryer (under constant supervision) to melt all the ice in the bottom. use towels to soak up all the water. after all the ice is melted you should be able to see the drain. this is where the melted ice drains when the unit goes into the defrost cycle. I have used some small amount of hot tap water to clear the drain and once in a while you need to actually push something thru the tube(compressed air or flexable wire) to clear out a blockage (paper, small piece of food or chunk of ice).. Be extra carefull not to crack the plastic with anything sharp or by using to much force. Once the tap water goes down into the very bottom (thru the drain tube into the catch pan) then the ice won't form as the defrost cycle will put the water clear down to the catch pan. sometimes even a scumy mold build up will block the drain. Get the drain as clean as possible and you may need to keep an eye on it so it doesn't become blocked again. After you clear the drain close the freezer and let it cool down before you put the frozen food back into the freezer.
May 01, 2011 | Maytag Refrigerators
Ice forming in the bottom of the freezer, not from spilled water.
you probably have a stopped up draing behind freezer wall panel
Sep 19, 2009 | Maytag Refrigerators
Water puddling in bottom of freezer which freezes
Tool needed: Screw drive with the insert tips can be used to remove screws use the end of the screw driver with out a philips bit or flat tip inserted. Remove frozen food to camping coolers igloo ice chests or coleman ice chests or a freezer in your home . Remove all racks and baskets to expose movable panels at the inside back of the freezer compartment.
Notice the 1/4" hex nuts remove the screws holding the panels at the back wall. Clear built up ice carefully. You now can take out the panels and expose the fan and cooling cool that creates the cold temperature on the freezer side.
Near the bottom is an aluminum U shaped pan with a shallow funnel indentation at the bottom. Clear ice from the funnel pan and inside bottom carefully. Sharp objects break ice nicely and can pierce the interior surfaces . Look under the cooling coil and at the back wall is a screw holding this soft metal catch pan in place. Remove the screw and carefully tip and slid out the catch pan tray. You now have access to the drain hole that is frozen closed or clogged. Place a large towel in the bottom of the freezer area to catch water. Pour hot tap water a half cup at a time into the drain area. Do not use boiling water the plastic inside a refrigerator or freezer can not tolerate high temperature. I have melted a freezer compartment in a GE with a hair dryer. Remove the water with a clean reag and add more warm or hot water repeat until the drain allows water to flow. stop adding water or the evaporation pan under the refrigerator will over flow.
Check the refrigerator about once a year for the freezeup problem or keep an eye on the bottom of the freezer looking for the build up of water frozen on the inside floor. The other solution get a new refrigerator.
Dec 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Water puddling in bottom of freezer and freezing
the drain in the back of the freezer is probably full of ice. you need to pull out panel and use heat from a blow dryer to unplug the drain. then take a small gauge copper wire long enough to extend into the drain a couple of inches and loop it around the black heating element then when it goes yhrough defrost it should keep this from reaccuring
Bottom of freezer has water dripping into it
A bad freezer door seal causes condensation that freezes at the bottom of the unit. I realize you said the drip pan was full of ice, but if the drain is clogged, that will happen. If that unit has the pan at the very bottom, condensation can also contribute to this.
Jun 17, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Water leakage in and below freezer on Maytag MFD2560HES
you have a clogged defrost drain, or your ice maker (if so equipped is leaking. clogged drain can be remedied removeig drawer , andmelting ice build up behind rear panel of refrig, you see an aluminum trough that the water drips down,using a hair dryer melt all thatice out of the way to clear the drain tube(i use a steam machine i purchased from infomercial works extremly well
Feb 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
271 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
