Question about Konica Minolta magicolor 2400 Laser Printer
Question about my "Paper Jam at Transfer Roller" issue
Hi Nopoke:
Thank you SO MUCH for your feedback and advice. I did call Konica, and they only told me about the one sensor in the middle of the printer. It looks like a little black cheap pin right, in the middle of the printer, between two roller looking things? Is that one of them? I pulled that out and the pin is now visible and hanging out, which I believe is what it should be, but it's still reading the error message.
You did mention another sensor that I can't see to understand where it's located. Where exactly is the fuser, and where would this other sensor be at? Perhaps, that's the next one that I need to fix and it should work?
I don't want to be taking this printer to a shop, as I know the moment I do, they'll charge me $200+ just to look at it, when all it could be is a jammed sensor.
Please help if you can. I'd greatly appreciate it. You can email me at kennethlin@carolina.rr.com directly. It's much easier for me to check that way.
Thanks again,
Kenneth
    Champion:
  • 214 Answers
Fuser is that place, whats Hot and where the paper comes out at the end. and middle of the fuser there is a sensor.
Posted on Jun 19, 2008
Paper feed jam near the fixer of konica minolta C220
check the transfer belt and the transfer roller (Sponge looking roller)
Jan 22, 2014 | Konica Minolta Magicolor 2590M F...
I have a konica minolta 1690mf. paper feed problem error 094
Transfer roller issue. the sponge looking roller across from the transfer belt.
Jun 26, 2012 | Konica Minolta magicolor 1690MF All-In-One...
Konica minolta MEDIA JAM TRANSFER ROLLER
yes 2 things. 1 bad sensor. 2 bad paper. change paper brand and type. use hammil mill 20# long grain brightness90 and above to test. if this works you need better paper. if not you have a bad jam sensor and need a tech to repair ir.
Dec 30, 2009 | Office Equipment & Supplies
Media jam, transfer roller
Replace the offending transfer roller.
Dec 20, 2009 | Konica Minolta magicolor 2300DL Laser...
Magicolor 2400w gives paper jam error at transfer roller, after I cleaned the printer -laser head.
My 2400W was standing a long time without being used, and when I wanted to use it, it made a very faint image and showed "paper jam at transfer roller". Also, the image stayed on the transfer belt, but never got transferred to the paper. I tried a lot of things, nothing worked, but the message from weirdal1968 above pointed me in the right direction.
I eventually scratched / scrubbed / cleaned the copper pad on the left side of the optical imaging drum - this copper pad probably receives the bias voltage for the imaging drum from a springy stainless steel wire. There was some visible darkening of the copper pad where the stainless steel wire touched, this is what I cleaned. And then, presto, problem solved - the image came out great, and no more "paper jam at transfer roller" error message.
Oct 12, 2009 | Minolta magicolor 2400W Laser Printer
Konica Minolta 2400W Error Message
remove the opc drum.
there are two black plastic flags that detect paper jams. one is high up just below the fuser unit. The other is roughly half way up the printer between two small transfer rollers very close to the opto sensor. Apparently it frequetly gets jammed behind the plastic cover, and once jammed you would never realise it is there.
I managed to prise it out from behind the cover and the "paper jam at transfer roller" message was cleared.
Unless you know it is there and hiding it is not obvious at all that anything is wrong.
Ian
May 23, 2008 | Konica Minolta magicolor 2400 Laser...
I get a Media Jam Message
Hey folks! This solution worked for my "media jam tray 1" problem! Just took out paper, pushed down @ back of tray, reloaded paper, and bingo! Now to use some air to blow out any dust.
Thank you
Mar 23, 2008 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta magicolor 2400 Laser Printer Logo
206 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
